hatchback shocks
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pholife, Jan 29, 2013.
  1. pholife
    pholife Junior Member
    57
    hb
    Has anybody experience that is hard to life up and open?
    is the shocks going bad?
    2012 Prius 3 with 13k miles.
    thank you in earnest.
  2. El Dobro
    El Dobro A Member
    7,102
    3,282
    Sounds like the struts are going. Take it back to the dealer since it should be covered by the warranty.
  3. Mendel Leisk
    42,239
    Most of these folks: Hatch Shocks Stiff, Easy Fix? | PriusChat
    I'm in that boat. Tried a very sparing amount of silicon lube, didn't make much difference. They go about halfway up, then need a nudge to go the rest of the way, seems like they have a "half-life" of just a few years.
    Hmm, maybe they're middle aged, LOL.
  4. pholife
    57
    hb
    thanks....when I go into service I will notify service rep about my problem!
    again thanks
  5. jayrider
    jayrider Member
    163
    17
    southwest illinois
    Just had my rear struts replaced [2 years old] under warranty and what a difference. You can buy them at most auto parts stores if you are out of warranty. Easy to replace.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    When it gets colder, my struts do not lift. I have had many dings on my forehead to prove it. :)
    In the summer, no problem.
  7. Den49
    Den49 Member
    498
    272
    Maryland
    The STRONGARM 4686 lift supports I installed last March are working fine in all weather. An easy fix if you are out of warranty. Details in below link:
    Aftermarket Hatch Struts | PriusChat
  8. jayrider
    jayrider Member
    163
    17
    southwest illinois
    Good hatch lifts work fine in cold weather. If they don't, they should be replaced. My wife needed staples in her scalp to close the gash when it fell on her head.
  9. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    I'd rather have stiff shocks than one that doesn't stay up
  10. Spindifferent
    Spindifferent Member
    155
    79
    Central Texas
    Just had both stay assemblies replaced under warranty on my 2010. Hatchback would not open fully on its own, even in warm weather. Only have 700 miles left on the warranty.
    New stays are much better! Press the button, give it a little lift, and the hatchback rises on its own.
    - Spindifferent
