Gen4 EGR fate?
Discussion in 'Gen 4 Prius Technical Discussion' started by rosencrantz, Nov 2, 2018.
  1. Mendel Leisk
    42,293
    They're plain steel (gaskets 2 and 3 in illustration above), pretty sure. I think it's just Toyota being a little over-the-top on those.
    Even with the compressible ones I've been cavalier: I've had the intake manifold off twice, the throttle body maybe three times, never replaced any gaskets. I'd think age/miles is a factor. Obviously replacing all is the rolls royce for safety.
    Yeah, 4th gen owners, especially those with miles going up: do yourself a favour and have a look at that pipe.
    knockknock_2 likes this.
  2. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    In all honesty, I too have only replaced gaskets or seals when I deemed it necessary. Such as ones that I have damaged taking off or that were leaking before or ones that would need a lot of disassembly to replace at a later stage. So common sense prevails in this throw away society.;)
    alanclarkeau and knockknock_2 like this.
  3. Mendel Leisk
    42,293
    I took the EGR valve off a Civic a while back. It had a metal gasket, but it had a coating, which half stayed with the gasket, and half stuck to the engine. That was obviously knackered and I replaced. But plain steel gasket, no nicks/bends, looks like new?
    Again, even the flexible plastic O-ring style gasket at the intake manifold end, I didn't replace. If it looked seriously compressed/stressed I would.
    This is all subterfuge by fourth gen owners though: someone's got to have a look at that pipe, report, lol.
  4. qettyz
    qettyz Active Member
    181
    208
    Finland
    This is not good news that inverter has to be removed to gain access to EGR valve. Sounds much more difficult job than Gen 3.
  5. Mendel Leisk
    42,293
    Yeah, looking at engine bay pics, it looks pretty packed. (n)
    alanclarkeau likes this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Don’t forget it’s the non-diy mechanic performing the task and getting paid to do so ;).
    As an example, I did the first egr cooler swap on our 2010 WITHOUT removing the windshield wiper cowling :eek:.
    But until someone actually does it and gives us info, it’s all supposition (y).
  7. Mendel Leisk
    42,293
    We wait...
    One sand-pounder: Toyota seems to have abandoned the print Repair Manual, and it's pdf iteration. Maybe someone with a subscription can download/post the relevant online sections, see what it says.
    That said, Toyota seems to have a "you need to remove your pants to pee" attitude. The 3rd gen repair manual oil change instruction for example, says to remove the full engine underpanel (which I readily do) AND the panel ahead of it.
    So yeah, maybe it'll take a few DIY forays to know for sure.
    #27 Mendel Leisk, Mar 4, 2019
  8. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    I'm a bit skeptical too that the Inverter needs to be removed.
    Looking at the engine pic here :
    Gen4 EGR fate? | PriusChat
    It looks like the EGR *should* be relatively easy to get to.
    However, that is just a picture of the engine itself. It is probably a far different scenario when viewed in the engine bay. (y) Even though they *did* shrink some of the components, they also slammed the 12V battery in the engine bay..so maybe overall less 'room to work'?
  9. Mendel Leisk
    42,293
    Not in that picture (which I'm guilty of posting) is the very nearby inverter. Google 4th Gen Prius engine bay pics, and you'll see it's pretty crowded.
  10. farmecologist
    1,960
    1,801
    Southern MN
    Yep..it does look very crowded. Looks like fact that they squeezed in the 12V battery is certainly a culprit.
  11. qettyz
    181
    208
    Finland
    Quite nice view of EGR system on this another great WeberAuto video of EV cooling system.
    Starts around 4:20 from side view to engine bay view where it can be seen that accessing those can be difficult for sure.
    FFD55004-0A14-467C-8732-B10FCEFA071D.png 5BA8DE22-64F0-426E-9F2D-A487D43A8C82.png
    5:25 for closeup of egr valve and egr cooler on engine bay.
  12. Mendel Leisk
    42,293
    Good video, and access to the EGR pipe actually looks easy. For the entire system, maybe not so much, without inverter removal? Still I'd bet it could be done.
    It's larger diameter than third gen? That might be telling. I think the cooler too has an significant increase in cross-sectional area.
    farmecologist likes this.
  13. farmecologist
    1,960
    1,801
    Southern MN
    After studying the video, I dare say that the *location* of the EGR cooler is in a better place than the Gen3. Looks like no need to remove the cowling on the Gen4? You may be right though..given the proximity of the inverter, there may not be enough clearance to get at the bolts and such without doing something with the inverter.
  14. Mendel Leisk
    42,293
    Do we dare to think spark plugs could be removed without cowl removal too?
  15. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Toyota Gen4 publicity said:
