How to tell which wheel bearing?
Discussion in 'Generation 1 Prius Discussion' started by ChapmanF, Aug 31, 2013.
Which bearing do these clues point to?
Poll closed Sep 7, 2013.
  1. Left front
    0 vote(s)
    0.0%
  2. Right front
    33.3%
  3. Left rear
    66.7%
  4. Right rear again (just don't make 'em like they used to)
    0 vote(s)
    0.0%
  5. Need more clues
    0 vote(s)
    0.0%
  1. royfrontenac
    royfrontenac Active Member
    247
    100
    Kingston Ontario Canada
    2001 Prius
    You are right on chap, I will refer to your post when I do a front wheel bearing. I have my own 10 ten ton press in the garage and will refer to your post when I do a front wheel bearing. You are very detailed with your instructions that will help a lot when doing one for the first time.
    Very good post
    Roy from Canada
    #41 royfrontenac, Jan 3, 2015
  2. royfrontenac
    247
    100
    2001 Prius
    Yes that is true, sometimes I try to help but forget the environment that you require to safely do the work - hot oil is a safety problem and should not be used without extreme caution.
    Thanks for bringing this to my attention.
  3. ChapmanF
    18,146
    I'm not the only weirdo who likes to think this way! Check out this nifty app from the same guy who does the Weber Auto teardown videos:
    $400, but cool. Brought to you by Vibrate Software, which is his spinoff outfit.
    -Chap
    mroberds, Mendel Leisk and Fred_H like this.
  4. Mendel Leisk
    41,399
    No extra sensors involved; just the iPhone itself is able to detect/isolate vibrations?
  5. ChapmanF
    18,146
    Pretty much all smartphones include microphones (for rather obvious reasons) and accelerometers and gyroscopes (for some applications you would think of, and various other uses that you might not).
    -Chap
    mroberds and Mendel Leisk like this.
  6. Mendel Leisk
    41,399
    I find it astounding though, that the phone can pinpoint an issue, just hand-held, just positioned "somewhere" in the car's cabin. That's it, no additional mikes or whatever?
    I know (with the app "cardio) it can turn on the camera's light, and when you cover it with a finger, determine your pulse rate. I'm mildly amazed by that, lol.
  7. ChapmanF
    18,146
    Did you watch the video? The whole idea is that the things that need to be distinguished from each other have characteristic frequencies based on known gear ratios and related to the speed of the car. So the thing needs to know how fast you're going (GPS on board phone) and your tire revs per mile, and do a Fourier transform of the all the vibrations it's picking up, and tell you which of the strong components match which known frequencies for the car at that speed.
    ... as was pretty much the approach going on earlier in this thread in post 25, and in my thread that preceded it where I was hoping to decide whether a noise was a bearing or MG2. (Only instead of a phone app doing a Fourier transform, I just had me going "ehh, sounds mostly somewhere between d and d flat".)
    -Chap
    mroberds likes this.
  8. Mendel Leisk
    41,399
    I had sound problems, halfway through the video. Thanks for the overview. That's impressive.
    Another problem: I always nod off, watching that guy's videos.
  9. ChapmanF
    18,146
    I use the speed setting a lot on youtube vids. It does pitch-correction on the audio, so it doesn't turn people into chipmunks, you just get through the video faster.
    -Chap
  10. rogerdpack
    rogerdpack Junior Member
    79
    Enoch, UT
    Do you think you needed the car "running" to hear the noise, or was any diagnosis possible with it jacked up? (basically, does chassisear work with it jacked up too?)
    Update: This thread mentions at least one way... All signs point to wheel bearing but it's not | Page 2 | PriusChat
    #50 rogerdpack, Sep 17, 2025
  11. PriusTech
    PriusTech Active Member
    247
    105
    Reno
    Left rear. The G-load of a right turn making it louder. Have someone else drive it, sit in the back and lean your head out the window. Or drive along a wall and open the left then right windows, the noise will reflect off the wall.
  12. dabard051
    dabard051 Tinkerer-in-Charge
    258
    97
    Rochester, NY USA
    2002 Prius
    <Bump> The only hard thing is determining whether the noise is from front or rear.
