Gen 2 ... Dr Prius says two blocks bad
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DylanWinter, Mar 18, 2024.
  1. DylanWinter
    DylanWinter New Member
    Suffolk
    Sorry chaps... you must get lots of these
    69 year old ag engineer
    135,000 mile old Prius
    full range of lights on - triangle, brakes etc - they have been like that for six months
    - then two weeks ago the car mpg fell from rock solid 61mpg -(English gallons) to 50 mpg
    I bought a dongle and ran Dr Prius... It said that blocks 2 and 3 are bad
    so I bought four second hand battery units for £22 each
    took the car apart and replaced blocks two and three with the four ebay battery elements
    same symptoms
    and here is the film
    when under way the pack voltage drops from 220 or so to 160 or so
    blade voltage also falls to around 6 - but only for short periods - the IC engine never turns off
    what - what next?
    also it says that the 12 volt battery has no voltage although avometer says it has 12 volts in it
  2. DylanWinter
    Suffolk
  3. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    You have a voltage sensing wire problem on blocks 2 & 3. These are small wires that go from the battery modules to the battery ECU. Start by checking for corrosion on the connector at the battery ECU. This is a very common problem with the Gen 2. Do a search on this forum, and you find pictures. Check the trunk of your car for water or moisture.
  4. DylanWinter
    Suffolk
    Thank you B,
    I do have some corrosion on the bus bars and spent some time last night looking for ways to clean them up...........
    I have checked the voltages on the removed battery units and they seem okay - the voltages on all the units seemed okay - although I did not load test them
    I shall remove the battery again and have a good clean up of all the connections on both sides of the units
    planning to use vinegar and fine sand paper - is that okay
    the car is an ex uber from London so I assume that it has had lenty of moisture in the back - there was some sign of corrosion around under the seat
    I shall re-approach the problem with renewed optimism
    Dylan
    #4 DylanWinter, Mar 19, 2024
  5. Brian1954
    2,694
    1,077
    The corrosion on the bus bars is probably not the problem. Look at the votage sensor wire connector at the battery ECU.
  6. DylanWinter
    Suffolk
    with joy in my heart and spent the morning diligently cleaning the bus bars and contacts on both sides of the battery until they shone like burnished gold
    the good news is that the skid light warning has now gone out
    the long term battery longevity test said that the battery registers 59 per cent - which is better than yesterday when it said it was 46 er cent.
    however, Dr Prius is still throwing weird stuff from blocks 2 and 3 -
    I have lots of codes from the battery test
    the lovely woman said that my battery needs attention
    and offers me several codes - enunciated at the end of the film
    P0A0D
    P3000
    P0a84
    P0aFA
    resistance is fine
    loadtesting bottom voltage block 3
    should I scrap the car and a Ford Focus
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    As mentioned, you have some kind of problem with the voltage sense circuits that go from the battery blocks to the battery ecu.
    It could be broken wires at the ring terminals at the battery studs. However, it is more common to have corrosion damage at the orange connector in the ecu.
    Repair usually involves replacing the harness and ecu (a good used ecu is fine).
    Brian1954 likes this.
  8. Brian1954
    2,694
    1,077
  9. DylanWinter
    Suffolk
    I have just spent the past two or three weeks attempting and failing to solve a battery problem on my 135,000 mile old Gen 2 Prius. I bought it four years ago for about £3,500 when it had 95,000 miles on the clock. The annual service has been about £300... plus a 12 volt battery... brakes and steering... tyres etc. Not too bad. The local garage said that they would look after the mechanics but anything electrical is down to me.
    It has been turning in a rock solid 62mpg (UK gallons). About 18 months ago the red triangle appeared - then followed by the two brake warning lights - but the car drove as well as ever.
    I did the paper clip trick and disconnecting the battery to clear the lights but they soon came back. Then about three weeks ago the mpg went down to 50mg, the engine was on all the time and the little arrows on the energy monitor kept flashing green and orange - clearly the battery was no longer pulling its weight. The battery level was close to the green - but still blue.
    So I bought a wireless scanner and downloaded Dr Prius
    That told me that there were two dodgy blocks - blocks 2 and 3. So I bought four ebay battery packs at £22 each - took out the battery - installed the replacement blocks - checked the voltages of each battery and they all seemed fine - as were the voltges on the four cells I had removed. An ominous sign.
    There were signs - bits of sharpie across bolts and battery blocks that suggested that I was not the first person to delve into the battery. It had caused problems in the past... before the 95,000 miles
    I was surprised at the amount of corrosion on the bus bars - I cleaned them up a bit - but thought it best to leave them well alone
    I redid the 150 odd bolts and nuts to replace the battery - turned on the car
    same problem.
    I started a thread on here
    Gen 2 ... Dr Prius says two blocks bad | PriusChat
    there are a couple of films of Dr Prius. You can seen that it was throwing a lot of faults at me.
    I removed the battery again - and as per instruction on web I polished all the bus bars and put them back. I used vinegar and sandpaper. This was a first for me attempting to repair anything with vinegar. It felt a bit silly.
