Fuel Mileage Questions
Discussion in 'Gen 3 Prius Fuel Economy' started by parrotlover, Aug 26, 2013.
  1. parrotlover
    parrotlover New Member
    29
    Central Missouri
    So, I'm new to this forum but not completely new to the Prius. I've had an '09 Prius for 1.5 years and we recently bought an '04 Prius for my husband and just bought (in the past month) a '10 Prius to replace the '04.
    In the 1.5 years driving the Prius, I have rarely gotten to 50mpg and I've just been ok with it since the EPA estimate on the '04-'09 is 48/45. But since driving the '10, I've been expecting better mileage and I'm not getting it. I've been getting about 45-46 on it.
    I know my tires suck and I know I need to air them up more, but will that make the difference by itself?
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations)
    I'm getting 45-46 on the trip computer - I did a manual calculation once and it was 44.4mpg.
    - What fuel economy are you expecting and why?
    I'm aiming to get to 50mpg.
    - What are the approximate outside air temps?
    They've been 70-90 degrees.
    - How long are your trips?
    I drive 45 miles to work and 45 miles back home. We have also taken a 3 hr trip and have averaged the same gas mileage.
    How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night?
    I haven't checked it yet.
    Have you had your alignment checked? Any pulling or abnormal tire wear?
    Tires look good...even wear, but haven't had the alignment checked.
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving?
    I drive mostly highway.
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.)
    Mostly flat with some gentle hills.
    - What are your tire pressures?
    Just checked them at 32 (I know I need to fill them up more)
    - Is your oil overfilled? (i.e. above the full mark on the dipstick)
    Looks like it may be like a mm above the full mark.
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.)
    I drove a '09 Prius but still never got 50mpg. Mostly 44-45.
    - What region/state are you in? (if you haven't set your location)
    Mid Missouri
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    I'm pretty light on the gas and try to glide to stop lights/signs but I mostly drive highway.
    - What modes are you using, if any? "normal", EV, power, eco?
    I've used Eco and normal and haven't noticed a difference using one over the other.
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on?
    No. Should I?
    - Are you driving using D or B mode?
    I use D. When hubby drives, he likes to use B a lot when slowing down.
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to?
    AC occasionally. I always set it to auto and usually 77.
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size (e.g. Goodyear Assurance Fuel Max 185/65R15).
    Mastercraft Avenger Touring 195/65R15
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute?
    No
  2. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Since most of your questions are fuel mileage related. Check your tires and if they are not Low Rolling Resistance tires, that should be the problem. I know, its hard to believe tires can make that much of a difference. Believe it! Check air pressure, depending on the tire manufacturer some of us run close to max. My tire presure is 40 front and 38-39 rear (Mich. Energy Saver A/S). Also, depending on how many miles you have on the 2010, a transaxle fluid change would be a good idea in the 30-40k mile range (first time). Last calculated mpg was 56 mpg on flat roads and some hills. Sorry, have to run!
    jgilliam1955 and parrotlover like this.
  3. fuzzy1
    10,688
    That is too low. According to the door label, the fronts should be 35, rears 33 when cold. Many of us take that label as the minimum, and more is better for mpg, though the harsher ride may limit how high you wish to go.
    When you checked, were the tires still at morning cold conditions, or had you driven within the past few hours? If the later, the cold pressure could be even lower than 32.
    If the the tires are not Low Rolling Resistance models, you will lose few mpg.
    Were the tires new when you acquired the car? If so, the newness will also cost a few mpg until they get broken in.
    Any one of these tire issues can't explain your mpg shortfall, but all three together could possibly account for it all.
    B will cost a bit of mpg, compared to a judicious use of the regenerative braking. D mode with light to moderate braking (without pegging the CHG bar on the HSI screen) is best, but many people will brake harder than that, wasting some regeneration potential.
  4. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Just checked out the Master craft tyres they are not low rolling resistance (LRR), in fact they are very poor in that department.
    They could be loosing 5 mpg or more against good LRR tyres, something that the Prius requires to get the sort of mpg you are looking for. The pressures you are running at will also not help, try 38f/36r or even higher if you do not mind the harder ride.
    John (Britprius)
    F8L and parrotlover like this.
  5. Madduck
    Madduck New Member
    22
    SLC, Utah
    44 MPG does sound low. I have a similar drive and get an average of 50 MPG. When I bought my used 2010 it had brand new Pep Boys Futura tires that are not LLR. I have just left them on because I don't know if it make financial sense to buy new LLR tires.
    After reading other posts here I increased my tire pressure to 42/40 and noticed a increase in MPG. You should also check your engine and cabin filters. They might need to be replaced.
    How fast are you driving on the highway?
  6. retired4999
    2,652
    627
    Eau Claire, Wi.
    Check side wall of your tires for max psi number do not excede that psi number, If you can increase to 40 psi front and 38 PSI rear. (will make a big difference).
    Do not use B mode unless needed. Use when coming down mountains. Using B mode on a daily basis will cost you mileage.
    Just start car and drive off. No need to warm up.
    Set air cond. as high as you can live with 77-80 is good, fan speed as low as you can live with.
    Light on gas and gliding is good. Don't try to stay in electric, us the battery as little as possible as it has to charge the battery later causing loss of mileage.
    These things will get you up to 50 mpg or better!
    Enjoy your car! :)
    Daddyjeph likes this.
  7. Britprius
    5,194
    1,922
    Obviously it depends on the price of fuel, but in the UK with our high prices the difference in 2mpg will pay for 4 tyres in there own lifetime making it worthwhile to change tyres to the best LRR tyres.
