Hybrid Charge Mode Question
Discussion in 'Prime Main Forum (2017-2022)' started by Wattup, Jan 25, 2017.
  1. bisco
    52,910
    how did you force charge the battery with a cold engine?
    i think you have to go with efficiency. mpge?
    #41 bisco, Jan 29, 2017
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Comparing MPG to MPGe is an entirely invalid comparison.
    52,910
    well, there has to be a way to compare mpg with force charge and without.
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Prior to arriving at the timeshare or before returning from a long side-trip (sight-seeing, shopping, dinner, etc), while still out on the open road when the engine is already warm.
  5. bisco
    52,910
    so you force charged it the day before, so you could drive 3 miles in the morning without the warm up penalty?
  6. Lee Jay
    5,850
    4,036
    I just did above.
  7. john1701a
    12,840
    5,312
    58
    Yup. Note the pool & bar are nearby too. So, the planning ahead works out nice.
  8. bisco
    52,910
    no, you converted ev miles to mpg and added it to the hv charge mpg. what would the mpg have been on that trip if he hadn't used force charge?
  9. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    For the old Prius, it cost me 25 cent to charge it. The Prime is double the size, so say 50 cents to charge.
    What is the cost of Gas to charge the battery? Due to ineffiency to convert from ICE to Generator to Battery, I would guess More.
  10. bisco
    52,910
    but you need to know the force charge efficiency hit, compared to the warm up hit, to see if it makes sense.
  11. Lee Jay
    5,850
    4,036
    I posted a link to Bob's plot showing it would have been about 56mpg at 65mph.
  12. bisco
    52,910
    his chart shows 56 mpg at 65 mph for the pre production prime? vs 37.5 mpg with 6.5 miles of ev created?
  13. Lee Jay
    5,850
    4,036
    Look for yourself:
    Prius Prime Plus in my hands | Page 4 | PriusChat
    Which, once you add in the 6.5 miles of Ev, you end up with 57.35mpg. (12+6.5 = 18.5, 18.5/12 * 37.5 = 57.8mpg (I must have made a small typo before).
    I'd call those the same, within measurement uncertainty.
    I still suspect that using charge mode in the right circumstances will improve mileage, even if you aren't using it to avoid warm up cycles. I lack the necessary data to prove it.
  14. Pizza Driver
    Pizza Driver Active Member
    158
    156
    United States
    This would also need to take into account the temperature, with the warm-up cycle lasting much longer in winter than in summer.
  15. bisco
    52,910
    how could force charging possibly improve mileage in any circumstances? and how can you compare 1200 mile average to 12 mile experience?
  16. Lee Jay
    5,850
    4,036
    I still suspect that, in light-load conditions in Hv mode (i.e. steady 30-40mph, or slight downhill at highway speeds with the engine propelling the car), the improvement in engine efficiency from adding load (by forcing it to charge the battery while still propelling the car) will outweigh the in-out losses of charging.
  17. bisco
    52,910
    seems counter intuitive, but i look forward to real world data.
  18. Wattup
    Wattup Junior Member
    I did some reading on other threads and read that it costs about a 1/3 gallon of gasoline to hybrid charge to 80% so I did some math.
    1/3 gallon to 80% charge
    1 Gallon = 55 mpg city - 1/3 of that is 18.3 miles
    80% of a fully charged battery will give you 20 miles
    So theoretically does this mean that using a 1/3 of a gallon to 80% charge give you an extra 1.7 miles of driving? Please correct me if I'm wrong.
  19. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
  20. bisco
    52,910
    your math is correct, but the 1/3 gallon you read about is suspect. i don't think we have any data. that would take a special machine, and more than just user observation.
    giora likes this.
