GEN II Prius P3030 & P0A1F
Discussion in 'Gen 2 Prius Technical Discussion' started by Tabi, Dec 27, 2019.
  1. Tabi
    Tabi New Member
    Honolulu
    Hello! First time poster, first Prius owner and car-owner. Just bought this car about a month ago.
    I scanned my 2006 Prius Hybrid today after a bunch of things happened all at once:
    Prius would only go into PARK and NEUTRAL, but not drive or reverse.
    Got the red triangle of death, tire pressure (which had always been there), TRAC OFF, ABS, CEL, and another one that’s a circle with a ! in it. All lights are orange and unblinking except for the tire pressure, which blinks, and the red triangle of death. The car makes no funny noises, but the AC also stopped blowing cold air the same time all these lights popped up.
    Because I’m car dumb, I got my uncle to help read the codes: P3030 & P0A1F. I contacted a repair service which specializes in hybrids but I’m wondering if there’s anything that I can do before dropping hundreds or maybe even thousands on a car that I just bought.
    Thanks for any advice!!
    52,914
    welcome!
    test your 12v to make sure you're getting the correct codes
  3. Tabi
    Tabi New Member
    Honolulu
    Thank you! Alright, will do. I did the system check with the display and it said 11.8V. Might I need to get a new one?
    52,914
    it is definitely borderline. any idea how old it is?
  5. dolj
    dolj Senior Member
    8,657
    4,407
    Wellington, New Zealand
    I agree with bisco that this is not a great voltage, but I wouldn't rush out to buy a new battery in the hope it will fix everything. But for sure, put that battery on a charger and monitor whether it can hold the voltage in the upper 12 V range.
    The codes you quoted in your first post point to problems in the HV battery, might not be serious, but needs to be looked into. FWIW, the state of your 12 V battery has not much to do with these codes.
  6. Tabi
    Tabi New Member
    Honolulu
    Yeah, I was hoping it’d be the 12v, but at least I know what it is. I’m guessing I shouldn’t rush into buying a brand new HV battery either and should just take it into a hybrid repair shop then?
    Thanks for the help!
  7. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Welcome to PriusChat!!
    Our advanced search feature is working, and with a little time and reading you (or anyone) will likely find an answer to any question.
    Would've thought a failed Inverter coolant pump, but you didn't report DTC P0A93. You could easily check and confirm though.
    Given your locale and the above DTCs it could be a condensation and corrosion problem.
    You will need to access the HV battery, then find the ECU on the drivers side (picture below) and inspect the connector and pins.
    You might find it looks something like this : Gen II codes P01AF P3030 P3056 | Page 2 | PriusChat
    Please report back to this thread with what you see/find.
    Raytheeagle likes this.
  8. Tabi
    Tabi New Member
    Honolulu
    Damn! This all just suddenly happened after a huge storm. I left the car out in street parking. Maybe it is condensation then? Right now, I’m a little scared to open up the HV and check things out since this is my very first car, but I’ll definitely read around here and do tons of research.
    Thanks!
    SFO likes this.
