fuel consumption
Discussion in 'Gen 2 Prius Main Forum' started by Mehmet alb, Jul 17, 2022.
  1. Mehmet alb
    Mehmet alb Junior Member
    77
    Turkey
    My 2007 Toyota prius car is burning in 100km 5 lite petrol,. What can I do to reduce fuel consumption. the tires are new, and the front tire is 35 psi, the rear tire is 33 psi, the oil and filters have just changed. I use it gradually during takeoffs. the battery status is medium. Thank you so much for your other oneeis.
    52,838
    new tires,, almost always the problem
  3. Mehmet alb
    77
    Turkey
    52,838
    they might just need to be broken in. are they 'low rolling resistance'?
  5. PriusCamper
    PriusCamper Senior Member
    13,452
    5,430
    Pacific Northwest, USA
    Pulse and Glide driving can boost MPG: How to Pulse and Glide? | PriusChat
    Also I drive with 47psi in front and 45psi in the rear. It's a much more rough ride but way better gas mileage and my tires lasted 10K miles longer than they were rated for.
    But your fuel consumption is fairly normal for most Prius.
    #5 PriusCamper, Jul 17, 2022
  6. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    5L/100km = 47mpg US or 56mpg UK
    Normal mpg for Prius
  7. beef jiggles
    beef jiggles Member
    136
    34
    Colorado
    I'd argue that is better than normal if you drive like a normal human and not a typical Prius Owner.
    TheLastMojojomo likes this.
  8. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    What grade of petrol are you using? 91 RON? If so, try 95 RON. When I changed to the recommended grade of 95 RON (in my country), I went from 5.2 L/100 km average to 4.7 L/100 km average. It also worked out to be cheaper per km to use the slightly more expensive 95 RON due to getting 200 km more distance out of a tank of fuel.
  9. Mehmet alb
    77
    Turkey
    .[beef jieggles
    biraz akıllıca cevap verelim lütfen i[/QUOTE]
    #9 Mehmet alb, Jul 18, 2022
  10. Mehmet alb
    77
    Turkey
  11. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    Is this consumption new or same as you’ve always experienced?
    How long have you owned the car?
    What other maintenance have you done besides filter, oil and tires?
  12. Another
    1,819
    520
    Naples, Florida
    That’s very surprising.
    Mehmet alb likes this.
  13. Mehmet alb
    77
    Turkey
    I bought the car 7 months ago. it has the ariza code po402. i installed a stub on the second sensor, and the po402 code was deleted. the spark plugs are the same as the original ones. has anyone else had
  14. Mendel Leisk
    42,332
  15. bisco
    52,838
    oh dear,
    14 posts to find out everything is normal?
    PaulDM likes this.
