Help No Display screen, can I drive it?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Freedom, Aug 19, 2015.
  1. Freedom
    Freedom Active Member
    553
    73
    Northeastern MA
    See Page 2 Post 32 - I did it I got the touch screen unit out!!
    I am due to make a 400 mile round trip business trip today. Go out and start the car, and the screen display is black. The MFD. None of the buttons on it work, either - I have the beep ON, no beep. I turned it off, waited about 1 minute and tried again, still nothing. Went for a short drive (took the dogs to the park where they can run), it was off for about 35 minutes. Still nothing for the short drive back home. I mean short, this is less than 2 miles one way.
    I can still access the a/c and the radio from the steering wheel. I can see my speed, fuel etc, that is fine. It is just the display monitor.
    This came out of the blue, I have not noticed any issues at all.
    Questions:
    1. Can I make my trip today and then get this addressed?
    2. Any thoughts as to what is going on? As in, how much is this going to cost me?
    3. Feel free to add anything you think may help.
    I found and read this: Dashboard Touch Screen Not Working | PriusChat
    If the problem is a loose solder connection, then why don't they just fix that instead of replacing the whole unit?
    And, new question 4: anyone know a place near Methuen, MA / Salem NH which does this for less than the dealer is going to want?
    Called the Service Dept at the local dealer, he said I can go on the trip. Took some time, as he had no idea what an "MFD" is. I asked him if he was familiar with the Prius. GRRRR.
    #1 Freedom, Aug 19, 2015
    Danny3xd likes this.
  2. Mendel Leisk
    42,364
    Multi-Function Display??
    (I'm stumped too, but then: I HATE acronyms.)
  3. Beachbummm
    Beachbummm Senior Member
    1,160
    393
    check the fuses?
    #3 Beachbummm, Aug 19, 2015
  4. Freedom
    553
    73
    Northeastern MA
    OK, where are they?
    Car has 60,000 miles. Is it worth spending the $4k to get the MFD fixed?
    #4 Freedom, Aug 19, 2015
  5. Patrick Wong
    18,210
    6,526
    Yes, you can drive the car indefinitely without the MFD.
    When you are tired of driving the car without the MFD, buy a used MFD on eBay and install it.
    Do you actually expect dealer personnel to be able to repair a solder connection on a surface mount printed circuit board? If they had technicians who could do that, they would not be working at an auto dealership.
  6. Freedom
    553
    73
    Northeastern MA
    Soldering is an easy job, I did it as a summer job during college.
    I can manage the a/c and radio. Not sure I can live without my back up camera, lol. And not sure I could put in an MFD myself, hmm.
  7. Patrick Wong
    18,210
    6,526
    If you believe you can identify the failed solder joint with a microscope and repair it, then removing the MFD for that repair is really a minor issue. There are several posts about how to remove the MFD and you can subscribe to techinfo.toyota.com if you can't find one. This basically involves pulling out the three ventilation louvers (other than the one to the far right), then removing the plastic panels as needed for access to the MFD. Then remove the MFD mounting hardware, pull off the wiring harness connectors, and the MFD is now loose for you to work on.
  8. Freedom
    553
    73
    Northeastern MA
    Further online research says it is possible - just possible -- that this is a fuse. And so, I will take Carmine to the Dealer for diagnosis and if it is a fuse, I'll let them fix it. PRAYERS needed that this is only a fuse issue. Because it does not make sense to spend $4k for a 2008 with 60,000 miles. I'll just have to get a new car; and that I am not in a position to do, at this time.
  9. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    I know nothing about this type of repair but I will pose a question to the experts here. Thinking outside the box, is the broken solder problem something that could be found and repaired by a local computer repair shop that works on laptops and circuit boards?
  10. bisco
    52,878
    i don't see why not. steve at autobeyours repairs them i believe.
    imwoody36 likes this.
  11. Freedom
    553
    73
    Northeastern MA
    Carmine went in to the dealer for diagnosis this morning. Internal failure of the entire unit.
    Toyota offers refurbished units with a 1 year warranty for $1350; then another $125 to install. I told them to order one for me. Should be in next Wed, and I can have it installed on Thurs. This dealership says they have never seen this problem before. ?????
    I had looked on ebay last evening, only one I saw for my year had no back up camera capability, so that wasn't going to work for me. But it did point out to me that not all the ones for my year have that functionality. I made sure the Service Dept knows I have this, so they order the right one. Their first question was, "is that something you added to the car?" Um, no, I have package 3 it is standard.
    Oh and my "Navigation Screen Sun Hood Visor" (from the Prius Chat shop) gave rise to all sorts of questions: "what is it, how is it attached, if that is what caused the mfd to fail you shouldn't use it" and on and on. Geesh!
  12. Patrick Wong
    18,210
    6,526
    Maybe that particular service writer, who joined the dealership two weeks ago, had not seen this problem before...
    Wow, that price is pretty high...
    More effort to redirect your attention away from the failed solder joint in the MFD...
  13. Freedom
    553
    73
    Northeastern MA
    Related to what, Patrick? The old thread I quote way up top, from 2010, $4 to 5,000, this is much lower than that. And, the only one I found on ebay was not compatible, did not have the back up camera, so I could not go the DIY route.
    So what are you comparing to when you say that is high? Thanks for more info!!
  14. bisco
    52,878
    did you try steve at autobeyours?
  15. Patrick Wong
    18,210
    6,526
    One alternative is to pay autobeyours.com $325 to repair your current MFD.
    Prius MFD Touchscreen Repair
  16. Freedom
    553
    73
    Northeastern MA
    OK, I've looked at autobeyours.com. Much better price, same 1 year warranty.
    Not confident I can remove the unit myself. Watched all the vids. Step by step. If ANYONE is near me, and wants to come over, sit and read while I do it, I'd give it a go. Only me, one car, not sure I want to risk doing more damage. I tend to be a 'bull in a china shop' when I do stuff around the house.
  17. Patrick Wong
    18,210
    6,526
    If saving $1K is not sufficient motivation for you to figure out how to remove the MFD, then let the dealer do that for you.
    Here is my post which explains how to replace the gear selector lever. The dashboard removal is similar to the process required to replace the MFD. You would also need to pull out the ventilation louver assembly to the right of the MFD.
    How to Replace 2G Gearshift Lever | PriusChat
  18. Freedom
    553
    73
    Northeastern MA
    OK, I watched this vid, by Steve Woodruff:
    In the first 20 seconds, he says the tools you will need:
    Says I need a Phillips screwdriver, a Flat Head screwdriver and a 10 mm driver, and then he says what? a retro? No idea. I do have hearing issues, even with my hearing aids, so just a bit of help there please. I've played it back several times, just can't catch what he says.
    I can follow what he does, the unit is out and ready to ship.
    Now, I just put everything back together and I can use the car with a big hole and 4 plugs? Do I have to make sure the plugs don't touch one another, or tape them or what? He doesn't actually show the plugs so I'm not sure what sort I will be dealing with.
    And, when I get the unit back, I do this again and put the unit back in, that I get, also.
    Guess I just have those 2 questions!
    Going to poke about on youtube, see if I can find any additional vids.
  19. bisco
    52,878
    after he says a 10mm driver, he says 'a wrench will work'.
    steve's two minutes would be a weekend for me.:cool:
  20. Freedom
    553
    73
    Northeastern MA
    Thanks Bisco, are you talking me INTO this project, or OUT of it! LOL
    Hey, you are in Boston, want to come up to Methuen and give me a hand?
