fred's c and the bicycle test
Discussion in 'Prius c Main Forum' started by fgp, Mar 14, 2012.
  1. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    well, here are the results of fred's bicycle test for shorty the c. can you fit a bike in it. in my past test on regular prii no sweat. but this guy... SUCCESS (mostly) i just put my bike in but had to remove the bike's front wheel. just barely fit, but it does.:)
    3 people like this.
  2. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    is it behind rear seats or with seat down? also which bike road/MTB, and what size L/M/S, thnx
  3. Tandem Rider
    Tandem Rider Junior Member
    56
    Indianapolis, Indiana
    A month ago I bought a Prius and strongly considered the V to haul my tandem bicycle. I measured and did not think that it would fit so I stuck with the hatchback. If the V would work is would save driving my Sienna with half the mph.
  4. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    sorry, it is definitely with the seats down. this is a 28inch giant model bowery, single speed. ive put straight bars on it for my comfort
      File size:
      184.7 KB
      2,033
    2 people like this.
  5. BrunoPuntzJones
    107
    28
    Mine fits fine too. Then again, mine has a quick disconnect for the front wheel and folds in half :D
    Montague Crosstown
  6. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    show off!!!:eek:
    but i do think ill get a quick release nut for the front
  7. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    a new pic . here is my giant bowery inside my prius (i hope)
    2 people like this.
  8. bugly64
    bugly64 Junior Member
    66
    Marysville, CA
    My bike barely fits in my '05 Suburban.
    NDcowPoke and jonb505 like this.
  9. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Yeah, but you've got an SUV cargo hauler version. I think that's longer than my LWB recumbent, and definitely longer than the trike. :cool:
    I've fit two mountain bikes in the back of a 'regular' Prius - front wheels off, and seats down.
    Good to know the c passes the bicycle test.
  10. moezer2112
    moezer2112 Futurist
    115
    50
    Iowa
    fgp,
    Looks like a Vietnam Service Medal sticker on your C.
    Thank You for Your Service!
    :usa2:
    2 people like this.
  11. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    holy mackeral!:eek:
  12. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    thank you very much for your comment. so many people walk up to me and ask what it is.
  13. arlotone
    arlotone New Member
    25
    Portland, OR
    I can confirm your bike test, with a standard road racing bike. My frame is only 52cm, but larger frame sizes should be fine as long as the wheelbase is similar. Removed the front wheel and it goes in and out easily.
  14. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    Good to know for us two wheel fans.
    Just a little worried about the statement I found in the Owner's Manual that mentioned a tow bar isn't recommended, even if you're just going to hang a bicycle rack off it.
  15. Veloist
    Veloist Junior Member
    16
    SF Bay Area
    Awesome! I'm a road cyclist, and as long as you take the wheels off and put the seats down, I'm sure a bike can fit in there, but some special oversized frames might need a distinct angle.
  16. barbinchicago
    barbinchicago New Member
    I ride a 56cm bike and stand 5'11" tall - do you think the frame can lay flat in the C without changing seat height? (Obviously I would remove the front wheel.) Thanks in advance - critical question before I purchase!
  17. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    See this post for reasonably accurate dimensions of the cargo space with the rear seats folded.
  18. vernon birdman
    vernon birdman Active Member
    330
    141
    Vernon BC Canada
    Cool bike.
  19. advicepig
    advicepig New Member
    I can easily put my 58cm road bike in with the front wheel still on when the seats are down in our C. I do have to turn the front wheel so it's going vertically.
  20. Frank Valdivia
    Frank Valdivia New Member
    16
    Upland CA
    2014 Prius c
    I can fit my prius c in my Specialized Allez very confortably no wheel removal at all :)
