Heat keeps getting redirected to floor vents with dash vents selected
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ualdriver, Dec 16, 2013.
  1. ualdriver
    ualdriver Member
    358
    65
    Midwest US
    Wow....lots of posts added to this thread and I never got that e-mail notification from the forum automation.
    Anyway, to get back to the original point of this thread (HVAC system overriding manual selection to have hot air come out of vents on dash), I was driving my relative's NON-plug-in Gen 3 Prius. It was down to 50F this evening, so after the engine warmed up a bit, I put the fan speed on high, selected 80F as a temperature, and directed all the hot air to go to the dash vents. Manually directing the air to come out of the dash vents also kicks the climate control out of AUTO.
    Guess what his Prius does? After a few minutes, the HVAC system goes back to AUTO on its own, and directs the hot air to the floor vents. I tried redirecting the air manually a few times, and sure enough, after a few minutes it overrides my directions and goes back to AUTO and the floor vents. Seems like this may be a "quirk" for all Gen 3s?
    Also, his seat warmers get pretty warm almost immediately (~60 seconds) while my PiPs seem to take a few minutes to get warm.
  2. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Admittedly it doesn't get anywhere near as consistently cold here but I have never had mine kick back into auto or direct to the floor vents when heating. Also I would never heat the car to such a hig temperature, 71 F at the most.
    51,895
    once you use auto, it seems you have to turn the fan off to clear auto from memory. then you can turn the fan back on and use it manually. pretty sure the gen II was the same way. as far as seat warmers, mine heat up in 30 to 60 seconds.
  4. El Dobro
    El Dobro A Member
    7,088
    3,270
    Yea, the seat warmers come right up in mine, too.
  5. markabele
    5,084
    1,782
    Nebraska
    Seat warmers are fast in mine and have never had a problem with the HVAC having a mind of it's own (except when I want it to in auto).
  6. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    I guess my PiP is still too new - where would I find the engine temp readout? Also, please explain what you all are doing when you block the lower grille, what material and how fixed in place. Thanks.
  7. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    For engine temp, you need a Scan Gauge II or an OBDII reader and an app for a phone/tablet to read the output.
    Grill blocking is covered extensively in the forum.
  8. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Engine coolant temp read in Torque on my smart phone using a plug in device that plugs into service plug under dash. Grill block, I use inch and a half pipe insolation stuff into lower grill.
  9. bisco
    51,895
    i use 1/2" foam copper pipe insulation. $2. for four 3' pieces at hd or lowes. cut to length, open precut lengthwise slit and hold upto the grille. mark the spots where the grille has vertical stabilizers and slice about halfway thru the foam in those spots so it will slip in deeply enough to be snug. the trouble spot for me is the front license plate holder. i just stuff a short piece on either side.
    markabele likes this.
  10. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    bisco, Lourun - thanks for taking the time to provide a few details, it's always helpful for the newbie. It appears that a lot of forum members are men of few words. :cool:
  11. bisco
    51,895
    no prolemo. sometimes, we just get tired of ansering the same ol' questions.:) i like the simple ones tho, that's about all i can handle!:p besides, who can refuse bilbo bagginses?(y)
  12. El Dobro
    El Dobro A Member
    7,088
    3,270
    I still have a pack of the copper pipe insulation in the garage for the TDIs. If it ever gets really cold around here for a while, I'll have to break them out.
  13. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    My suggestion to search regarding the grill blocking was because there's a number of methods and parts utilized by various members of the forum so you can pick what suits you. Sorry if it seemed terse or lacking helpfulness.
    And your welcome for the info regarding the Scan Gauge II and/or OBDII reader.....Jeez
  14. retired4999
    2,652
    627
    Eau Claire, Wi.
  15. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    The climate control system in the PiP does this kind of bizarre thing constantly. You've only stumbled on one case. Wait until it starts switching your vents from recirculate to outside air every time you press the AUTO button, or better yet, doing the same thing when pressing the OFF button. My favorite annoyance is when you press the filter button and after it runs for its programmed period of time it helpfully switches your vents to outside air so you can recharge your interior with all the stuff you just filtered out.
  16. markabele
    5,084
    1,782
    Nebraska
    Sounds like you guys need the system checked out. There are plenty of examples on here, including mine, where the AUTO acts exactly like it should.
    uropip likes this.
  17. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I assume the "filter" button is in the Advanced only...?
  18. markabele
    5,084
    1,782
    Nebraska
    It's in every Prius from 2010 on.
  19. bisco
    51,895
    to the right of the air direction button. i tried it once, it's just like auto, fan goes to high, :eek: sounds like a jet engine, never used it again.
  20. Feri
    Feri Active Member
    761
    144
    It's quite effective. I use it to stop dust getting in when cars pass on dirt roads and I use it when travelling long freeway tunnels. As well as filtering it completely stops outside air from entering. The three minutes is usually enough. A few time while travelling the wife has reacted to outside allergens and filtering has helped clear those. I agree about the noise which is why I don't use Auto.