    PriusTech (above) has an excellent suggestion about finding a quiet stretch of wall along which to drive and listen.
    The back of a shopping mall is suitable, after closing time.
    IMHO, replacement of bearings should be done in pairs (do both rears or both fronts at the same time) since it is likely that both bearing sets are at very similar points in their wear-out characteristic lives. Plus, if you're already set to do one side, it's a heck of a lot easier to do the other side at the same time.
    The bearings (front or rear; relative to the total time/labor expense) are relatively inexpensive.
    For Prius drivers north of the Mason-Dixon line, it's likely that corrosion will play a significant part in the difficulty of any bearing removal.
    For the fronts, have a friendly machinist available with a good press. That machinist's vocabulary will expand.
    For the rears, knock out two of the wheel retaining studs on the old hub assembly and use a pair of (4-inch long, 1/2-inch diameter) bolt and nut to extract the bearing from the bearing mount after removing the rear brake parts. I found liberal use of penetrating oil (Liquid Wrench) and patience (let the oil get to where it's needed, and it takes some time) is also very helpful.
  13. ChapmanF
    18,146
    I attached the ChassisEar as a last resort after every other piece of "shake this or do this and listen for this and it'll definitely tell you which bearing it is" definitely didn't.
    I've definitely found bad bearings to spin ok when the weight is off, so if I were going to use a ChassisEar for diagnosis I would definitely just attach it and go for a drive.
  14. beardlesswhelp
    beardlesswhelp Junior Member
    US
    Chapman, nearly 12 years later, your fastidious work is saving my bacon. I recently (a few thousand miles ago, now) developed a front-end hum and have been trying to diagnose it.
    Just before it began, I redid most of my front suspension, but I also installed new tires, balanced and realigned, and replaced my transaxle fluid. During the front end rebuild, I accidentally pulled an axle out of the transaxle and it popped the inner joint boot off at the same time, losing some fluid and grease that I didnt have time to replace, and I also had to torch both ball joints and use a cutoff wheel on one of them to get them off the knuckle. Sheesh! So I was worried that either I screwed the transaxle running it with low fluid, or I toasted one of the wheel bearings.
    The noise is perfectly linear with speed/MG2rpm. Earlier today, I had the idea to match pitch of the noise and relate it to MG2 rpm and wheel rpm, to see if I could determine the source. After doing that, I figured someone here might have done the same before. Et voila; you have provided, many years prior!
    I was matching pitch using my voice and a piano tuner app, and my GPS speed and MG2 rpm readings are not the most accurate, but I figured a very rough ratio of 3:1 noise Hz/MG2 rps, and ~13:1 noise Hz/wheel rps. E.g. my wheels are rated at 825 revs per mile (13.75rps @60mph), the noise was ~180Hz at 60 mph, with a MG2 speed of ~60rps.
    3:1 Hz/MG2rps wouldnt make any sense from a harmonic perspective for the MG2. But 13:1 is pretty darn close to your theoretical and more robustly data-driven 12.8:1. I may try and get better data on my next few commutes to further refine my calculations and see if they converge.
    Looks like I may have cooked a bearing, or damaged it on a bad pothole (I do a lot of driving around scrap yards and quarries for work, the suspension takes a beating). I'll try to do a thermal imaging comparison next, and then maybe rig up some sort of audio sensor—or maybe I can use this as an excuse to buy the Steelman wireless kit.
    I suppose it could be an inner axle bearing at the transaxle, so hopefully another test will narrow it down.
    Anyways, thanks for all your work and helpful posting!
  15. ChapmanF
    18,146
    Glad that exercise is helpful to someone! (y)
    I should be clear the 12.8 that I came up with was heavily dependent on the dimensions and arrangement of a gen 1 Prius front bearing.
    The methods I used to compute it should be applicable, I hope, to another bearing if you know its dimensions and details and number of balls ... but I haven't got those specific details for any Prius generation besides gen 1 (or even for the rear bearings in gen 1).
