How often to drain gas tank when only using EV mode
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by idahohacker, Mar 29, 2019.
  1. schja01
    schja01 Senior Member
    1,867
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    How about seals and gaskets? Don’t they need to be lubricated to prevent oil leaks?
    Maybe apples to oranges but I had a spare submersible sump pump I never ran for years until I heard you should run it periodically to keep the seal lubricated. I ran it for a minute and it leaked oil badly. I run the replacement for a short while every few months. No leaks.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    On top of that, I understand that the Prius spins the engine faster during startup than a gasser and doesn't fire up the ignition & fuel till it has oil pressure, so no load on the bearings till there's oil pressure. That would greatly reduce cold start friction and wear.
  3. schja01
    1,867
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    It must do all of that in a sub second timeframe because my Prime and previous Gen 2 started the engine almost instantly. I get the spin up but how much oil pressure and oil distribution could happen in that short a period of time? I’d like it to be true but how can one actually prove it?
    That said I run the ICE weekly “Just because” it gives me a warm fuzzy feeling. I just push the HV button once, wait for the ICE to start and then press the HV button again. The ICE then continues to run for a minute or three depending on what the outside temp was at the time.
    Arctic_White and jerrymildred like this.
  4. Mendel Leisk
    42,232
    I'd be inclined to have a "hybrid vehicle" day, at least once a week.
    Arctic_White and Tideland Prius like this.
  5. jerrymildred
    11,517
    14,164
    Tampa, FL
    I'm not sure how long it takes, but it can't be more than a second. And it's pretty hard to tell if the engine is cranking or running from the tales I've read here of people thinking their Prius starts for a couple seconds and stops when it's actually cranking, not starting, and timing out.
    Arctic_White likes this.
  6. schja01
    1,867
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    My ICE is definitely not just cranking. I can hear the increased engine sound whenI accelerate.
  7. Tideland Prius
    16,665
    Granted my car is still new (although it was sitting around the dealer for 3 months before I purchased it) but after my nearly 70-day experiment in EV-only mode, the gas engine fired up normally when I went into HV mode at the end of the experiment.
  8. srivenkat
    srivenkat Active Member
    596
    93
    IL
    I heard running the engine for too short a time could cause moisture to build up, which is normally expelled when the engine is usually brought up to operating temperature (197F?) with a longer run.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    This is true.
    And the "procedure" you replied to is likely WORSE than just letting it sit......for several reasons.
