Gen 2 (2009 Prius) - Noise Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ronni_K, May 15, 2015.
  1. Ronni_K
    Ronni_K New Member
    This weird noise that I have been detecting past few weeks have been bugging me. I was wondering if someone can help me figure out what is causing this noise? I simply do not want to fork out $150+ to get the diagnostics done from the dealership. Where can I upload the video file? I tried to upload a file with this post but I couldn't...
    Thank you for your help in advance!
  2. JC91006
    16,935
    8,646
    I heard you have to have a certain amount of posts before you can upload anything....maybe 5. So just keep replying and say something stupid and come up with 5 and then upload. :)
    You can try describing the noise? When do you hear it?
    #2 JC91006, May 15, 2015
    Ronni_K likes this.
  3. Ronni_K
    Ronni_K New Member
    Ohhh...Perhaps Priuschat should have instructed newbies on that policy...
    I actually just uploaded on Youtube...here is the link
    Let me know if you heard of this noise before....thank you!!!
  4. JC91006
    16,935
    8,646
    I believe that's the coolant control valve problem.
    Ronni_K likes this.
  5. Ronni_K
    Ronni_K New Member
    So...do you recommend taking my car to the dealership? or is it common issue that can be fixed easily...?
    Also, my engine light isn't on. I just picked up on the noise...and ever since..it has been bugging me....
    #5 Ronni_K, May 15, 2015
  6. JC91006
    16,935
    8,646
    The valve is supposed to allow fluid to flow to the coolant heat recovery canister, upon startup. Since your car is a 2009, fairly new, I would replace the valve.
    Sometimes this issue can come up when you are low on coolant in your radiator. You can try adding coolant and see if that will solve your problem and the noise goes away.
    If you do find that your radiator coolant is low (which you have to physically look by removing the radiator cap), then you'll have to find out why the fluid is low.
    The correct fluid to add to the radiator is Toyota Super Long Life Coolant, which is pink in color.
    What maintenance have you done on the car? How many miles do you have on it?
  7. Ronni_K
    Ronni_K New Member
    ODO: 114230
    Last Maintenance was Synthetic Oil Change and I completed cooling system flush on 12/17/2014 (odo:10268)
  8. JC91006
    16,935
    8,646
    well you've done the necessary coolant change at 100,000 miles. If this was done recently, I would suspect that was the cause. But since it's been over 10,000 miles, it might just be a bad valve.
  9. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
  10. JC91006
    16,935
    8,646
    So did you service the car 4000 miles ago or 10000? If this has been happening for a few weeks and it's been 4000 miles since last service, the dealer may have not gotten all the air out.
    Does your heater work?
  11. Ronni_K
    Ronni_K New Member
    So........I purchased radiator coolant and filled it up...since I have noticed the fluid wasn't all the way to the full. However, I don't believe it was that low. Also, the noise didn't go away... :(
    Does this mean I have to shell out $150 to get the diagnostics done?!?!?! I was hoping the noise would go ahead...
  12. Ronni_K
    Ronni_K New Member
    Are these questions for me?
  13. JC91006
    16,935
    8,646
    Did you put fluid in the radiator by removing the metal radiator cap? The cap is covered by a black plastic cover, covering the front part of the engine.
    Can you check if your heater works and generates heat?
  14. JC91006
    16,935
    8,646
    yes, it's for you
  15. Ronni_K
    Ronni_K New Member
  16. JC91006
    16,935
    8,646
    That is not the radiator, that is the inverter coolant reservoir. There's another one like it for the engine side.....but that's not where we want to fill it. We want to fill directly into the radiator itself, not the reservoir.
    You should still verify if the heating works.......it'll answer a lot of questions
  17. Ronni_K
    Ronni_K New Member
    I got the coolant flush service done over 10K miles ago. Now I am due for another oil change.
    I get my oil change done at local spot that provide car maintenance services. Dealership charge arms and legs for the oil change.
  18. JC91006
    16,935
    8,646
    The oil change is not the issue, the coolant service might be an issue if not done right.
  19. Ronni_K
    Ronni_K New Member
    Major fail....well I blame Google haha perhaps I should have asked you.....
    I will check on the heat and report back in a bit.
    Thanks again for patiently answering all my questions!!!! :)
  20. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    do not remove the radiator cap when the engine is hot. wait until it is cold or you will scald yourself and get coolant all over the place.
    the coolant valve can be replaced pretty easily, but if cali has a 150k emissions warranty, you might be able to get the dealer to do it free.
    Ronni_K likes this.
