Tags:
  1. BlueMagnet
    BlueMagnet Junior Member
    46
    San Bruno, California
    2023 Prius Prime
    SE
    Just purchased my blue prius prime today. Drove into my garage and hatch hits the garage door. I've read of suggestions on using a bungee cord or tying a rope - I can't find any places to hook a cord or tie a rope in the
    trunk area. Any suggestions? I don't want to change the struts and backing in is not an option since there is
    an incline to my garage.
    priuscatprimeguy likes this.
    49,399
    congrats and welcome!
    someone mentioned that the hatch has adjustable height.
  3. alpilotx
    alpilotx New Member
    Germany
  4. BlueMagnet
    46
    2023 Prius Prime
    SE
    Has anyone made this adjustment with the hatch? I looked at my struts and the first plug that is
    anchoring the struts look different from the other 2 on the side of the hatch. My work around for
    now is to just throw a towel on the spoiler edge so it doesn't get scratched when it hits the garage door.
  5. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    That's because you supposedly move the actual strut anchor to one of the other two positions. Try prying out one of the plugs to see if the hole is threaded.
  6. bisco
    49,399
    i glued a piece of foam to the inside of my garage door.
  7. MikeDee
    MikeDee Senior Member
    1,550
    590
    San Francisco Bay Area
    I think the plugs screw out because they have torx heads, but they look like they're made of plastic. Hard to say if Toyota meant these to be true attachment points though. Maybe the repair manual would say.
  8. xliderider
    7,869
    3,116
    Honolulu, HI
    It doesn't matter if the plugs are plastic, it's whether the threading underneath it is solid metal, or some other material like plastic, or carbon fiber, etc.
    If it's meant to be an attachment point, it would have to be a threaded metal insert like where the original attachment point is mounted.
  9. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Using a Torx driver, I unscrewed the other two bolts. They have metal inserts and look suitable for lowering the hatch. I couldn't loosen the arm of the support without excessive force but I'm sure once I do these other points were made to adjust the hatch.
    alpilotx, Lee Jay and bisco like this.
  10. alpilotx
    alpilotx New Member
    Germany
    Please keep me / us updated on whether or not changing the position the two supports is working (as this information has quite some relevance to me).
    Thanks!