    John (Britprius)
  8. parrotlover
    29
    Central Missouri
    Thanks so much for the replies. I've just been debating on whether I should spend the $$ on new tires, or just wear these out. They seem pretty new, but of course I'm no expert. I typically drive between 65-70 on the HWY. I will definitely tell my husband to stop using "B" mode so much. None of the three Priuses we own have had LRR tires and I'm really beginning to wonder if thats why we can't seem to hit 50mpg. Its just frustrating because everything I read says that Gen III Priuses are supposed to get 50mpg with no effort and up to 60mpg with effort. I'm also going to start using Fuelly to keep track of my mileage a bit more.
  9. jnet
    jnet Member
    196
    32
    If you have money to throw away then buy new tires, otherwise, I would just wear them out because it's already paid for. Check the max pressure your tires can handle and then fill them up to 90%. My tires can handle 44psi so I fill mine up to 40psi. But I must warn you, high pressure = less safe. Therefore, I don't drive as fast with high pressure tires. If it's raining, I definitely slow down more than usual.
    LRR aren't for everyone. IMO, there's a trade off. To me, my ride is less comfortable with LRR tires. So it's up to you. I have LRR tires, my overall average is 55 mpg. Driving on local roads under 45 mph, I could easily get 65 mpg.
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    If he is driving in the mountains, (Ozarks?) then he may wish to use B from the top of long downhills.
    B under the D in the Drive gears? | PriusChat
  11. fuzzy1
    10,688
    The "high pressure = less safe" view is disputed, not a consensus. You will find several conflicting views here.
    I'm on the side that higher pressure lowers the risk of hydroplaning, a significant issue here in the Pacific Northwet. This is backed up by NASA and other aviation sources linked in previous threads.
    The opposition points to changes in wet traction in the absence of hydroplaning. I haven't seen enough documentation to convince me.
    But when the road is wet, drivers should slow down or allow greater spacing regardless of tire pressure.
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    Slow down on hwy to 62-65 mph and you will gain about 3-5 mpg instead of going 67-70 mph, but only if it safe to do that!
  13. jnet
    jnet Member
    196
    32
    When I was at the dealer, I asked them to make sure that my tires are at 40 psi, the refuse to do it. They set them at 35 psi. I had to bring them back up to 40 psi when I got home. They said over inflated tires have less surface touching the road. Therefore, the stopping distance will be longer. They didn't say anything about hydroplaning.
  14. fuzzy1
    10,688
    Toyota puts about 40 psi in the tires at the factory, to reduce tire flat spots during their long Pacific cruise. The dealers are intended to reduce that to the door label values during PDI, but neither of my Prii were so reduced. Numerous other PC readers found similar over-label pressure upon delivery.
    When getting service on a very long road trip, while the tires were highway hot at high elevation, a dealer technician claimed my tires were dangerously overinflated, and refused to leave them over 40 psi.
    Unfortunately, he didn't understand pressure vs temperature and pressure vs. altitude changes. The next cold morning at sea level, a mere two hours away, my tires were actually UNDER-inflated.
    On a subject were we want to know the advanced details about tire traction, your dealer doesn't even know the basics of classical friction physics.
    I learned about this the hard way, in a previous car, long before seeing the papers linked here in PriusChat.
  15. jnet
    jnet Member
    196
    32
    Fuzzy1 - it's either they don't understand it or they are just covering their butts. I don't mind filling up the air myself but it's just a pain to get those hubcaps off and putting them back is even harder. To tell you the truth, I could not see the tire shape change by just adding 5 psi
  16. jnet
    jnet Member
    196
    32
    By the way, I didn't say high pressured tires are not safe. I said they are less safe. The link provide some good information about this. Of course, the info is general and not specific to any particular brand or model of tires. For me, I think high pressured tires are fine since I drive slower than most people.
    Over-inflated tires are a bad idea - Wheels.ca
  17. fuzzy1
    10,688
    We have been through this many times, possibly before any of your identities here were established ...
    I used to religiously follow the car company recommendation. Then my new Accord suffered seriously premature hydroplaning, which was eventually cured by increased pressure. Then the Ford Explorer - Firestone Fiasco struck, with many fatalities, and a too-low pressure recommendation was one of several contributing culprits.
    Tire wear patterns on several of my past cars, and on many Prii as reported in this forum, also point to door label recommendations being too low.
    Pressure is a compromise between many conflicting goals, with comfort being very high on the list. Many of us are willing to put less weight on that.
    Safety? While multiple articles such as the one you linked say one thing, a similar number of others keep pointing the other way, and numerous driving professionals go for increased pressure. Then we find more evidence that the research on the high pressure side is actually very skimpy and sparse compared to research of underinflation. The issue remains unsettled.
  18. jnet
    jnet Member
    196
    32
    I never follow any tire pressure recommendation religiously. But I do believe there's a trade off. under inflating a tire is also unsafe. I guess as long as we are working within a certain range, we will do fine. I'm just saying for myself, if I'm going to inflate my tires to the upper limit, I should at least slow down a bit to compensate.
  19. retired4999
    2,652
    627
    Eau Claire, Wi.
    Over inflation is not when you inflate your tires to the max setting on side wall of tire. It's when you excede that max psi!
    So for my tires 44 front and 42 rear are just fine, just don't excede that!.
    So I set mine at 42 front 40 rear. :D
    fuzzy1 likes this.
  20. retired4999
    2,652
    627
    Eau Claire, Wi.
    You are correct! Under in flation is the worst thing you can do! Just ask Ford and Firestone!
    Ray-o-Vac, jnet and fuzzy1 like this.