    Re-intalled the battery - same problem
    Dr Prius was also reporting faults on every module - and weirdly double reporting more faults on modules 2 and 3.
    Then following a suggestion from Bryan I took out the battery cleaned up the BMS cables and saw that there was some corrosion on the 14 pin socket to the BMS.
    (I trained as an ag engineer 45 years ago and have owned a string of diesel cars over the years. I have done some serious engine repairs on tractors and small vans, I build ebikes so I am not a numpty but this was my first experience with Hyrbrid batteries - this has not been a good experience as I was losing at every turn.
    I spent a lot of time on forums and watched lots of really annoying videos on youtube - emntioning no names but some of them are way too fond of their own voices.
    I cleaned up the connections re-assembled the battery and suddenly it started to run really hot - 178 f. Red lights all over Dr Prius.
    I was worried that the car was going to catch fire so I removed the battery quickly and set it on the drive - it stayed hot for about an hour. There was some swelling of the cells. Then it cooled down and the cells went back to their proper shape.
    I put the battery back in and fired up the car. Same faults again - as expected. But no overheating. I have since driven it for an hour and no repeat of the overheating.
    Dr Prius threw up so many fault codes it made my head spin. Some I could not find on the web.... or said could be the fan, could be the BMS , could be the Control unit module.... it also said that I had problems in every cell. Details on the other thread. Dr Prius just kept telling me that my battery needed attention - duh!
    I found one local repair man who said he would have a look at it - but warned me that it would be expensive. He was basically telling me that he could fix it - but it would probably not be worth it and he needed to keep the car for two weeks!
    The local Toyota dealer wanted to replace the battery with a new one and replace the BMS and the control unit. The bill would be more than the car would ever be worth.
    There are some second hand batteries on ebay at about £500 a pop - the nearest is a three hour drive away in Nottingham - the bloke wants cash... it would have a one year gauarantee but he wanted to add £200 for fitting it and there might be more costs on top.
    but I still do not know if that would solve the problem. I have never heard the cooling fan go on - It was clean - no clogging .The fan runs when connected to 12 volts but I have no real way of testing the sensors it as the battery does not seem to get hot enough to fire it up - is it the temperature sensors, is it the main computer? I still do not know and am no closer to finding out how to find out.
    I was now five days into this - and still no solution. The car still runs - but the battery is still not helping. The battery temperature is about the same as the interior of the car - peaking at 20c. No red warnings on Dr Prius. Not a peep from the fan but it would only be blowing cabin air through the battery anyway.
    We only run one car so it needs to be fairly reliable.
    On the bright side I am now getting really good at fitting and removing the battery and upholstery - three fittings so far.
    However, I still do not know what the problem is and am worried about throwing good money after bad.
    The car has been really comfortable and fairly reliable. Certainly quite economical.
    For me the big downside is that the corrosion inside the battery is alarming. I do live near to the coast in the wet UK and the car is kept outside. I have had a slight leak on the back quarter gutter - which I sealed up and the 12 volt battery box often fills with water. All common Prius faults I now see from the web. These are pretty bad faults for a car in a wet climate.
    As an aside I am a sailor and was thinking of converting my small yacht to electric but the thought of a BMS with its tiny wires and many, many connections in a marine environment is not encouraging. I fear that I will stick with the 25 year old smelly diesel inboard for a bit longer.
    Dr Prius and fault codes seem all very well and initially make you feel rather powerful...but less than specific about what is going wrong. Some of the fault codes are weirdly vague when I look them up on the web.
    There is a Gen 3 Prius for sale at £4,000 some 50 miles away - it has 100,000 miles on it but I do not really trust the batteries or the ability of Dr Prius to identify much of any value or of Toyota to produce a waterproof Prius.
    As a scrapper the old Prius is worth about £400. It still runs without the help of the battery ... but I do not know how much longer it will do so.
    I will not sell the car yet - but we will be buying an 80,000 mile old Diesel VW Polo for £2,500 - they are slower, noisier, less comfortable, more economical and it is easy to find a local garage who are willing to repair it.
    I will not yet scap the Gen 2 Prius and would still like to get it going properly as the mechanics seem fine - the battery and associated computers are the problem
    But I will not be buying another Prius even if I get this one going as I am not sure that they are all that good in a damp environment and the battery on this one has obviously gone wonky twice in 135,000 miles.
    I am open to suggestions - a neighbour who was a tank mechanic said he would help me have another go at it so I am still oen to suggestions or shared experiences.
    Please don't flame me as I am rather foolishly using my real name on here.
