Homelink weirdness
Discussion in 'Prius v Technical Discussion' started by rdgrimes, Jun 22, 2013.
  1. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    Has anyone been successful in programming the same garage door remote to all 3 Homelink buttons?
    I'm stumped, if I program the #2 button, it forgets the #1 programming. It might be related to the rolling codes my door uses, cause after I program #2 then #1 acts like it does before I do the rolling code programming.
    In case you're wondering, I'm lazy and don't want to have to fish for the correct button, I want all 3 of them to open my door.
  2. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Are you programing the same garage door? Each button only works for different garage door say if you have garage door # 1 and # 2. If you program the same garage door, it will just transfer the assigned button.
  3. rdgrimes
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    I guess I figured that out, but I don't understand why it does that and wanted a way around it.
  4. ImeanGreen
    547
    73
    Somewhere out there
    It's just simple logic. ;) That's the problem of being lazy. :LOL: The other option is to do what the OP did in this thread.
    Easy "Homelink" option | PriusChat
  5. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I used the first button to the left of the red light on my homelink/mirror. I use the other to the left of that one for the homelink lighting system. Sometimes I press the wrong one and when I come home during the day, I'll walk in and see a bunch of lights on. For the most part it works well. The only remote I can't get to work on my homelink is for the gate to get in my community. This is the third car I've had the same problem with.
  6. Kdedgin
    Kdedgin New Member
    I have all three Homelink buttons on my Prius v programmed to open the same garage door opener. I also have the rolling code type system. I'm like you, I want to be able to push any of the three buttons to open/close my garage door. I just followed the instructions and programmed one button at a time.
  7. rdgrimes
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    You must know some magic incantation, it sure won't work here. Maybe your 2012 has a different model mirror.
  8. totsubo
    totsubo New Member
    Duluth, GA
    2013 Prius v wagon
    I installed an aftermarket Homelink mirror (Gentex GENK40A Homelink Mirror with Auto-dimming, $200 from amazon) in my Prius v and it works fine with all three buttons. I have buttons 1 and 3 open the same door. My garage door is a Chamberlain (purple button).
  9. GerryL
    GerryL Master Model Railroader
    170
    23
    Minneapolis, MN
    I just encountered this problem this past weekend: programming all 3 buttons to one garage door, on both my Prius and my wife's Suburu. It stumped me for half an hour.
    What I did was contrary to the online instructions. Before programming EACH button, I held the first and last buttons for 30 seconds until I got the slow blink, then was able to program each of the buttons individually. Holding the first and last buttons didn't erase the previously programmed buttons at all.
  10. Ed Kaleda
    Ed Kaleda New Member
    I purchased one, but haven't installed it yet. Can you describe the installation process so I don't mess anything up. Ed
  11. tanasit
    tanasit Member
    399
    60
    Philadelphia
    Ditto for me, so I can press any of the 3 buttons to open my garage door. It seems like it has better range (almost full city block) than the included remote controllers.
  12. rdgrimes
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    I've never resolved this issue, I may have to try the above variation. I've suspected it was due to bad instructions. The dealer told me I had to contact Homelink directly, and Homelink was zero help - just kept quoting the bogus instructions. I'll post back if it ever gets resolved.
  13. rdgrimes
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    I fooled around with this some more and failed completely. It may be that my opener doesn't want to play nice with it. My Wayne-Dalton I-Drive manual even has a page on programming with Homelink, but it's just a copy-paste from the Homelink manual.
    Anyway, only one HL button is recognized by the opener, the most recent one I programed.
  14. jzchen
    jzchen Newbie!
    3,296
    1,006
    Arcadia, CA
    Only thing I can think of is a defective homelink mirror. Each button should work independently from the other, otherwise I would suspect your old rolling code remotes do not work once you program a new one? (This would indicate an issue with the door opener.)
    Interesting way to test. If you have two rolling code devices you can program program both, and see if the first one you programmed still works. (Definitely an issue with the HL if the first one no longer works.)
  15. kostby
    kostby New Member
    Some of this 'weirdness' may be with the garage door opener itself, not Homelink instructions nor the Prius. My (2012) Chamberlain chain-drive garage door opener only 'remembers' a total of 3 remote devices, Homelink or otherwise. The prior Chamberlain garage door opener only 'remembered' 2 remote devices. Adding another device erases the oldest one, and so on.
