How long can I keep driving after getting P0A80 code (dying hybrid battery)? Options to buy cells?
Discussion in 'Gen 2 Prius Main Forum' started by nathandavidhall, Sep 1, 2020.
  1. nathandavidhall
    nathandavidhall Junior Member
    37
    Eolia, KY
    Did the car have a really tough time going up hills throughout that time? Or did it drive just fine? I don't mind keeping it going a little longer til I can afford a newer one, but the trip I made last week through the mountains of east KY, southwest VA, and northeast TN (almost all 4 lane highways, not crazy mountain backroads) was nearly unbearable with slowing down to 20-30mph going uphills in 60mph speed zones
  2. nathandavidhall
    37
    Eolia, KY
    Thanks for the tips! It looks like hybridautomotive.com also sells individual modules albeit used ones, any idea if they're decent quality? I'm a little spooked by reading lots of bad reviews of HV Hybrid Parts modules on Amazon where people got used modules worse than the ones they're replacing. I'm willing to learn and do some DIY work if I save $$ and get more useful life out of the car, and will do everything I can to be safe as I understand the voltages can be lethal
  3. PriusCamper
    PriusCamper Senior Member
    12,771
    5,174
    Pacific Northwest, USA
    I've not bought modules from Hybrid Automotive, but they've always been generous in fixing problems when things don't go as planned. Though their shipping is a bit slow.
    Have always got modules from my buddy Joe in Bend, Oregon: Refurbished Hybrid Battery Supplier - 2nd Life Battery He has $30K in testing equipment and his modules are always slightly better than the packs I put them in. Keep in mind you're trying to match modules with existing quality, not replace with high quality.
    Don't be too alarmed by the negative reviews. Not many people do this work well and it's a challenging learning curve when you first get started. Deep cycling all modules / reconditioning is essential to success.
  4. strawbrad
    953
    1,007
    If you keep driving that car it's going to get worse.
  5. nathandavidhall
    37
    Eolia, KY
    Can you explain why it's having such a hard time going up hills with one bad battery module? Doesn't seem to be something others with a failing battery have experienced, at least no one has commented directly on that so far
  6. strawbrad
    953
    1,007
    Sure,
    The short answer is that the computers are programed to cut the power when a failing cell is detected. That keeps users from just ignoring the problem until things catch on fire. If you clear the codes your car will have normal power for a few miles until the computer detects the failing cell again. This trick can be used to get you off a freeway or back home. Uber drivers have been known to try this for months. I don't recommend pushing a failed battery that hard.
    The loss of power might not get discussed but it happens with every failed battery. What gets discussed is how to fix the problem.
    tangerino and nathandavidhall like this.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,048
    1,974
    NJ-USA
    The battery pack has 28 modules- in series. Current flow is the same through each module, so you can only use however much capacity is in the weakest module. If 27 modules have 6Ah but 1 has 2Ah, then you have a 2Ah pack. So you don't have much capacity for electric drive.
    In use the weak module causes the voltage on that block to vary too much from the others and the ecu limits electric drive more to try and preserve a little function to get you off the road (and not burn the car down). It will get bad enough that the car won't ready up.
  8. PriusHead05
    PriusHead05 Member
    318
    It didn't seem to have a problem. It was in Florida, though; oher than a trip to Michigan and back. It did fine. It just varies on how long and when it will finally fail.
  9. PriusHead05
    PriusHead05 Member
    318
    It failed while driving in a neighborhood.
  10. nathandavidhall
    37
    Eolia, KY
    Thanks all, so two folks just mentioned the car catching on fire (!!!) while being driven with a bad module, and this is the first time I've heard that as a possibility. Anyone care to comment how likely that is to happen? I'm assuming it's a NiMH chemical fire which sounds very bad, are we talking explosion/car very quickly engulfed in flames kind of situation?
  11. PriusCamper
    12,771
    5,174
    Lithium has fire issues, NiMH does not... I've been on here since 2012 and I've never once seen any mention of a fire from Nickel-Based battery. It's just a flippant statement people make sometimes because they don't know any better.
    To be clear:
    "NiMH batteries are very safe and not particularly flammable. They can vent electrolyte if overcharged, and if the safety vent fails this could result in the cell coming apart, but usually not a fire. This probably wouldn’t happen after the battery is removed from the charger. If any kind of battery is short-circuited, it can generate a lot of heat. This heat can set other things on fire" Can a NiMH HR6 battery explode or cause a fire when it is unplugged from the charger? - Quora
    nathandavidhall likes this.
  12. strawbrad
    953
    1,007
    I would not call battery fires common but they can certainly happen. These batteries demand respect. Only those with a good working understanding of the battery should attempt to work on them.
