Hybrid battery balancing
Discussion in 'Gen 2 Prius Technical Discussion' started by Jonscheets, Sep 26, 2017.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    I use a red lead and a black lead on each channel, connected directly to the (+) and (-) terminal of the module. I don't use any of the other connecting points/plugs.
    C Wagner and Prius Jas like this.
  2. Prius Jas
    Prius Jas Junior Member
    Western Australia
    Thanks
    Much appreciated. Trying mine out this week.
    Raytheeagle likes this.
  3. Hybrid Battery Exchange
    83
    93
    Gresham, OR
    I had the same problem once I started doing more than 1 battery at a time. The solution wasn't available to buy, yada yada yada and I ended up with a high voltage battery cycling system with fully automated workflows, smart charging/discharging and graphing/logging. It's true when they say necessity is the mother of all inventions.
  4. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    So what do you do to balance them all at the end once they are all cycled and full TMR-JWAP? Do you discharge them to same voltage, or just done with it?
    rekonditioned and C Wagner like this.
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,097
    6,963
    Texas Hill Country
    For anybody new to this discussion and facing the issue of a dead Prius HV battery, I throw my hat into the following viewpoint in quotes below. I believe most people are not ready to tear apart the back end of their Prius, disassemble a complex and powerful battery module just to wait while they buy individual modules and specialized high dollar chargers. On a hope and prayer it all works. Usually people want something fixed reliably and forgotten about until they sell their car. Does anyone buy and recondition used 12v batteries, used water pumps, or used alternators? I realize we are talking bigger money but then again a Prius may well of saved someone $10k over 200k miles already. This discussion is not just for 2009 or earlier model years, generation 3s are now dealing with it.
    Further Jadziasman thoughts:
    "If your Prius has relatively low miles <150,000 you should splurge for a brand new pack from Toyota. If more than 200,000 miles the decision is easier; do a DIY repair and balance and be happy with doing so every year or every other year if you are lucky. Modules will continue to fail as the years and miles pass by."
    "Whatever you do, don't spend upwards of $700 on a fancy charger/intelligent discharger. It's not worth it with an old HV pack like yours. You can charge the pack with a less expensive pack level charger ~$300 and use incandescent light bulbs of decreasing wattage to discharge it to regain some lost capacity."
    "A pack level charger has many advantages - the one I think is best is the ability to charge and discharge the pack in the car without removing the interior panels or the pack itself. But when a module fails.....it's disassemble city no matter what you have."
    "There is no "approved" written procedure for balancing, it's not as simple as that - unless you get the system @Prodigyplace just mentioned. These systems do have procedures unique to their equipment and work well."
    "New Toyota batteries from a dealership can be had for about $2100+tax if you install it yourself. First you must pay a $1350 core charge which is a PITA but unavoidable if you DIY. Another issue is getting a dealership to actually sell one to you - many will not. There are some independent hybrid battery installers who have very reasonable prices and the two I know of are located in Texas and Florida. The one in Florida would be a possibility for you once you repair the pack sufficiently so that your Prius could make the trip there."
    "Don't even consider a refurb. I don't know enough about the Bumblebee battery except that it is new and may contain cylindrical modules - not the prismatic modules that the OEM battery pack contains."
    "So there are your two options - do a DIY with a brand new pack or go to a installer who does it all of the time. I considered the latter the better option after my pack failed because the price difference between DIY and installer was not very much. The hybrid battery installer gets to keep your old pack which usually contains about 10 to 15 good modules that he/she can use to make a refurb pack with. You get a brand new battery, installed for you, without the hassle of a core charge or a search for a dealership willing to sell you one."
    #jadziasman, Sep 26, 2017
    #65 rjparker, Sep 1, 2018
  6. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    What about if you start at 5000mAh instead of the 530am you choose? What would happen? I just got the CQ 3 chargers also.
  7. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Dxta,
    The 530am is actually (5:30 am). Since my CQ3s seem to only like performing one discharge/charge cycle at a time, I start a cycle just before leaving for work in the morning (5:30 am). Then, when I get home from work, I record all that data and start another cycle at around 5:30 pm. This way I get 2 full cycles performed each day.
