How to clean back-up camera?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by sueNWCal, Sep 20, 2017.
  1. sueNWCal
    sueNWCal New Member
    McKinleyville CA
    It got splashed by someone driving by hitting a puddle and now has 3 big splotches showing on the screen. I couldn't find anything in the owner's manual to fix it.
  2. Clean the lens area with a microfiber cloth. It's like right above the rear license plate.
    bps likes this.
  3. drysider
    drysider Active Member
    823
    337
    Liberty Lake WA
    My index finger works pretty well.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Is this your first vehicle with a backup camera?
    The camera is typically hidden on the exterior just above the rear license plate and quick swipe with a wet clean cloth or similar (or just wash the car) will give you a clear view again.
  5. Just.Drive.It.
    Just.Drive.It. New Member
    27
    25
    Here, There, Everywhere. Driving my Prius!
    A little spit and my t-shirt works well. :D
    bodgm and drysider like this.
  6. Mark57
    2,945
    2,740
    OK
    You're never close by when I need to clean it.;)
    bodgm likes this.
  7. Mark57
    2,945
    2,740
    OK
    Kudos for checking the manual and welcome to the site. It's the little bump just left of the hatch release. A tissue or pretty much will clean it off adequately.
  8. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I use my thumb. No need to use anything fancy. It's on the exterior of the car so is designed for heavy duty use. It's not a high definition camera anyway.
  9. Fester
    Fester Active Member
    201
    198
    Ohio
    Use a soft damp cloth with a small amount of detergent (to remove any oils) then a damp clean wipe and dry. if you don't and just wipe it with anything you can find you will scratch the lens surface because any debris not removed first will scratch the surface.
  10. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Same here.
  11. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    it's glass... unless you got splashed in a diamond mine you'll be fine just swiping with your finger.
    WilDavis likes this.
  12. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Welcome to PriusChat! Well, you can do the "damp-tissue/cloth" solution, as so many others have suggested, or you can head to your local dealer and ask them for their "Special Toyota Approved MajikLensCleaner" imported from Japan, in the special spray-bottle with the Toyota Logo and available for your use from all good Toyota Dealers and accessory stores, for only $39.99/½ fl.oz. bottle, see the pretty bottle? …and how nice and shiny bright it is? ;) (please excuse my jaded sense of humour!) Welcome again, but be warned, PriusChat can be addictive! :)
  13. Mendel Leisk
    42,355
    A bit of spit might help too. Hey, painting archivists use it...
    If you want to get serious: drop by an optician, they might have bottles of glasses cleaner, and a microfiber cloth. I've got some of that, very good formula, use it also on UV filters on camera lens: works completely streak-free.
    Addendum: checked my bottle, google:
    leader lens cleaner
    #13 Mendel Leisk, Nov 8, 2017
