HELP lol.... Code p1437
Discussion in 'Generation 1 Prius Discussion' started by devinholland, Apr 2, 2022.
  1. devinholland
    devinholland New Member
    wi
    2001 Prius
    Alright, I have replaced the hsv, I currently have the sensor coming to the house to replace that but all the lines are in great shape... if this doesnt work im at a loss....
    If someone has a picture of the CHECK VALVE... because I have no idea where that is... I would greatly appreciate it!!!! or any help with this...
  2. Stock808
    Stock808 Junior Member
    Hawaii
    2001 Prius
    That's the HCAC Valve mounted near the rear of the cat underneath the car.
    Double check all the vacuum lines it runs from the side under the brake fluid reservoir.
    if it's missing or acting up you can do a "hack" from this thread to bypass it Tricking HCAC codes into going away? | PriusChat
  3. devinholland
    wi
    2001 Prius
    I do appreciate the reply. So I replaced the sensor and the hsv. However I am now pretty sure its the VSV... Does anyone know if I can use part # 25860-62010 instead of 25860-46010? or has given in a shot?
  4. devinholland
    wi
    2001 Prius
    pretty sure my problem is the vsv, only because my abs lights come on along with the code...
