Has Anyone Installed a Dash Cam?
Discussion in 'Prime Accessories and Modifications' started by geguia, Jan 26, 2017.
  1. pkmntrainerharry
    pkmntrainerharry New Member
    17
    17
    DFW
    Has anyone hardwired a dash cam to the OBD? What battery does that run off of? If it runs off the main battery (not the 12V) wouldn't there be enough power to keep the camera running 24/7? Trying to decide if I should get a dash cam with parking mode or just keep it running constantly.
  2. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    Here is my installation of the Black Box purchased from Amazon (with GPS Antenna)
    The power is via an included 12-foot cable with standard automobile power plug. I have it routed around the left side of the windshield to the aux power port on the rear of the console.
  3. William Redoubt
    1,228
    1,174
    I doubt the camera draw will deplete the 12v if the car is driven daily.
  4. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    that's a bad Idea, I know first hand. I bought two Anker 26 amp hour USB batteries and hooked up my two Wheel Witness Dash Cams. One battery hooked to both dash cams lasted 12 hours, after 12 hours I swapped out the battery with a freshly charged battery and charged the depleted one and repeated the process. After about a month of doing this the heat inside the car damaged the front dash cam the rear one was covered by the hatch so no damage to that one. I have since abandoned the 24/7 scenario. I ended up buying a new dash cam to replace the damaged one since warranty coverage does not cover heat damage.
  5. pkmntrainerharry
    17
    17
    DFW
    Thanks for sharing your experience! It seems that the Wheel Witness Dash Cam has a battery and not a capacitor, and I read that battery dash cams aren't as heat-resistant as capacitor dash cams. Do you think A119 (which has a capacitor) would still run into the heat problem?
    You're right; unfortunately I don't drive consistently on weekends. Which is why I was hoping to find out whether the OBD is powered by the accessory 12V or the hybrid battery :confused:
  6. priuscatprimeguy
    2,730
    2,640
    Sorry can't help you there, the only experience I have is with Wheel Witness Dash Cams.:cry:
  7. priuscatprimeguy
    2,730
    2,640
    I just purchased 2 A119 with GPS on Ebay for $69.95 each, thanks for the tip:D
    pkmntrainerharry likes this.
  8. priuscatprimeguy
    2,730
    2,640
    Maybe this software will work with the A119
    #28 priuscatprimeguy, Jun 17, 2017
  9. Phildgreat
    Phildgreat Member
    73
    44
    Los Angeles
    Has anyone installed a dash cam on the front window with window tints on it? I'm concerned about the pressure applied to the tint and how it'll impact the tint in the long run. I've been looking and dash cams that sits on top of the rear view mirror as an alternative but they don't see as popular or as high quality as the ones you apply on the front windshield.
  10. Elektroingenieur
    2,515
    3,288
    Three Touring
    If you’re referring to pin 16 (BAT) of the Data Link Connector 3, according to the Electrical Wiring Diagram (EM32D0U, available by subscription to techinfo.toyota.com), it’s supplied from the 7.5 ampere OBD fuse in the Instrument Panel Junction Block Assembly, which receives unswitched power from the 12-volt (auxiliary) battery, via the 60 ampere JB-AM fusible link.
    kaynin likes this.
  11. priuscatprimeguy
    2,730
    2,640
  12. priuscatprimeguy
    2,730
    2,640
    My new A119's front and rear (only front shown here.) Got the new Dash Cam Viewer software because Registrar Viewer won't display GPS from the A119
    #32 priuscatprimeguy, Jun 22, 2017
    Mark57 likes this.
  13. James2012
    James2012 Junior Member
    24
    Chino
    Hello everyone... I just purchased an Anker Roav C1. The prior posts are pretty helpful in terms of routing the cable.
    However, has anyone thought about attaching the dash cam directly to the center plastic housing for the sensor instead of the windshield? I figured that it would keep the dash cam centered and protect it from direct heat.
    Other option would have been to attach it onto the top of the windshield where the tiny dots are and low enough that the camera view is obviously not obstructed by the dots.
  14. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I've often wondered if it would be possible or prudent to mount the camera "over the shoulder" rather than to the windshield. My thought would be to mount it to the headrest bar so it is centered in the car. This way, even the dashboard is being recorded. You say I didn't stop at the sign but my speedo reads "0".
    What do you all think? Is this possible and/or plausible?
  15. priuscatprimeguy
    2,730
    2,640
    my dashcam has GPS so........it shows the speed I'm going
    HPrimeAdvanced likes this.
  16. fuzzy1
    10,707
    I believe that the jury watching the video view through the windshield can see for themselves that the car-camera unit came to a stop.
    priuscatprimeguy likes this.
  17. bwilson4web
    16,535
    I tried it but with poor results. I am getting higher quality mounted on bottom of visor using bungee cords. Then I can flip it up so it is not visible to parking lot thieves.
    I’ve ordered a part to put dual USB ports in passenger vanity light.
  18. Flaming
    Flaming Active Member
    138
    123
    QC , Canada
    Technology
    im using a Falcon Zero F170+ dash cam , it's mounted behind the rear-view mirror so i dont have it in my face ... i purchased an Armortek mirror mount to achieve this : Dash Cam Mirror Mount – Fits Falcon F170HD,Rexing V1, Z-Edge, Old Shark, YI, Amebay,KDLINKS X1,VANTRUE and Most Other Dash Cameras | AmorTek | Tech for Love
    the dash cam is powered from the rear 12V plug , no wire visible anywhere. The dash cam is very close from the windshield , just low enough so it dont block the sensor behind the rear-view mirror .. the only downside is we can see a bit of the black plastic from the factory Toyota camera system in the field of view of my dash cam but no big deal. I like it that way.
  19. geguia
    geguia Active Member
    210
    108
    los angeles
    hey guys which fuse pins do i need to hardwire the power to?
    also where is the fuse puller? i found the fuses. so conveniently placed under the steering wheel
  20. Elektroingenieur
    2,515
    3,288
    Three Touring
    I’ve discussed this previously for the liftback Prius, but the information should also apply to the Prius Prime. You may also need IG or ACC switched power, and the EWD shows where to get it.
    On the bottom of the lid for the fuse box in the engine compartment (Owner’s Manual, page 631).
    kenmce and geguia like this.
