Head Gasket - Good shops in the Minneapolis Area?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by climb.on, Apr 20, 2018.
  1. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    ALso, I just completed the intake manifold procedure and posted some pics that might be useful :
    Hi all, new Prius v owner | Page 3 | PriusChat
    The video will be far more useful though! :D
  2. climb.on
    climb.on Junior Member
    30
    MN
    Three Touring
    Thanks man. Just what I needed. Cheers.
  3. climb.on
    30
    MN
    Three Touring
    I watched the video, which is great, but it's really good to see another perspective too. Thanks much!
  4. 04priusnow
    04priusnow Active Member
    345
    201
    for the exhaust smell.. check the catch can hose. mine were off gassing like crazy.. car emitted a gas/exhaust smell once warmed up..
    PH-1 ?
  5. Joele3
    Joele3 Active Member
    135
    201
    Bay Area
    I did notice the hose attached to the PCV valve was leaking oil or something, was all wet underneath. I'm just too lazy to take off all hoses, clamps, intake tube and re run the hose. I was getting inpatient at the time. With all the different diameter size fittings.
  6. climb.on
    30
    MN
    Three Touring
    Just wanted to update...stop leak has maybe helped a little. We don't have the shudder anymore, but it not winter anymore either. Not sure if that's a big factor or not. It's still losing antifreeze though and there is still some sort of exhaust manifold issue and it's getting worse. I assume it's a manifold as we can't fin any problems with the exhaust. Sounds just like the cracked manifold we had years ago in our Honda Civic. CarSpec quoted $3500 as a rough estimate for a head gasket. They won't drop a new engine in. I've only found one place that will but they won't give me a price until they see the car. It's 8 years old. I'm probably looking at battery replacement before too long.
    Any suggestions for how to proceed? Drive it as is? Do the head job? Drop a used engine? Trade the damn thing in?
    I know I know, it's up to me...ok what else should I be considering as I weight the decision?
    Raytheeagle likes this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Thanks for checking back in:).
    Some follow up questions:
    • Did you get your house built or further along?
    • Are you able to DIY?
    • Still looking for a shop?
    • What’s your budget?
    With oil consumption and head gasket issues, I’d look at LKQ and see what their cost is for an engine. Once the blocks would be swapped, I’d take the egr cooler and valve off of the old engine for future use;).
    Keep us posted (y).
  8. climb.on
    30
    MN
    Three Touring
    Progress on the house yes, but we won't be done until early August. I am able to DIY, but not until the house is done. I swapped a Toyota 22RE engine once back in college. I'm no expert but I'm sure I can do it. Yes I'm still looking for a shop. Called a few and I get all kinds of responses from "it's not worth fixing" to "it's definitely worth fixing" and everything in-between, but mostly "we won't touch it." My budget is whatever it costs to fix it...but I don't know the point where it's not worth fixing anymore.
    I don't think I'm losing oil. Just A/F.
