Help interpreting Dr. Prius results on Prime
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Kirker, Feb 27, 2024.
  1. Kirker
    Kirker New Member
    Seattle, WA
    I'll try posting this here and maybe will get a response. I'm looking at a used (not certified) 2021 Prius Prime XL and I got to test drive it. A few paint chips on the hood and near the electrical fill up port, a pretty dirty engine compartment, but otherwise *looks* good. I plugged in my OBDII sensor and got the following reading. The car had 25 miles at the start of my test drive and ended at 24. That was Thursday, Feb 22. I called on Saturday Feb 24 and the salesperson said the EV range was down to 21 miles. So it lost
    I also made a recording but I don't know how to turn that into a real-time video. I do have the .csv file data though. What should I look for in that file?
    Here is the snapshot. What should I be looking at/for?
    52,706
    how many miles on her?
  3. Kirker
    Kirker New Member
    Seattle, WA
    42,100 miles
  4. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    Everything in the screenshot looks normal.
    The .csv file needs a reader app to view. I haven't found one I like, so I can't help you with that.
    Is the Prime you're asking about different from the Prime listed in your Profile?
    Approx how long was your test drive in minutes and / or miles?
    Did you use all of the estimated 25 miles? Did the gas engine start / run during the test drive?
    Do you currently drive the 2020 Prime listed in your profile?
  5. bisco
    52,706
    These cars are nearly bulletproof.
    At 42k, I wouldn’t be concerned in the least
  6. vvillovv
    4,336
    1,517
    NY
    I haven't done a test drive in a few years. LIke a typical test drive is gonna be a half hour or 15 minutes on the hwy.
    Wondering what the confusion is about the estimated range dropping,
  7. Kirker
    Kirker New Member
    Seattle, WA
    I don't know why it says I own a 2020 Prime in my profile, I'll change that. I do not own one, but I've been looking for awhile.
    I can open the .csv file in Excel or Google Sheets, that's not difficult, but it (obviously) doesn't show an animation of the data like in the Dr. Prius main screen. It just has rows of data with timestamps when it was recorded. I ran it for about 2-3 minutes.
    My test drive was about a half hour but I only drove it about 1 or 2 miles. I parked and did a once over on the outside in a bright parking lot (it was nighttime and wanted to get a better look). Also fiddling with my OBDII scanner and Dr. Prius app took some time.
    I did not use all of the 25 miles.
    The engine did start and run when in Auto EV mode when I gunned it or going up a moderately steep hill. On pure EV it didn't kick in unless, again, I really hit the gas. At least that's what I recall.
    Someone below said he wondered what the range loss issue is. The issue is that I didn't buy it after the test drive. So it sat at the dealer for two days. I asked the salesperson to check the range. It was at 21 miles after two days. When I brought it in after the test drive it was either 24 or 23 miles. So it lost about 2-3 miles fo charge in two days.I had the car held so no one should have driven it. Is that kind of loss normal?
  8. vvillovv
    4,336
    1,517
    NY
    That's quite a bit clearer now although 1 or 2 miles for a test drive is pretty unusual. Though it make sense about the 25 miles of range and finishing with 24 or 23 miles of range. No, it's not normal for the Prime to loose a couple of miles of range in a day or two of not being used, but we also don't know what happened between the time you finished your test drive and when the salesman looked at the estimated range.
    But, if the Prime wasn't moved at all since your test drive than it should have still been 23 or 24 miles, typically.
    Will they give you another test drive? Hopefully, you'll be able to drive it in EV mode for 20 minutes or so, than compare with your experiences from the first test drive.
  9. Kirker
    Kirker New Member
    Seattle, WA
    Again, I took several minutes to fiddle with the OBDII dongle and getting it connected to my phone - maybe upwards of 10 minutes. Then about 5-10 minutes at a big box store parking lot with lots of lighting. So I only drove it for about 10-15 minutes. It drove well, the engine was not on all the time (or even on that much).
    I don't think it was moved or test driven - I held it for $500 so they said it's mine and I would be surprised if they'd have someone else test drive it.
    I am going to take it in for a pre-purchase inspection tomorrow, Feb 29th, but not at a Toyota dealership. I have to wait until Saturday for the Toyota dealership to look at it. They tell me they can't hold it beyond the 29th as the manager wants it sold by the end of the month. It seems a little odd to be pushing it out the door so quick (they just got it a week ago).
    But yes, I test drove it Thursday night and it had about 25.1 mile range and between the relatively short drive time and regen it went down to 24 or maybe high 23's. On Saturday when the salesperson texted me the remaining EV miles on the dash it was 21.1 miles.
  10. Kirker
    Kirker New Member
    Seattle, WA
    So far that has not been my experience. I've looked at three used Prius Primes: 2019, 2018 and this one, 2021. I had the dealers fully charge all of them and send me a photo of the dash EV range. The first was 30 miles, second was 23, and the third was 25. After three days the first two were: 5 miles (2019), 0 miles (2018), and 21 miles (2021).
    It appears that as the cars age at least *some* of them have batteries that lose charge while sitting unplugged. Maybe not yours, maybe not anyone else on this thread. After all, you still have yours. These are all trade-ins. So maybe they traded them in partially or solely due to the battery losing charge?
    I don't know, but scouts honor, that is what I've seen. It's extremely frustrating and makes buying a used plug in hybrid that much more dicey.
  11. bisco
    52,706
    you haven't seen it because you're not in possession of the cars. if this was a problem, someone here would have reported it in the last 7 years.
  12. Kirker
    Kirker New Member
    Seattle, WA
    I've seen what I wrote above. Not clear on what you mean by "You haven't seen it because you are not in possession of the cars." What does that mean?
    Using PriusChat as the touchstone for whether this is happening isn't adequate. First, there are other venues for people to bring this issue up. Reddit (r/prius), priusonline.com, etc.
    Second, the population of people who own Prius' is not the exact same population that frequents (or even knows about) PriusChat. Think of it in terms of a Venn Diagram. There are thousands of Prius' and Prius Primes and not everyone are aficionados that frequent chat boards like this.
    So could this happen? You bet. And if you Google search it you'll see other people have had this problem.
    At any rate I didn't buy the car more because of a title issue.
  13. OptimalPrime
    OptimalPrime Member
    167
    100
    Keene/Nashua
    First, "EV miles remaining" is ALMOST TOTALLY WORTHLESS. It uses an algorithm to convert % charge, to miles. Do YOU know exactly what that algorithm is? I'm an engineer who has owned one for 7 years, and I don't claim to know it. Maybe it's some rolling average of miles/kWh for the last so many miles, so many days, so many start/stop cycles, or a combination of things.
    Bottom line, I know that % charge means the same thing every time, and EV miles remaining does not.
    I can drive my car 5 miles, have the % charge not change at all, and have the EV miles remaining estimate change drastically. If I drove uphill, fast, or poorly, the EV miles will drop. If I drove downhill, slowly, and well, the EV miles will rise, despite no change at all in battery state of charge.
    And neither measure means anything, when you don't know if a kid tasked with cleaning the cars on the lot, sat in it and listened to the radio for 15 minutes, much less what mode the car was in at the time. Ditto if the headlights were put on for 2 minutes with the car off, then the car was put in Ready mode for 2 minutes. Or the weather changed by 40 degrees. Or the car's settings triggered battery heaters or something else to use up some charge.
