How much time between oil changes?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Mr. Man, Jul 20, 2022.
  1. Mr. Man
    Mr. Man Junior Member
    89
    Chicago
    OK, so I have a 2013 Prius C. I was checking recently to see when the next oil change would be, and the sticker on my car says 65852 miles. Current odometer reading is around 57000 - and I just wanted to check with you guys, am I crazy or is that way to much time between oil changes? 8000 miles? Or is that some convenient quality of the Prius C?
  2. Mendel Leisk
    42,361
    From page 38 of the Toyota USA Warranty and Maintenance Booklet, the regular interval is yearly or 10K miles, whichever comes first:
    I'd concur it's too long. If you want some justification, there's a stipulation (on the same page, to change every 6 months or 5K miles, under "special operating conditions":
    Funny thing: for 3rd gen Prius, Toyota Canada's regular oil change interval is 5K miles (aka 8K kms) or 6 months, whichever comes first. And special operating conditions halves those intervals.
    And, the great white North ain't what it used to be. Our west coast winters in particular are a LOT milder than somewhere like Chicago. Or Alaska... And I've heard something like 90% of the Canadian population lives within 100 miles of the US border.
    #2 Mendel Leisk, Jul 20, 2022
    mikey_t, Mr. Man and Pri3C like this.
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,354
    982
    Monument, Colorado USA
    Unless you drive Uber or a Taxi or for delivery, every 6-months or 5,000 miles, whichever comes first. Oil changes are cheap compared to costs like the engine starting to burn oil or a head gasket going out from dirty oil, etc.
    Doug McC, mikey_t and Mr. Man like this.
  4. Mendel Leisk
    42,361
    Last image in my post above, they recommend the shorter interval, for cabs.
    Mr. Man likes this.
  5. bisco
    52,878
    agree, 5k. does the c have the egr/head gasket issue?
    Mr. Man likes this.
  6. Merkey
    Merkey Active Member
    330
    306
    Birmingham, Michigan
    5 thousand for me too.
    Mr. Man likes this.
  7. Mr. Man
    89
    Chicago
    Thanks for the advice guys, 5000 or six months it is. I really don’t drive the thing as often as I used to, I used to be an Uber driver and now I try to use it as little as possible, so 8000 Miles could conceivably take me an extremely long time to reach, and I just could tell there was no way that was accurate, I’m sure it’ll be six months. And yes, those Chicago winters. They are so great.
    mikey_t, Mendel Leisk and ColoradoBoo like this.
  8. bisco
    52,878
    i go with 5k or one year. i don't see the value in 6 months, am i missing something?
    i figure the change in seasons might create a little condensation.
  9. ColoradoBoo
    1,354
    982
    It's a highly debated topic!
    It's your car so whatever you're comfortable with.....watch this video from a master Toyota technician who's probably seen thousands of engines in his 10+ years of working at a dealership.
    Doug McC and mikey_t like this.
  10. bisco
    52,878
    if he backed it up with some data, i'd go with it.
    gasoline is seeping into the oil even when the engine isn't running? i don't understand this. if you're not driving 5,000 miles, i don't see how it can happen.
    but i only watched to 3:15, is there more?
  11. Mr. Man
    89
    Chicago
    One more thing - is it in my best interest to get the oil changed at a Toyota dealership, or is that just not worth the cost? I always thought it was best to go to dealerships to increase possible resale value, but maybe it’s insignificant in this case.
  12. bisco
    52,878
    i would expect any buyer would be just as happy with receipts from anywhere, showing that it had been done.
    i haven't gone back to the dealer since my two free oil changes.
    iirc, you can add them to your record at toyota.com/owners, where dealer service is also recorded.
    Mr. Man likes this.
  13. Mendel Leisk
    42,361
    I’ve never had any “professional” oil changes with our 2010. Benefits include an engine bay under-panel that is like-new, no missing fasteners, drain bolt threads not near-stripped, no overfill, no great gobs of grease on the door hinges, and no service decals on the windshield.
  14. bisco
    52,878
    what about that time you forgot to tighten the drain plug? :cool:
  15. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    I change at 5k though I did one at 10k and while it felt wrong, I'm hard-pressed to show that it hurt anything.
    There's nothing special about oil changes on these cars. Get it done anywhere you find reasonable confidence and convenience. Toyota will often be more expensive- they're fine, just make sure it's worth it to you.
    For my money, "special operating conditions" aka "severe service" always, always shows up as low miles per gallon. Think police car idling 7 hours a day at the speed trap with the AC cranked. EDIT: More relevant example.
    Taken another way, if you are getting normal MPG, you aren't operating in special conditions or exposing your engine to severe service.
    #15 Leadfoot J. McCoalroller, Jul 21, 2022
  16. PriusII&C
    PriusII&C Active Member
    432
    147
    San Jose, California
    If it is a 2010 - 2014 Gen 3 Prius, I'd go with 5k miles OCI due to the notorious oil-burning issue. But for Prius C, I have never heard of that issue. While 10k miles OCI is preferable, 10k miles is probably acceptable.
    mikey_t likes this.
  17. Mr. Man
    89
    Chicago
    Well second thoughts - with Prius C I need this synthetic oil which is more expensive, so I’m inclined to wait til I really need this service. My main concern is these brutal midwestern winters - is it really vitaI get the oil changed between each winter, even if the car isn’t getting much usage?
  18. bisco
    52,878
    are you saying go longer than a year if you don't hit 10k?
    my mech actually tells me every 2 years, but idk what he bases that on.
    maybe an oil analysis, but just another expense.
    it depends on how long you want to keep it as well.
    Mr. Man likes this.
  19. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    Depends on how that really adds up. If you take a 100 mile trip once a week and that's it, you can run that oil a long time through all weather.
    If it's a 0.8 mile trip every 3 hours, that's different. The engine will never hit full temperature.
    Atmospheric water vapor can and will condense into water through these temperature changes, and it gets whipped into the oil- an emulsion. That's not as good as pure oil.
    Normally, the engine block and the oil temperatures will exceed 212°F, so the water just boils out and exits as steam.
    So if your driving pattern is mostly short trips, I'd recommend changing more often. If you decide to do the minimum annual change instead, I'd suggest doing it in May.
    Mr. Man likes this.
  20. Mendel Leisk
    42,361
    I just change oil/filter mid-April and mid-October. Miles between changes is VERY low; I don't think about it, just do it.
