How to change inverter coolant 4th gen
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Leksvndr, Dec 20, 2019.
  1. Leksvndr
    Leksvndr Junior Member
    Hello, now I have 115k miles on my Prius. I want to change inverter coolant.
    Do you have any special instructions for it?
    Thank you.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Is this a Gen 3 or Gen 4?
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Profile and thread title are conflicting:cool:.
    If talking about a gen4, I have an underside shot of our Prime with regards to the inverter drain:
    What did you do to your Prime today?
    Maybe we’ll find out soon(y).
    amos likes this.
  4. Leksvndr
    2016 year, I thought its a gen 4
    iLikeTurtles likes this.
  5. krmcg
    2,592
    2,393
    Whittier, CA
    My 2016 is a Gen 4...
  6. Leksvndr
    if there is no resistance as in the photo, then the electric mode does not turn on at all. it began to happen quite often.
    If I drive without stopping for a couple of hours, then the temperature of the battery rises to 115-116 degrees. Is this normal?
    #6 Leksvndr, Dec 22, 2019
  7. Leksvndr
    My Prius is not a prime)
  8. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    The engine bay layout is the same;).
    So why not help us out and eliminate the confusion we asked about:whistle:?
    We will help with more data that doesn’t conflict(y).
  9. Mendel Leisk
    42,373
    4th gen Engine and Transaxle (& Inverter) Coolant Changes attached:
  10. Leksvndr
  11. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    So between @Mendel Leisk ’s manual guidance and the pics I took, you should be sorted:).
    Good luck and keep us posted(y) .
    krmcg likes this.
  12. alanclarkeau
    7,045
    7,593
    It'd be a good idea to change your profile - which shows "2012 Prius Plug-in" - or you'll get this question every time you post (or people will ignore you).
    Leksvndr, Raytheeagle and krmcg like this.
  13. Mendel Leisk
    42,373
    Watch @NutzAboutBolts 3rd gen coolant change videos too, should be similar. Maintenance Mode procedure is handy too, at least for engine coolant change. I'm hitting the wall trying to find 4th gen procedure, guessing it's the same as 3rd gen (attached):
  14. dy/dx
    dy/dx Junior Member
    26
    United States
    Hello,
    My Gen 4 Prius inverter coolant and engine coolant are mixed in the radiator. If I remove the engine coolant, inverter coolant goes down, if I add coolant in the inverter reservoir, it shows up also in the engine coolant reservoir. Is this normal?
  15. Mendel Leisk
    42,373
    I don't think that can be; it's two separate circuits, and two separate zones in the radiator.
  16. dy/dx
    dy/dx Junior Member
    26
    United States
    Where in the system can they possibly mix? Radiator? Thank you for your time.
  17. Mendel Leisk
    42,373
    They can't mix anywhere; it's two separate systems. You can drain either system, without affecting the other.
    This image from the repair manual engine coolant change instruction seems to show the two zones in the radiator:
    Note the hose is shown attached to a higher drain spigot. There's appears to be an extra zone at the bottom of the radiator, with a separate drain spigot (I've coloured it yellow). That I believe is for the inverter coolant.
    Here's the repair manual info for both:
    #17 Mendel Leisk, Aug 3, 2020
    iLikeTurtles, amos and dy/dx like this.
  18. dy/dx
    dy/dx Junior Member
    26
    United States
    Thank you.
  19. Solarj
    Solarj Junior Member
    Central Arkansas
    Do you need the Toyota Tech Stream to run the pump to evacuate the air? I have a 16 I am wanting to do the inverter and coolant replacement.
  20. Mendel Leisk
    42,373
    I can post repair manual excerpts tomorrow, if you’re still interested. IIRC it’s sim to 3rd gen.