  10. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    We get pretty wet here in North Carolina USA heavy rains for days and days at a time We also have part of our state on the ocean I'm not down there that much I'm more in the middle of the state water leaks affect us here also there are plugs made of rubber underneath the 12 volt battery that probably has never been pushed through this will allow water to pass through the tray and in the winter it won't build up and freeze. There's also a plug under the spare tire the one that's right behind the HV battery if you push that out is another place for water to escape and not build up in the car and create the terrarium effect in the summer makes everything a wet mess over on the other side under the tool compartment where the battery would be on the other side of the car there are some plugs over there that can be pushed out so that if the hat seal or anything leaks water will pass through the chassis rather than sit somewhere and freeze in the winter or release lots of humidity in the summer every time I get another Prius I have to make sure these plugs are situated this way so that water will pass through We have four generation twos they are great cars once you get your battery sorted You should be back to what you had before other than your battery and the brake actuator and the CM monitor display those are about the only things that really go on with this model Don't even think about a generation 3 you don't like this model the two you certainly won't be happy dealing with the mechanicals on the generation 3 when they come due and it's a lot cheaper interior truly is You live with it for a while and you'll find out the hard way no fun and you think you got parts problems with the generation too every generation 3 you find has the same issues interior trim things like that falling apart You have no choice but to get new and it's expensive.
  11. bisco
    52,895
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    No, this is actually more likely to indicate it's a virgin battery.
    Where exactly are you doing all this work? A battery can't just suddenly get 178F....Was it installed and you were driving? Then you just snatch it out and toss it on the driveway to cooldown? None of this makes any sense. I'm curious as to how you saw swelling of the modules. Did you not have the cover installed?
  13. TNToy
    TNToy Member
    70
    42
    Memphis TN
    Sadly, the only way to go about the repair you were attempting is to load-test and charge/restore each cell one by one with a balance charger, and then reassemble and load balance.
    A very very failed battery blade / cell will liekly have the same voltage as the rest of the pack… but zero ability to maintain it. It’s how many miliiamps it takes to charge and discharge the cells that you need to test for. Not how many volts it had in a resting state upon disassembly.
    It requires either several days of testing and charging and replacing each of the 28 cells, or the fitting of a replacement battery pack with a warranty of some kind. In your case, the latter sounds more suitable.
  14. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    A very very failed battery blade/module ... each of the 28 modules,
    Modules are sealed units that contain 6 cells in series that cannot be accessed. It can get quite confusing, in some instances, when a post uses cells instead of modules so it is good to be clear what is being talked about.
  15. DylanWinter
    Suffolk
    there was a tiny amount of corrosion on three pins to the BMU down in the same corner as shown in the osts linked above
    I cleaned those up - re-instaled and then the battery started overheating
    I removed it again and it stayed hot for about an hour and then cooled down
    I re-installed it all ran the car and it was back to the first state - bttery not performing but not overheating either
    I see that a second hand BMU is around £65
    there are lots on sale on ebay
    that maybe worth a punt
    Dylan
  16. DylanWinter
    Suffolk
    the ebay seller says that they are for gen 2 and gen 3 Prius
    is it the same unit in both cars?
  17. dolj
    dolj Senior Member
    8,655
    4,406
    I'd be very surprised if was.
    The EU Gen 2 part number is 89890-47092 whereas
    the EU Gen 3 part number is 89892-47020.
    You should replace the No. 2 Frame Wire - part number 82165-47040. It is likely corrosion has wicked up one or more of the sense wires and is causing integrity issues. This is the most common cause of the problem you are seeing with voltages that don't make sense.
    #17 dolj, Mar 23, 2024
  18. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    That part is $73.11 from Olathe Toyota here in the US in Kansas. might be worth shipping to UK
  19. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    Sorry for your frustration. These cars can be very good or an absolute nightmare. My advise is to borrow a known good traction battery and see what happens. If all is good, visit the bloke in Nottingham and have him do the swap, or maybe do it yourself in the driveway. Not sure what happened with your batt, but as is with many tasks the learning curve is steep and painful. I am a retired engineer with considerable experience in electrical stuff but pay for rebuilt batts on our cars. They come out, do the swap in the driveway and the bill is about 600 bucks. Never had a problem with one. New batteries from toyota are under 2K USD now and many are going that route. Personally I never keep a car more than 3-4 years as they get boring so rebuilt is the best option.
    On the gen3, hard pass. They have their own issues. On the oil burner up to you. You are probably more comfortable with them doing repairs.
  20. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    I hear you on the frustration and to be honest I would have caved after I found the swollen modules. I'm a buy once cry once kind of guy and I love my 2008 Gen 2 with 140K miles. If you need and want to keep this car and have it be reliable once more. I would buy a brand new battery from the Toyota Dealership or a Project Lithium battery and install it with a brand new No. 2 Wire Harness and clean up your old bus bars with vinegar and sandpaper or a rock tumbler. Be sure to torque the nuts down to specs..(8 INCH Pounds IIRC) As long as your other wires in the trunk are clean and free of corrosion you should be good for another 10 years. Even if you do this the value of this work can be recouped when you sell it.
    This could be costly but after owning a P38 Gen 2 Range Rover I learned how to spend money once and have my problem solved.
    Just my 2 pence mate...but my free time to work on cars has been less and less and I grow older.