  8. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Is it on, if I set the cutoff capacity to first 2000mAh, at the first charge, then the second cycle can be stepped up maybe to 4000-5000mAh?
    In my case, power supply in Lagos, Nigeria, is t stable. So, can't use the time format.
    What do you suggests I use as my settings for the discharge/charge cycles?
    Thanks
    C Wagner likes this.
  9. Cody26
    Cody26 Junior Member
    86
    Raleigh, North Carolina
  10. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Hi. I got some cq3 chargers last month. Please what sort of setup settings do you employ?
    Please correct me, if my setup is wrong.
    1. Discharge 6.0V
    Discharge current 5.0A
    2. Charge current 1.2A
    3. Cutoff capacity 7000mAh
    My observations:
    1. At this setup, the charging of the modules, seems not to get to the set capacity (7000mah). But tends to stop at maybe 1000, or sometimes 1830mah.
    2. Other times, when charging/discharging, I get to see DRY displaying on the display screen of the charger.
    What do you think could be the problem with my setup?
    Thanks
  11. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I don't think there should be any balancing done again. The chargers takes care of all that.
    If you were using any hine made customized chargers, that's when you'd maybe think about how to balance them
  12. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    I'll get the total setup when I get back tot he shop later today but I believe:
    Discharge to 5.8v
    Discharge current is set to 1.5 amps (actually electronically limited due to the 10W limit of the CQ3)
    Charge current at 2.0 amps
    Charge limited to 7200 mah
    safety timer off
    delta set to 20mv
    I'll verify these and get back with you this evening
  13. Cody26
    86
    Then they will be at different volts?
  14. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Thanks for the reply. Expecting you when you're home then.
  15. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    OK, maybe top up some of the voltages of the modules, to make them uniform.
  16. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Here we go.
    On the PROGRAM SELECT---USER SET menu:
    Precharge Time ----OFF
    Wait Time---CHG>DCHG----20min
    NiMH sensitivity D. Peak 20mv/cell
    NiCD sensitivity D. Peak Default
    Temp Cutoff......OFF
    Safety Timer......OFF
    Capacity Cut-off......7200 (I vary this anywhere from 5000 to 8200 depending on the modules)
    Input Power low Cutoff.....11.0v
    Key Beep....ON
    Buzzer.....ON
    Back Light.....50%
    Battery end volt LiPo...4.2v/c
    Then PROGRAM SELECT----NiMH Battery
    NiMH CHARGE Man
    CURRENT 2.0A
    NiMH CHARGE Aut
    CURRENT 2.0A
    NiMH DISCHARGE 1.5A 5.8V
    NiMH CYCLE D->C
    C=2.0A D=1.5A 1
  17. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Thanks a thousand, sir! Would try this out with some of the modules I have in the garage.
  18. R-P
    R-P Active Member
    808
    288
    Netherlands
    Do your chargers switch off through their delta V setting? I bought a couple of B6 (most likely clones) and only the 50W version seems to work. The two 80W versions don't detect any delta V and are therefor worthless unless you gamble with capacity cutoff.
    Never did anything with Prius batteries yet, still gaining experience with electrical bicycle batteries. My original 20 D-cell serieswired 24V NiCd had very limited range. Two cells were dead, brought them back to life with lagre current spikes (30V 0.2F capacitor shorted a dozen times made it come to life) but it didn't last. Got some free different bicycle batteries (they get thrown out because the electronics guarding them are horrible, a little moisture and the battery fails to communicate with the 'brain' of the bicycle and cannot be used anymore even though the cells may be in excellent shape), but also 20D-cells but now NiMH (one of 9Ah and one of 10Ah) Tested these by charging 10 series wired batteries per charger and ran into those "not detecting delta V" problems. Obviously too late to send them back to China or get refunded as they don't do what they are supposed to do...
  19. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Hmmm! Chinese stuff? Well...
    bej likes this.
  20. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Hmmm! Chinese stuff? Well some of them seems to be great.
