Help with Dr Prius readout
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Nivlatan73, Aug 28, 2020.
  1. Nivlatan73
    Nivlatan73 New Member
    Singapore
    Hi Prius gurus,
    Just gotten my 2017 Prius and did a OBD run with Dr Prius and this is what i got. Anyone can confirm my HV batteries need balancing or replacement?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    A 2017 - the HV battery should be just fine till 2027 and longer. About then, here in Australia, they've had a 10 yr, Unlimited km warranty for a couple of years now - so their expectation is that they'll last a long time.
  3. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    I would guess your Dr. Prius app was not installed correctly. I doubt that there is anything seriously wrong with your car's HV battery after only 4 years of usage. I believe the app's developer, @jacktheripper, is still active in this forum. Perhaps he can explain why your installation is displaying such odd results.
    alanclarkeau likes this.
  4. Elektroingenieur
    2,515
    3,259
    Three Touring
    I don’t think so. See my previous posting about the block voltages; readings of 16 V and 32 V are normal.
    davecook89t and alanclarkeau like this.
  5. alanclarkeau
    7,044
    7,584
    The other question - was there something going wrong with it - that made you connect Dr Prius?
  6. davecook89t
    1,057
    789
    Four Touring
    I see the same pattern in the other member's readout that @Elektroingenieur referenced, but when I run Dr. Prius on my Gen 4, I see 14 blocks having voltages around 16V or so. Is there something about the JDM ECU that causes the blocks not to be properly recognized by Dr. Prius?
    Edit: Ok, I see from your posting of the manual info, a block can be defined as 4 modules, rather than only 2, as is the case I am more familiar with.
    #6 davecook89t, Aug 29, 2020
  7. Elektroingenieur
    2,515
    3,259
    Three Touring
    There are different versions of the battery management system, depending on the HV battery chemistry. My posting linked above applies to models with a Ni-MH battery (ZVW50 series). Models with a Li-ion battery (ZVW51 series), such as your Four Touring, provide voltage readouts for each of the 56 cells, rather than in blocks. See the Hybrid Battery System (for Lithium-Ion Battery) section of the Repair Manual (more info) and the Powertrain > HV Battery > Data List page in a Toyota Techstream diagnostic system.
    alanclarkeau and davecook89t like this.
