Headlights, Power Locks, Hazard lights, Cabin Lights, Signal lights ALL WORK -but Cannot Power Car
Discussion in 'Gen 2 Prius Technical Discussion' started by Jouxse, Jun 21, 2020.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    No need to update me we get your post all the time now. All the G2 battery's are failing either now or pretty soon. Just the age just the heat.
    Its very very diy. But its silly to do so without tech stream imho. I know I wouldn't bother doing it without that. So concentrate on that software first search the word
    mini vci
    its one very inexpensive way to get TS software. Sometimes tricky to set up and you need a burner laptop its all Chinese hacked software.
    I see so many people whack a mole there hybrid battery it wont work when they put it back in the car and they have no idea why. Pretty nutty.
    The car throws the exact codes on why its unhappy all you need is the TS software to see why.
    Good luck.
  2. Jouxse
    Jouxse New Member
    28
    Pennsylvania
    Four Touring
    So turns out the car has to Power on for the bluetooth obd2 reader to pair with the app. So I was not able to do anything with the Bluetooth one. :(
  3. davecook89t
    davecook89t Senior Member
    1,089
    825
    Washington State, Florida
    Four Touring
    I'm sorry to hear that. With no power to the OBDII port, there is really not much you can do. I know you said you checked all the fuses, but was that a visual inspection or did you actually put a multimeter on each one and check continuity? A blown fuse would still be the most likely cause of no power to the dash or OBDII port. It would be a shame to have the car towed to the dealer only to have them tell you there is a blown fuse. Anyway, best of luck with whatever you decide to do. Keeping us updated on how this gets resolved will help someone with a similar problem.
  4. Jouxse
    Jouxse New Member
    28
    Pennsylvania
    Four Touring
    Hi @davecook89t thanks for the thought. I did NOT use a multimeter. So am going to go do that now. I tested the following fuses with a visual inspection AM2, AM1, DC/DS . Any others to test out besides those?
  5. Jouxse
    Jouxse New Member
    28
    Pennsylvania
    Four Touring
    Hello again. I tested every single fuse from the top of each with the multimeter and they all read 0.0. The only ones i didn't test were the fusible link under hood and the 120 amp main in the trunk, well because i don't know how to test those. How do I test the fusible link for continuity? Also what about the 120 amp which also has a plastic covering the fuse. The more I think about this the more I think it's gotta be a fuse because as I said in the title of my post, lights go on, car locks, keyless entry flashes when i try to hit power and their is no key with me.
    Could the fuses just need some sandpaper to them because they do seem rusty.
    I didn't mention this earlier but early on when I had to jump it a few times, I thought to keep a battery charger on the terminals under the hood (btw did trying to charge from the hood terminal mess things up?) and had forgotten to disconnect the charger from under the hood one night and it had rained that day so the fuses were completely exposed and rained on so all the ones under the hood have like a white crustiness on them when I pull them out.
  6. bisco
    51,964
    charging and jumping under the hood is recommended.
    white crust is not good. try cleaning with baking soda and water. test continuity or voltage across the fuse terminals
    davecook89t and Jouxse like this.
  7. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    You would be checking for voltage at one of the fuse terminals to ground. Some may need the car to be at least ACC-ON, others might need IG-ON to see 12.x V from one terminal to ground.
    #27 dolj, Jul 20, 2020
  8. Jouxse
    Jouxse New Member
    28
    Pennsylvania
    Four Touring
    sorry just to confirm when you say fuse terminal you mean inside the plastic covering (take off the plastic covering from the long fusible link) there are a number of connections so just test red to one of those and black to a ground. Do I need to test the 120a ?
  9. davecook89t
    1,089
    825
    Four Touring
    I believe the Fusible Link and 120 Amp fuse near the battery are the 2 most likely culprits for your no power condition. This thread, How to change Fusible link under hood | PriusChat, will help you test both the fusible link and the 120 Amp fuse. Apparently, you can test the continuity of each section in the fusible link to be sure it is Ok. Another suggestion is to use a wire with alligator clips to temporarily bypass any fuse that might be suspect just to see if the car will power up. You wouldn't actually want to let the car run in that condition as you would likely burn something out, but at least then you would know where your problem is.
    Jouxse likes this.
  10. Jouxse
    Jouxse New Member
    28
    Pennsylvania
    Four Touring
    Hi thanks for sharing that post it was actually one I had come across in my desperate search. I'm interested in doing the alligator clips test but have no idea how to execute. The poster wasn't very specific.
  11. davecook89t
    1,089
    825
    Four Touring
  12. ChapmanF
    18,220
    I was about to post an old photo from my old Gen 1 (similar battery clamp and fuse to Gen 2) showing the side of the plastic assembly unclipped and folded open, revealing the bolted fuse connection. But I saw I already posted that in the link given in #31. I still have the photo, but it hasn't changed. :)
    davecook89t likes this.
