Help With Next Move: Code P0AA6 and Subcode 612
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lighthouse-Beacon, Oct 24, 2018.
  1. Lighthouse-Beacon
    56
    44
    FL
    Hi Everyone, Long time lurker, but first time poster. Prius chat has helped me alot along the way and I am thankful for that. This is my first real deal issue with my 2009 Toyota Prius. I've have it about 6 years, total mileage at 220k, 100k of that is me. It's a great vehicle and has ran well with routine maintenance.
    I threw red triangle, yellow exclamation, and VSC while on way to Home Depot a few day ago. Turned it off and the vehicle locked down and wouldnt let me start. Pulled the 12v aux plug in back and it let me get home. I ordered a MiniVNC TechStream from Amazon, which has been awesome and is a MUST for a Toyota owner IMHO. Amazon search "Yueku Mini VCI J2534 Toyota TIS Techstream Cable Car OBD2 Diangostic Cable (1.4.1)"
    Anyway, I am seeing Code P0AA6 and Subcode 612 (attached) P0AA6 is a Hybrid Battery Voltage System Isolation Fault, and according to another thread I'd encountered the subcodes represent: 611 = AC compressor, 612 = Battery case, 613 = MG1 or MG2, 614 = inverter or DC cables, and 655 = MGR. I thought this was awesome because I really didnt want to see 613.
    So my next step was to do a ground test on the pack. I followed this video, which is kind of neat and turned out accurate: Youtube search "Gen 2 Prius P0AA6 battery leak confirmation" Sure enough my meter showed a consistent voltage of 30.8V, which confirmed my leak was in the pack.
    I next removed the safety plug, removed interior, and removed battery shield to find a pretty big and messing electrolyte leak in the bottom of the battery case. Bingo! (attached) My research gets alittle fuzzy now at this point.. What is my next best course of action? Any replied appreciated. Thank you!
    52,380
    replace the battery?
    Lighthouse-Beacon likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Next step is to find the leaky module. Once you find that, then replace it;).
    I would charge and balance the pack once you replace the module to keep everything in sync:).
    Good luck and keep us posted (y).
    Lighthouse-Beacon and SFO like this.
  4. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Best course of action you said!? If you want to keep the car forever, get a new pack. If just for awhile, considering the mileage, then replace modules affected, and do balance the new modules along side the pack.
  5. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  6. Lighthouse-Beacon
    56
    44
    FL
    Going to brake down the battery pack and begin to look for leaky cell(s). Will update the thread as I proceed. Thanks a lot.
    Raytheeagle likes this.
  7. strawbrad
    953
    1,007
    High voltage batteries are dangerous! A leaky battery is even worse. Keep in mind that with a leak present the battery case and the cars body are a live part of the circuit. High voltage is present until all the bus bars are removed from one side of the battery. Unlike home wiring with circuit breakers and such which allows working on dead circuits, the only way to remove the bus bars is while they are live. Don't touch the case, don't touch the terminals, and definitely don't touch them at the same time.
    The leak in your battery is 30.8 volts away from where you measured. That will help locate which module is leaking. Once you get down to individual modules measure for voltage between each terminal and ground (case). Gen 2 modules crack next to the bottom mounting holes. Don't expect to be able to see the cracks or electrolyte. They are usually much too small to see. It helps to wash the individual modules as one leaker can contaminate several nearby modules.
  8. Lighthouse-Beacon
    56
    44
    FL
    Thanks Strawbrad, yes this all makes good sense. Ive opted today to take it to a guy I've met who rebuilds/conditions HV batteries. I know I could do it and for less money but I think I am going to throw this job to him this round. If I get another failure within the year I plan to start doing it myself. He said he can get me back on the road for a few hundred bucks so I am going to let him take it. I give it to him this Thursday 11/1/18. I will document findings, area, price of fix, and location for the forum. Thanks for the above tips.
  9. Lighthouse-Beacon
    56
    44
    FL
    Found a new guy who's agreed to take a look. Dropped it off today. Seems like a nice guy, curious to hear how many cells are not good.
  10. Lighthouse-Beacon
    56
    44
    FL
    So the shop just got back with me and is saying that he could not find a leak in any modules and modules have all been discharged and recharged and balanced. He doesnt think it's a bad modules. Hes theorizing it could be a bad relay or bad battery controller ECU. Ive asked him to button the car back up and I am going to get it again tomorrow. I asked him about the level of corrosion. He said it appeared as older build up and average spillage due to the vehicles use. He was not able to find a ground fault. Thoughts on this? I guess the plot thicken...?
  11. Lighthouse-Beacon
    56
    44
    FL
    Well turns out the people I took the car to are total dumbasses and don't know what they are doing. I got bad vibes from the moment I left the vehicle. He claims to have tested the modules, discharged, recharged and balanced and everything is good, then claimed it was the inverter, then the mg1 and mg 2 generator, then mumbles something about replacing the battery ECU, just totally random crap. I tell him not to do anything and Im coming to get the vehicle.. I get there and the vehicle hasnt moved and the battery case hasnt even been opened.. I know this because I rigged the case with a piece of masking tape and also all the cover panel bolts I selected and left in were exactly the same. I had to buy my key back for a couple hundred bucks before I could get the prius out of there.. Total con artist idiots. Anyone who may come across this thread in future in Fort Myers Florida area needs to avoid these people:
    Buy Rite Auto Inc
    Hybrid Battery Repair
    8236 Engle Pl #2
    N Ft Myers Fl 33903
    (239) 826-9097
    Total conartist idiot. AVOID!
