Fob was stolen, can't find spare. Dealer wants $500 :(
Discussion in 'Gen 2 Prius Main Forum' started by Raghav, May 18, 2017.
  1. Raghav
    Raghav Junior Member
    39
    My prius 2006 fob was stolen. My car is locked now. I searched entire house 5 times, could not find the spare. Dealer wants $500 for a new fob. What are my alternatives? I have the metal thing with a number on it which came with the fob.
    Thanks in advance.
  2. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    Depends on where in the country you are, how soon you need to use the car, and if you can get to a locksmith or if they need to go to you. It's not going to be cheap.
    Art's Automotive
    If the dealership is including the cost of towing your car into their shop in their price, $500 may not be all that far out of line.
    You're in a tough spot. I'd bet that you could eventually find your spare key, but it might take extreme measures, and two or three full days of searching. And, all the while you won't have a running Prius. So, the question you have to ask yourself is "What is three days of my time without a car worth?" Personally, if I had to choose between packing up each and every thing I owned versus paying $500, I'd probably pay the money. But, YMMV.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,379
    3,235
    Madison, Wisconsin
    $500 for an "all keys lost" situation is not too bad a price at a dealership.
    You can try calling around some locksmiths and see if they can help it may not much cheaper. Hard to say
  4. Mendel Leisk
    38,952
    Yeah they'll give you one or two fobs for $500? Two, starting with a fobless car, sounds like a really good deal. One fob, still a good deal.
    Or hang in there, find the spare, should cut the cost.
  5. Raghav
    39
    Thanks for all the reply. Found the spare finally, so relieved.
    Still can't believe it costs half grand for a key.
  6. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    You might want to get another key in case the one you have left goes missing...
  7. dolj
    dolj Senior Member
    7,788
    3,942
    Wellington, New Zealand
    It's to motivate people to not loose them.
    Glad you found your spare. Will only cost about $110 to buy a new key and program it yourself.
  8. ericbecky
    4,379
    3,235
    Madison, Wisconsin
    Go buy a NEW key right now.
    And if someone stole you other one you might want to have the other key(s) wiped out and only re-register the one you have now.
  9. Mendel Leisk
    38,952
    That's a relief! I misplaced mine once, leaving us With just one. Found it, and decided at that point, to attach a small luggage tag with my phone number.
    biglew8 likes this.
  10. Raghav
    39
    That a good idea in case it is lost. Not helpful when it is stolen.
    Now on to getting a new spare...
  11. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Now that you have one working one it won't.
    When you lose BOTH a computer board has to be changed out in most models.
    Call locksmiths ASAP to get a spare made.
    Next time you might not be so lucky.
  12. RobH
    RobH Senior Member
    2,369
    979
    70
    This was true of Gen1, but locksmiths came out with the ability to reflash the key ECU.
    Everything since Gen1 can be recovered with Techstream or similar locksmith equipment. The kicker is that it requires a "seed reset". Techstream issues a magic number, and the seed is a computed reply to that magic number. Seeds come from a central Toyota computer that is restricted to licensed dealers and other security professionals.
  13. Raghav
    39
    How to wipe out stolen key? Could not find any guide. Can I do it or need to get it done by dealer? Also, aren't both the keys same? If wiped, won't other key stop working? Any link to a guide is appreciated. Thanks.
  14. RobH
    RobH Senior Member
    2,369
    979
    70
    Techstream has a "delete all keys except the current one" function. Do it both for the immobilizer and again for the smart key system. You'll need to get a Mini VCI system that works with the key system (some fail on K-line functions like the keys and TPMS).
  15. bobzchemist
    507
    342
    For this, I'd probably go to the dealer or a prius-experienced locksmith. Have them delete all the keys except your current one using Techstream, THEN make a spare or two, maybe even an extra mechanical key. There's a few threads here about hiding a no-battery-power spare fob somewhere on/in your car. The mechanical key will get you in the driver's side front door (but won't start the car). The no-battery fob will start the car if it's right next to the ignition switch (but won't open/lock the doors). Where you keep those so that you can find them later is up to you.
    Need to deactivate stolen key fob for 2009 Prius (NHW20) | PriusChat
    Deactivate stolen key fob for 2004 Prius | PriusChat
    2007 Prius stolen fob | PriusChat
  16. surferboy808
    surferboy808 New Member
    Honolulu
    Some really good info here thanks guys
  17. Raghav
    39
    Where do I get Techstream? Is that a software or hardware?
    Also I think I have to first delete "all keys but current" first then program new fob. Is this right?
  18. Raghav
    39
  19. bobzchemist
    507
    342
    Yes, that's the right gizmo. Can't speak to the reliability of the manufacturer, though. There are a bunch of chinese versions floating around. I've heard that it's best to download the software from an online source.
    Using the OEM tools is very, very expensive (but less risky) which is why I suggested a dealership or other pro.
    The official device is this, I think:
    And then you need a subscription from Toyota to Techstream:
    https://techinfo.toyota.com/techInfoPortal/appmanager/t3/ti?_nfpb=true&_pageLabel=ti_home_page&contextType=external&username=string&password=sercure_string&challenge_url=https%3A%2F%2Ftechinfo.toyota.com%2FtechInfoPortal%2Flogin%2Ftechinfo&request_id=5078392247083709271&authn_try_count=0&locale=en_US&resource_url=https%253A%252F%252Ftechinfo.toyota.com%252F
  20. pTomic
    pTomic New Member
    Serbia
    If I want to buy used Prius gen 2 (manufactured 2007) can I use this cable and software to check everything that I need to check (battery status, errors, etc.) ?
    iPad ?
