How to drive a Prius Plug in
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by kevgreen36, Jan 9, 2013.
  1. Francos
    Francos Member
    118
    Which way generate more electricity?
    1. Cruising... Foot off accelerator, let car slow down
    2. Gently braking...
  2. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    2 because the lighted area moves further to the left in the braking area of the display. Go to far near the left end of the braking area you are using the friction brakes.
  3. Francos
    Francos Member
    118
    May be about the same, To cruise to stop, the generator kicks in earlier.
  4. CaliforniaBear
    1,180
    289
    Northern California
    More brake pedal, more regenerative braking until you go too far and start friction braking. See this thread. Regenerative Braking | PriusChat
  5. Gladius
    Gladius New Member
    26
    Bay Area
    2014 Prius Plug-in
    Hi - I am reviving this pretty old thread. I need some advice on my commute and how to get maximum efficiency from my new prius plug in.
    I drive about 45 miles one way to work. Home to Freeway distance is around 5 miles, Freeway to work exit is 39 miles and then another 1 mile on surface streets to office. I do have free EV charging at work.
    My return commute is bit tricky though as the freeway (CA 237 E & 680 S) becomes parking lot during the evening commute.
    I will appreciate any help!
  6. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    If your morning run is at highway speeds, start off and remain in pure EV mode and use EV-boost once on the highway above 63-63 mph and the engine automatically starts. That should fully use your wall charge and you can exit the highway and do your best to keep within the EV range of HV mode for the 1 mile city route.
    Recharge at work.
    Leave the city and crawl on the highway in pure EV mode as far as possible. Eventually the engine will start but only for several minutes, after which you will have a fully charged battery and can continue in the EV range of HV mode for fairly long periods, with occasional engine restarts to recharge. The last 5 miles could feasibly be a combination of EV/HV and your overall commute could be impressively efficient.
    Good luck and enjoy your new PiP(y)
    lensovet and Gladius like this.
  7. bisco
    52,746
    the perfect scenario. ^^^ nothing needs to be added.
  8. retired4999
    2,652
    627
    Eau Claire, Wi.
    Purrrrrrrrrrfect!!!!!(y)
    Gladius likes this.
  9. GregP507
    GregP507 Senior Member
    3,002
    481
    The best driving technique for the Prius is to commute to your job 5 miles away, charge up for free at work, and drive home, all in EV mode, with a stiff tailwind both ways.
    markabele likes this.
  10. bjbroswick
    bjbroswick New Member
    Coleman, WI
    So I just bought a used 2013 Prius Plug-In with 48000 miles on it. Went from 2002 Mini Cooper S to the Prius and it has been the best thing ever. I feel like I'm riding on a cloud. Anyway I have read some of this thread and will use some of the techniques as I drive 42 miles one way (84 round) to work M-F and want to maximize the wall charge. Currently I charge up at night, drive in Eco mode into the city then switch to EV mode once off the highway. I do not have the option to charge up at work as some of you mentioned.
  11. bisco
    52,746
    congrats and welcome, all the best!(y)
    bjbroswick likes this.
  12. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Congrats & welcome! With winter coming on you might get a couple extra miles of EV if you use the charge timer function to end your charge shortly before you leave in the morning.
  13. bjbroswick
    Coleman, WI
    The car is kept in the garage. When I get home I plug it in let it charge over night. I have been getting about 14 miles per charge.
  14. Pluggo
    608
    534
    A heated garage will certainly help you hold the charge. Fourteen miles is about as good as it gets. Was your 12V battery replaced. Me? I am wondering if my range is beginning to suffer from nursing the original 12v battery.
