Getting a issue in prius 2016
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Shahrukh hassan, Oct 14, 2024.
  1. Shahrukh hassan
    Shahrukh hassan New Member
    Manchester
    ----UK----
    I have been using a toyota prius 2016 model for
    One month everything is fine but now I encounter a problem and I don’t have idea what to do the problem is this
    From last three days my car giving orange engine check light which only last for 15 mints in the morning when i start my car and then light disappear and whole day light will not shown but when i park my car in the night and start in the morning the engine check light come and after 20 to 25 mints light disappeared and nothing wrong with vehicle i got scanned it says water pump b circuit open the mechanic is saying change the water pump which cost me 400 pound but light only appear in first start in the morning then disappear even i ran my car 80 miles nothing wrong what should i do mow
    From last three days same pattern in the morning first start light come after 20 mints light disappear and then whole day no light then in the next day in the morning light again came and again disappeared the error code is this
    P261A13 water pump b circuit open
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It may be the automatic reminder to bring your Prius in for service. It first lights up 4500 miles after a reset and will then stay on at 5000 miles after a reset.
    JeffD
    52,904
    see post #2
    p261a13-p261a14-what-to-do.210686
    Brian1954 likes this.
  4. BiomedO1
    BiomedO1 Senior Member
    4,639
    2,434
    Left Coast
    You need to read the operators manual for your car. There are some things you can ignore and others that you cannot! You need to figure out which one that warning light is - otherwise it may cost you much more that $400 pounds.:sleep::whistle:(n) You can blow up your motor and will be back to riding the bus...
