Fumoto Engine Oil Drain Valve
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Peng Xiao, Apr 23, 2019.
  1. Peng Xiao
    Peng Xiao Junior Member
    84
    New Jersey
    2018 Prius Prime
    Anyone put a Fumoto Engine Oil Drain Valve on the Prime? I think it should be F103, just want to confirm.
  2. a_gray_prius
    2,927
    783
    IL
    I'm too worried that the lever might accidentally catch on something and leak oil out without my knowledge. I know it's kind of an irrational fear (it's kept me from installing them on our cars with floor panels that need removal before oil changes), but nothing really beats the solid drain plug.
  3. MichaelKnight
    MichaelKnight Junior Member
    39
    22
    Westcoast
  4. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    I have/had them on every Gen II where there is no underbody panel near the oil pan, never had a problem other than it takes a lot longer to drain. You can buy a clip that will keep the lever from moving if you want.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,531
    2,553
    Taylors, SC
    Used this one for years on both our cars,
    Sure Drain SD3 | eBay
    It's discontinued but is still available. Never had an issue or a leak.
  6. Peng Xiao
    84
    New Jersey
    2018 Prius Prime
    Do you use F103?
  7. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    I don't recall, bought them some time ago. Bit it was easy to figure out on their site. Haven't looked to see if they have one for the Prime but I have to ASSUME there are only a few drain bolt sizes and they do have one.
  8. Peng Xiao
    84
    New Jersey
    2018 Prius Prime
    Cannot find Prime on Fumoto website. But I found out Prime and Prius are using the same drain plug, so I think they should both use F103.
  9. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    I have a spare Fumoto if anyone wants it. It was in use on my car for one oil change but I took it off. Part #F103SX.
    SFO likes this.
  10. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,847
    Hyampom
    I sent them an e-mail a few years ago and they responded quickly. I am sure they can answer your question. All my family have used them for years. No problems at all I do notice now thathey include a little locking clip, but doubt I would ever use the clip. The sx is the newer model that allows you to "custom" mount it so the drain lever is in accessible spot. I need an F108 -- but not for a couple months.
  11. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    The newer valves also have a "nipple" to connect tubing so you can drain directly into a container rather than hoping the wind doesn't blow too much of it away from the catch pan. Yes I have had that happen, especially when you are near the end of draining and the stream is thinner.
  12. cyberpriusII
    1,157
    1,847
    Hyampom
    Actually, you could always buy a valve with a nipple, or a comparable valve without the nipple -- the deciding factor being if you were worried about the "extra length" on the nipple valve vs ground clearance. Never went with the nipple valves. guess I like to live dangerously. :sick::sick:
  13. Peng Xiao
    84
    New Jersey
    2018 Prius Prime
    Maybe their support is a robot. Keep telling me to go to their website to find the correct model base on my vehicle, even I replied I cannot find my vehicle on their website
  14. The Critic
    3,193
    2,333
    CA
    All Toyota’s use the same thread size and pitch.
    SFO and Raytheeagle like this.
  15. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    I had a Fumoto on my previous car, sold it with it still attached. A wonderful part and well worth the money. Then again, that car needed oil changes every 3-5k miles. This car only needs it every 10k, I still think its worth it, but you still get oily taking the filters off.
    vegan likes this.
  16. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    Which of the Fumoto valves works with the Gen3 Prius? I assume that the F103N (with the long nipple) would not work, but what about the F103S (with the short nipple), or do we have to settle for the one with no nipple so that it's not trying to poke a hole in the cover. (I put one on the Chrysler that we no longer own, and we have one on the Vibe that we still have, so I am an enthusiast -- but not if there's a particular problem with using one on our low-clearance Prius.)
  17. Peng Xiao
    84
    New Jersey
    2018 Prius Prime
    I just got under the car, took off the plastic panel that cover the oil plug, positioned my F103S. Looks like it's just OK, do not need to cut a hole on the plastic panel. Even if it's a little bit long, the panel is plastic, should be fine too.
    I have 8400 miles on my Prime, will install it after the 2 free oil changes.
  18. Peng Xiao
    84
    New Jersey
    2018 Prius Prime
    I took down my Honda Accord’s oil pan with a Fumoto valve, its thread part is about 1/16 inch higher than the oil pan’s bottom, so it keeps about 0.2 qt oil in oil pan. I think it will be similar on Prius Prime.
