How are your Multi Function displays holding up?
Discussion in 'Gen 3 Prius Technical Discussion' started by findlj, Apr 6, 2013.
  1. findlj
    findlj Junior Member
    47
    I've got a Type II Prius and have had to replace the MFD a couple of years ago. Note that I bought the car in Sept. of 2006 and a technical service bulletin from toyota was out on the MFD regarding it's failures in Jan. of 2005! :mad: I've heard of several Prius owners who've had this issue. Anyway, I wonder if the MFD's in the Type III's have been reliable or if the same old problem still exists. It's an expensive piece of equipment and, in my opinion, Toyota should've covered this for their customers.
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    F8L likes this.
  3. findlj
    47
    I'm going to correct you here. This was not a multi post. It's two different questions. This one is about new MFD's on the Type III cars since I'm thinking of buying a new car. The second is regarding replaced MFD's on Type II's. Please consider really reading the posts before you decide to chastise someone. ;)
    Now, with that being said, I'd like to hear from Type III owners regarding the reliability of their MFDs. the replaced one in my Type II is starting to act up again. :mad:
  4. p00kienrayray
    p00kienrayray Active Member
    720
    135
    Long Beach, CA
    Haven't had a gen III long enough to give valid feed back. But FWIW, I owned my previous gen 111 for a little bit over a year, and no issues. After a year of surfing through the gen III forums, I haven't come across such an issue.
  5. Jeff_M
    Jeff_M Junior Member
    West Richland, WA USA
    I had the speedometer section of my 2010 liftback burn out during a hightway night trip, a couple months ago. It had buzzed on night trips previously and we had contacted our dealer when we first suspected a problem a couple of years ago. The dealer covered the repair as goodwill even though we were past warranty at time of complete failure. We have one of the early generation 3 builds.
  6. p00kienrayray
    720
    135
    Long Beach, CA
    What was the odometer during the issue?
  7. retired4999
    2,652
    627
    Eau Claire, Wi.
    Had a 2005 for seven years and now a 2012 for a year, no problems!
  8. p00kienrayray
    720
    135
    Long Beach, CA
    7 years no major part replacements? That is why I decided to go with Toyota, and stayed away from Ford/Chevy/Nissan hybrids.
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    Had two recalled water pumps replaced early on, 1st year one engine and one inverter pump, no other problems at all, loved the car. :)
  10. Jeff_M
    Odometer was 36311 miles and functioning at time of speedometer panel failure 3/11/2013. Liftback purchased 6/2009.
