Heater 'growling' when engine is stopped
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SquareWheels, Nov 29, 2013.
  1. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    There is some confusion on this matter because in the US, and the north American continent the Prius is fitted with three pumps, a thermos tank, and a coolant control valve.
    This does not apply to the rest of the world where the engine coolant circuit has one mechanical pump, "engine driven" and one electric pump for when the engine is not running to supply the heater core. There is no control valve or thermos tank. The OP lives in the UK meaning his car has the simpler system.
    John (Britprius)
  2. SquareWheels
    SquareWheels "15kW or stealth" driver
    23
    London, UK
    Indeed John – but I didn't even know there was the electric pump until I concluded that there must be when I heard its naughty growling noise. ;-) Is there no flow-control valve other than the actual thermostat, for regulating when/how much coolant runs through the radiator or otherwise?
  3. Britprius
    5,194
    1,922
    Just as with any other car there is just the normal thermostat. The electric pump is there to feed the heater core with hot coolant when the engine is not running.
    The growling noise is almost certainly air trapped in the heater core, due to the coolant level getting low, and quite possibly this is aggravated by the leaky pump allowing more air in to the system as the air already in there contracts as it cools forming a vacuum.
    With the VCI it is possible to run the engine continuously to help remove the air. This can also be done by putting the car in service mode.
    A vacuum pump fitted to the top of the rad helps a great deal to remove trapped air, but if the engine pump seal is weak you may just draw in more air.
    John (Britprius)
  4. northwichita
    481
    102
    29
    Wichita KS
    My heater pump made a slight rattling noise -- I identified it by scrolling the cabin temp up and down when at a stop with the engine off-- before it finally failed, was a pain to change. If you are getting decent cabin heat with the ICE running, I would lean to a failing heater pump.
  5. SquareWheels
    23
    London, UK
    Thanks for that. I didn't let the coolant level in the reservoir fall below MIN, but air may be being drawn in via the (known to be) leaky mechanical pump.
  6. SquareWheels
    23
    London, UK
    A slight rattling noise, eh – maybe if I make a recording of mine you could say if yours was similar? It could be described as rattling, and yes as you scroll the cabin temp up & down you hear it kick in and out.
    A pain to change? Don't tell me it's one of those things where you have to remove the entire dashboard? :mad:
    Many thanks,
    Richard (Squarewheels)
  7. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    The electric pumps make a growling noise as they fail. I don't think it is air in the system if the reservoir still has some coolant inside.
    Un plug the electric pump and see what happens. It will throw a check engine light but that can be cleared with a code reader which you may already own.
  8. SquareWheels
    23
    London, UK
    Thanks for that. I don't know where this pump is to be found or accessed (it's not shown anywhere that I've seen yet) – indeed I only discovered its existence in the last few days. I can already turn it on & off at will by toggling the heat setting up & down.
  9. northwichita
    481
    102
    29
    Wichita KS
    The pump for the heater is behind and a bit underneath the inverter next to the engine bulkhead. I replaced it when I replaced my brake actuator. I'm not sure if the inverter has to be moved to change it, but it sure helps. You could try first taking out the inverter mounting bolts to give an inch of two movement forward for more access for the pump. The engine cowl definitely needs to be taken out, not as bad as the dashboard.
    Engine Compartment Cowl Removal: Owners w/Mice or Stinky AC take note... | PriusChat
  10. SquareWheels
    23
    London, UK
    Ah, great – thanks for this. The cowl is straightforward enough, moving the inverter isn't something I've tried before (yet...!).
  11. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    Moving the inverter is not as bad as it sounds. It is easy to unbolt. All the coolant hoses and wires going into it are flexible so you can push it over a few inches without committing to a long complex procedure. The inverter is not live as long as the car is off and has been off for at least a minute or two. Removing the service connector is a good precaution as well.
  12. SquareWheels
    23
    London, UK
    That's all good to know, thanks for sharing it.
  13. Patrick Wong
    18,210
    6,514
    OP said that the coolant level was around 1" low at the radiator neck. That is evidence that air is getting in the system. If the system was air tight, the overflow container and radiator cap would keep the radiator itself totally full.
  14. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    I just don't see how a slow coolant leak is going to make the electric pump growl. I've never seen aerated coolant only power steering fluid. Has anyone seen coolant frothed up because of a leak or any other reason? It just leaks out and eventually overheats your motor once it goes too low. He probably needs both mechanical and electric pumps replaced to get the car back into shape. The mechanical pump will be much more challenging to change and requires some finesse to get right.
  15. SquareWheels
    23
    London, UK
    I got my VCI yesterday. Opened the boot with a trackpad-click and everything.
    Sadly, it seems the kind folk who sent it also sent me Win32:Sality virus which is causing me a lot of trouble and wasted time now. :cry:
    Fortunately it's on a virtualised instance of XP running in my Mac so a bit less catastrophic than it would otherwise be.
    I take it no-one else has had this problem?
  16. Britprius
    5,194
    1,922
    Sorry to hear that Richard. Are you sure you got it from the program? as I have not come across anyone else that has had a problem with a virus from the program. Word would get round very quickly if there were problems.
    If you need a copy let me know and I will see if I can Email you a clean copy.
    John (Britprius)
  17. SquareWheels
    23
    London, UK
    Thanks for the offer, John. It's a big coincidence if it's not related. I'll see if I get it again when I reinstall it on the virtual machine, and report back if I do.
  18. SquareWheels
    23
    London, UK
    Yes, it's on the CD-ROM that came with the cable. E:\patch_Toyota Techstream V8.20.019\MainMenu.exe is infected with Win32:Sality right there on the CD-ROM. I've contacted the seller in the first instance, but in due course I may indeed wish to take up your kind offer.
  19. SquareWheels
    23
    London, UK
    OK, a small update. Haven't done anything terribly useful yet, but I do now have a recording of the growling heater-pump for those who may be interested. I can also confirm it's related to the heater-pump, as to make this recording I was controlling it on/off/on/off directly via the Techstream USB/OBDII cable (you can hear my trackpad-clicks!):
    Audioboo / Prius heater-pump 'growling'
    Also a heads-up, particularly for those who like me mostly use non-Windows computers, to virus-scan any CDs received or bought before deploying. :oops:
  20. Scorpion
    Scorpion Active Member
    440
    162
    Lincoln, NE
    I had a question about the heater and I'd sure appreciate any input anyone may have.
    I never understood why the engine idles when providing heat, without actually charging the battery.
    I mean, I'm stopped at a drive-thru, it's like 5 degrees outside, and my battery is in the blue w./ 6 bars.
    Since the engine has to run anyways to bring the cabin temp up to whatever I set it at (70-75), why doesn't the engine act like a generator at the same time to charge up the battery to 8 bars green? How can it possibly be less efficient not to? I mean you'd think the extra gas used would be more than saved once I start moving again?
    Am I missing something?
    Thanks,