  13. Jouxse
    Jouxse New Member
    28
    Pennsylvania
    Four Touring
    Hi thanks for the picture. Can i run the alligator clip test with the 120 Amp or is that intended to be run with the fusible link ?
    Also do i have to take the 120 amp fuse out to test it? Or can i just take the clear plastic off and test the continuity that way?
  14. davecook89t
    1,089
    825
    Four Touring
    You should be able to use a wire to bypass a fuse where ever you can make a connection on both sides of the fuse. It might even be necessary to pull away some of the insulation to get to the bare wire to make the connection. Rather than risk permanent damage to the car's wiring, in some cases it might be better not to employ this type of testing method. Never having tried it myself for this particular fuse, I don't know what to tell you.
  15. Jouxse
    Jouxse New Member
    28
    Pennsylvania
    Four Touring
    Oh ok yes I agree @davecook89t I guess my issue is that I don't know how to test if the fusible link is bad, nor do I know how to test the 120 amp cartridge fuse next to the battery in the trunk. And I searched long and hard for some guidance on how to test to see if it's bad. Do I put the black on a ground and the positive inside the fuse wire once I take the plastic cover off? Neither the 120 amp fuse look bad nor the fusible link under hood but I would like to test before I rule out and of course before I just go and replace (since it doesn't look like a simple job)
  16. dolj
    dolj Senior Member
    8,450
    4,291
    No. The terminals are the metal legs on the outside that bolts go through on these big fuses. They are the exposed metal legs that slide into the fuse holder on the low profile 5, 10 15 A fuses.
    To test the fuse (any fuse) it has to be removed from the circuit or at least "open circuit" which means that at least one end of it needs to be disconnected. You then put your ohmmeter across the two terminals (of the fuse) and if the fuse is good then the reading on the meter show 0Ω (or as near as). If the fuse is bad it should show 1 (or whatever it displays on the ohms setting when not connected to anything).
    The issue with both these fuses is that they are bolted on so removing them is quite an undertaking. The rear one is easier than the front one, I believe.
    Another way to test a fuse is to establish which of the two terminals of the fuse-holder is the input voltage side and which is the output voltage side. With the fuse in place, you then test the input side terminal to ground and should see 12 V. You then test the output side terminal to ground, again you should see 12 V if it is good or 0 V if it is bad. Make sure the car is in a state where the input side definitely has (or should have) 12 V. This may mean the car needs to be in either ACC, IG-ON, or READY. If you do not have 12 V when you should then the problem is somewhere in the circuit before the fuse. If you don't have 12 V on the input side you can't use this method to test the fuse.
    Thirdly, I would suggest you find someone who understands what is written above, has enough knowledge of the use of both an ohmmeter and a voltmeter who can work alongside you as a sounding board/sanity check to verify you are going in the right direction. If you don't know what you are doing and/or have no real idea of what outcome to expect from a test, you will likely take yourself down the proverbial garden path.
    If all else fails, you just might be better off taking the car to an auto electrician, or if the car is immobile having a mobile service come to you.
    #36 dolj, Jul 26, 2020
    Raytheeagle, Jouxse and davecook89t like this.
  17. Jouxse
    Jouxse New Member
    28
    Pennsylvania
    Four Touring
    Huge thank you. This was very helpful. I know how to use a multimeter but I guess my dilemma will be trying to determine which to start with. What's the most likely culprit of my issue. I guess I can start with the easier one first. Or as you suggest a mobile service which i don't even know exists. My prius is parked at the top of a hill with the front facing the garage so not sure how I can get towed. There is no way to move a prius to neutral manually either.
  18. Stephanie Esser
    Stephanie Esser New Member
    Columbia, Mo
    I had a problem similar to this. A few weeks ago, I watched the YouTube video about cleaning my battery cooling fan to extend my battery life. In the video it shows how to engage (remove the big orange thingy on the big battery) the safety battery kill for my own safety. I did everything perfectly, but after the reassemble the car went nuts...no ready light, and it absolutely would not start. Took it apart two more times, still nothing. 10 hours of crying and apologizing to my car for destroying her, all the good stuff, and I decided to watch a different video. This video showed me that AFTER you put the big orange plug safety thingy in the car you MUST PUSH IT DOWN ! That was it...just a safety mechanism...have you toyed with the orange safety on the big battery? Keep us posted...
  19. dolj
    dolj Senior Member
    8,450
    4,291
    And for anyone landing on your post at a later date, removing the safety interlock is completely unnecessary when cleaning the cooling fan. There is no danger whatsoever of encountering high voltage when cleaning the fan.
  20. davecook89t
    1,089
    825
    Four Touring
    As long as there is enough room at the front to place a jack under the car and roll a dolly under the front wheels (a common procedure that towing companies use), the car can be towed. It's too bad it has come to that. In what part of Pennsylvania are you located? It so happens I will be travelling through the state later today, going from West to East along Route 80 and would be willing to stop by, if you are not too far out of the way. Send me a private message if that is Ok with you.
    Raytheeagle likes this.