    At this point I've decided to reset the code each time I drive it to work, which I am doing 9 miles a day total. I am going to risk it and just drive it because the vehicle is not worth much at this point anyway. When I get time Im going to order ebay modules, break down the pack, clean and start replacing based on observation and position of leak. Ive been without a car 3 weeks and I am just over this process. Will update forum in time to see how it does driving on a leaky module! Woohoo!
    Cheers
    SFO likes this.
  12. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    1) Do Floridians a favor and register your complaint w/ Florida Dept of Agriculture and Consumer Services. A few more key strokes, copy/paste your earlier postings into the online complaint form.
    Motor Vehical Complaints
    2) Something to keep in mind, a new OEM HV battery could have been had for $1700.
    Battery - Toyota (G9510-47031) | Conicelli Toyota of Conshohock
    Relatively pricey ($1700/10yrs = $170/yr). Possibly worth more than the car. BUT, a new OEM pack gives you flexibility.
    You can move it into another Gen2, esp one w/ a bad HV battery, should something happen to the current Gen2.
    You can move the modules into a Gen3 w/ a bad HV battery, via module transplant.
    You could also sell the replacement OEM pack, recovering a fair chunk of your expenditure.
    If you had to rent a car for 3wks, that was money that could have been utilized for a new OEM pack.​
    SFO likes this.
  13. Lighthouse-Beacon
    56
    44
    FL
    Will do. Luckily my wife has been taking me to work in the 4Runner (SR3). This Prius was originally her driver when she had s big daily commute years ago (160 miles daily). I've had the car since our first child was born and we put him in the SUV. New pack would be cool but I just don't think I am willing to sink 2k in the car. I just watched a 2009 Prius with 148k miles sale from 3,500 on Facebook Market and I am looking at a 2016 RAV4 with 33k miles for 15k (non hybrid) which I'm going to eventually do I think. I talked to these folks last night, they are in Sarasota Florida and can do a resused pack that according to them has been "rigorously tested". For 700 installed with 6 month warranty. eBay
    I may do that before I trade the car towards the RAV4. (Private dealer). I am just going to keep driving another few weeks and think about it.
  14. Lighthouse-Beacon
    56
    44
    FL
    My tech stream is showing good voltage and not terrible resistance in the modules. I fill probably get bored one night and just fix the leaker especially if I'm going to trade it towards a gas burner, I've just gotta get the time to pull it apart. Maybe if I keep driving the module will die completely and make it easier to find when I jerk it apart again. Oh well! About to head to work in her. I installed a JIS terminal switch on my ground so I am just flipping my ground off and on before driving. Quicker than clearing. Ha! I know.. I'm a bad boy!! But hey I'm going to keep running her, she's a work horse.. always has been. Cheers
  15. Bigjohnson
    Bigjohnson New Member
    Phoenix
    Any updates? I have the same codes and am about to take the plunge.
  16. Lighthouse-Beacon
    56
    44
    FL
    Hey Johnson,
    I still havent broke the pack open again. I wish I would have fixed it when it was all broken down but was intimidated at the time. I installed a reset switch on my aux ground and basically reset the car when I throw the fault. I dont drive far to work everyday 5.5 miles round trip so the car has been running the same. Installed a Switch to Keep Driving :) | PriusChat
    Ive got some off time coming up and plan on breaking it down to find the fault. I was hoping Id have the block fail so Id know for sure in Techstream what block was bad but no dice. Just ran techstream again today on it and all my voltage and resistances are still the same.
    I will document everything when I do it for other sake.
    Hope its worked out for you.
  17. Lighthouse-Beacon
    56
    44
    FL
    Hey Brad Im attaching my driving and off HV battery voltage and resistance that doesnt tell me anything about what block or how many blocks are bad does it? Do i need to order modules from you after I get in there and visualize for the leaker? will a volt meter tell me? Does it need to be under load?
    Also,
    Do I absolutely have to balance the pack? I was curious if I could attempt to volt match alittle and just put it back together. Getting ready to break the pack down soon and doing some planning....
    Thank you!!!!!!!!!!!!!
  18. Lighthouse-Beacon
    56
    44
    FL
    Yes I ended up replacing the bad module. It was a leaker and the pack was filthy inside. I've moved my work over to this thread:
    Installed a Switch to Keep Driving :) | Page 3 | PriusChat
  19. Lighthouse-Beacon
    56
    44
    FL
    reporting in 5/9/20. I've put 10,000 miles on the 6 modules switch with no rebalance, no errors. still driving.
    strawbrad likes this.
  20. Lighthouse-Beacon
    56
    44
    FL