    Here's a thread I started about a battery fire I had to repair. Battery Fire | PriusChat
    Here's another thread found with a simple search. 2001 Prius Battery Fire | PriusChat
    The attached photos are all shots I have taken of various battery mayhem.
    b22.jpg b21.jpg b20.jpg b19.jpg b18.jpg b17.jpg b16.jpg b15.jpg b14.jpg b13.jpg b12.jpg b11.jpg b10.jpg b9.jpg b8.jpg b7.jpg b6.jpg b5.jpg b4.jpg b3.jpg b2.jpg b1.jpg
    Prodigyplace likes this.
  13. PriusCamper
    12,771
    5,174
    Well yes, if you consider these photos what is meant by "fire." then it does happen periodically when electrical gear fails.
    But In general when people refer to a car fire they aren't referring to the types of failures where battery parts that get fried and smoke a little if it fails to ignite the rest of the car. That's what most people are referring to when they speak of a car fire. As in a car fire destroys the vehicle.
    That's what dogged Tesla for years. It's also what regularly happens with any vehicle powered by fossil fuels. But vehicles that use NiMH batteries don't have anywhere near the concerns that Lithium cars have when it comes to electrical fires.
    I might also add the electrical failures I've experience with these battery packs have always impressed me in terms of the how safe their overall design is.
  14. mr_guy_mann
    4,048
    1,974
    NJ-USA
    Perhaps that was not the most accurate phrase to use. In general all cars are designed to "not burn down", and the prius certainly has show itself to be very safe. In my head I was thinking more of the car is trying to prevent (heat) damage to itself from extreme use/ abuse or mechanical faults.
    Actual burn to the ground fires are very rare.
    I sometimes forget that others can interpret posts quite literally instead of figuratively. It takes knowledge and experience to make that determination.
    PriusCamper likes this.
  15. nathandavidhall
    37
    Eolia, KY
    Checking back into this, could a person theoretically just get one of the iMax chargers and bulb and individually do that procedure with each module, including a replacement refurbished one bought from 2nd life battery or elsewhere to replace my one bad module? Any estimate on how long that would take for a careful first timer? I'm guessing 10-15 hours including removing battery and putting it back in
    It looks like the Prolong charger/discharger setups cost $470 to $680 for my model, are these able to reliably recondition a battery in the condition shown in my earlier Dr Prius screenshot? Would I still need to replace the bad module 4 before using one of those?
    Seems like my options then are: reconditioned 07 battery from 2nd Life Battery guy for $1000 (along with time and effort to switch batteries and ship old one to him), $500-700 for a Prolong reconditioning package (seems like I don't have to take the car apart unless the bad module has to be replaced, and seems like this could be resold on ebay or here fairly easily), or ~$100 for a replacement module, hobby charger, and halogen bulb (much more labor and learning curve/potential to screw up). Does that sound about right? I'm leaning toward one of the Prolong Value Reconditioning packages if folks think they have a good chance of being worth it..
    #35 nathandavidhall, Nov 9, 2020
    tangerino likes this.
  16. nathandavidhall
    37
    Eolia, KY
    PS after some more digging I found a thread on here where someone just dropped in a couple of replacement modules, did no balancing etc, and kept updating the thread everytime they put another 5k miles on the car with no problems.. I'll provide link as soon as I find it again but makes me want to try that and cross the ol fingers..
  17. Prodigyplace
    12,564
    11,779
    Central Virginia
    That is how many places "recondition" the battery, That also means the car could leave you stranded at any time. Other than getting modules from a low mileage wrecked Prius, the only good non-OEM alternative is the kit of new cells from newpriusbatteries for $1600 delivered. The link is in my signature. They have had zero warranty claims or other issues. The "reconditioners" cannot claim that record.
  18. mr_guy_mann
    4,048
    1,974
    NJ-USA
    What you choose to do depends on your available time and money vs your risk tolerance for having an unreliable car. Straight module swap CAN work but who knows for how long- a year, a month, a week?
    I cycled all the modules on my hv pack with hobby chargers and ended up replacing 4. Each module takes 5-6 hours per cycle (depends on the discharge power spec of your charger) and they needed 3 to 6 cycles per module. So all told it was about a month of evenings and weekends to do it all (with several chargers to do 4 at a time). Will look closer at the Prolong system. I did end up with a pack that tests to 5.5 Amp hour and data still looks good after 2 months and 3 thousand miles.
  19. nathandavidhall
    37
    Eolia, KY
    Thanks, also got a reply back from Prolong, they said I'd still have to replace the module but their unit should balance and charge the entire pack once that's installed. Seems worth the cost for less hours involved, especially if it can be resold after.
    Another maybe dumb question, if Dr Prius is showing block 4 with high resistance/ bad, does that mean i need to replace two modules since each block is two modules? Or do I check both modules with multimeter and potentially only replace one?
  20. PriusCamper
    12,771
    5,174
    It can be done with just one SKYRC charger if you're ok with not having the vehicle available for a long, long time. I have seven SKRC chargers and 7 lightbulb-based dscharger and it still takes 2-3 days, so...
