Gen3 modes: Ready, Limp, Maintenance, etc.
Discussion in 'Gen 3 Prius Main Forum' started by rjh427, Oct 19, 2022.
  1. rjh427
    rjh427 Junior Member
    39
    Earth
    I've heard of "Ready" mode, that's fairly self-explanatory.
    I've heard of "Limp" mode, that's where things are wrong and the car limits itself to about 25 mph.
    I've also heard of "Maintenance" and "Invalid" modes, are these synonyms or are they two different modes? If the latter, what is the difference? I.e., what type of operations require entering one versus the other?
    Are there any other modes and if yes, what are they and what are they for?
  2. Mendel Leisk
    42,365
    Chap just summed up the degrees of on-ness eariler today. IIRC, they're:
    AUX (one push of start button): just the radio woke up
    ON (two pushes of start button): mostly woke up, except no engine running
    READY (one push of start button, with foot on brake): engine starts/stops, typical driving condition
    There's several "maintenance" modes. For various, pretty esoteric maintenance requirements. For example, keeping the engine running constantly, after coolant change. "Invalid" mode is for doing some brake work, brake fluid replacement mainly.
    Tronald and bisco like this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,126
    6,981
    Texas Hill Country
    Maintenance Mode
    Continuously Idle Engine
    Press Start button 2 times
    Press Gas Pedal 2 times
    Press brake and shift to Neutral
    Press Park
    Press Gas Pedal 2 times (hybrid warning light will start flashing)
    Press Brake and Start button (starts engine, don't drive it, shutdown to return to normal)
    Invalid Mode
    Useful for normal brake flush without Techstream Scanner
    Press Parking Brake
    Press Start Button twice
    Press Brake Pedal and shift into Neutral
    Press Brake x8 in 5 secs
    Press Park
    Press Brake x8 in 5 secs and release
    Press Brake pedal and shift to Neutral
    Press Park (Blinking brake light)
    You are in Invalid Mode
    Bleed rear brakes by holding pedal down
    Bleed front brakes by pumping brakes
    Power down to exit invalid mode
    Consider using charger on 12v battery during process
    Brian1954, Foxglove and Mendel Leisk like this.
  4. rjh427
    39
    Earth
    Thank you.
    Of course they want the different modes to be complicated enough that they are not entered into accidentally, but for Invalid mode, wow. Even Einstein's theories on general and special relativity seem easier than that. @@
  5. Mendel Leisk
    42,365
    There’s a couple of specific gotchas:
    1. when shifting out of park, you need to depress brake pedal. You do this normally, but perhaps without thinking. Repair Manual description of the modes does not note this. (@rjparker does note it, in his post.)
    2. Invalid Mode requires car to have parking brake applied. It’s mentioned at the outset of Repair Manual description, but not noted/stressed.
  6. ChapmanF
    19,045
    It's good to be clear this isn't a complete bleed procedure. It works if you are simply flushing fluid (new fluid in, old fluid out, no air). It also works if there is only air down at the wheel ends of the lines, as when you've just replaced a caliper, say.
    If there's any air that got into the head-end units, you need the actual bleed procedure invoked with Techstream to work all of those valves and get all the air out. Invalid Mode keeps the brake ECU from yelling at you while you mess with the brakes, but it doesn't do the active stuff a full brake bleed needs.
    Bill Norton likes this.
  7. rjh427
    39
    Earth
    Again with Techstream. I'm not going to buy a new computer - and more software on top of that - for a one-time thing. Labor to pay someone who already has Techstream is on par with that computer+software expense. There's got to be a workaround.
  8. rjparker
    11,126
    6,981
    Texas Hill Country
    Primarily need Techstream for a brake booster (master cylinder and or brake pump) replacement. Invalid mode is not some kind of hack, it is a Toyota recommended normal brake flush procedure.
    There are aftermarket scanners that can do the more involved brake booster replacement flush and calibration. XTool is one and they offer a bluetooth version that uses your phone or tablet. Plus it is good for other manufacturer's vehicles besides Toyota. However most of the advanced diyers here use the hacked Techstream software for a PC along with a specific hardwired interface. Illegal but cheap.
  9. rjh427
    39
    Earth
    Okay, I'll ask this Q: will Techstream run - and work - in a virtual machine under say, VMWare or VirtualBox, that is running on a Linux laptop?
    Otherwise, I guess I need to drill down on those 3rd part scantools that grok Prius brakes. XTool did you say? I'll look. Anyone know of any others?
  10. Mendel Leisk
    42,365
    I think the usual ploy with Techstream is to get a clunker laptop, if that's possible. It used to work better with an older Windows OS, say Win95, though that may not be a factor now?
  11. ChapmanF
    19,045
    Yes, exactly: it is a Toyota recommended normal brake flush procedure, and flush is what you're doing when new fluid goes in, old fluid comes out, and no air is there. Invalid mode works for that, and is fully documented for that purpose in the manual.
    It also works when the only air is way down at the wheel ends of the lines. You can get away with it then too.
    What it does not work for is when there's air in the head-end components, and it doesn't appear in the manual for that purpose.
    When you need the procedure for bleeding air out of those components, you don't necessarily need Techstream. Techstream is not what knows the procedure; the procedure is baked into the brake ECU. You just need any scan tool able to send the brake ECU the command to do it. Techstream can do that, of course, but isn't the only option.
    This thread comparing other OBD-II tools and their capabilities can give you some ideas. It's in the Gen 2 forum because mr_guy_mann has been testing on Gen 2s specifically, but the most promising products there are probably also promising for Gen 3.
  12. rjparker
    11,126
    6,981
    Texas Hill Country
    Several have reported no success with vms. Part of the Techstream hack version is some registry modifications to make it work. Most people have done it with xp or win7 running xp mode.
    Buying a used brake booster can be tricky as there are different versions by tire size, Prius model and year. When you buy a new set you will get the right parts based on your vin.
  13. Elektroingenieur
    2,515
    3,288
    Three Touring
    This worked for me and still does—but I used software directly from Toyota and Drew Technologies, which I realize may not fit every budget.
    The current, supported products are fully compatible with 64-bit Windows operating systems.
    I don’t know what one might expect with unofficial copies of the Techstream software, nor with the device drivers or J2534 pass-through libraries for inexpensive vehicle interface modules, whose sellers, having copied the software that came with whatever device they cloned, may lack the ability to update it.
