Hybrid malfunction warning (light)
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Lievre23, Jun 2, 2019.
  1. Lievre23
    Lievre23 Junior Member
    Wading River, NY
    My Prius Prime was rear ended a month ago (minor damage). After getting it fixed - 3 weeks later I got a Hybrid System malfunction light in the car. It brought it back to collision company, they reset computer and the error went away.
    Yesterday it came back on again.
    In addition it appears to me that the gas engine is not working as it should and the battery are overworking to move the car. The MPG on the car is above normal.
    48,974
    you're probably the victim of an overactive imagination.:p
    the hybrid warning though, that's nothing to ignore. you're going to have to have the codes read, and if it is related to the accident, have the repair shop bill the insurance company.
    resetting the code just resets the code, it doesn't fix the problem. they probably missed something while they were in there, body work hybrids takes extra skills.
    Lievre23 likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    The collision may have caused an intermittent ground fault or some other issue. It might be as simple as a loose connection from the jolt. As @bisco said, you have to read the codes to know what it is.
  4. Lievre23
    Wading River, NY
    Thanks. I’m going to bring it back this week.
    The MPG is way above. I am use to getting 50-60mpg, but at times it is getting closer to 80mpg.
  5. jerrymildred
    11,491
    14,100
    Tampa, FL
    Those mpg numbers are a real mystery to me unless it's using up your EV range and not replacing it. Hmmm That give me an idea. If the fault is in the charging circuit, it might let you drive a while before it notices the problem. If so, you should see EV range going down even in HV mode. I'm just guessing, though. It needs attention from a dealer or other Prius pro.
  6. bisco
    48,974
    i say let it be (y)
  7. Lievre23
    Wading River, NY
    When I switch to the energy use screen on display, it appears very little energy coming from engine.
  8. bisco
    48,974
    impossible to get better mileage without the engine, unless you're running on wall charge.
  9. Lievre23
    Wading River, NY
    I don’t get it, can’t explain it: I’ll hope to get it solved early this week
    jerrymildred and bisco like this.
  10. jerrymildred
    11,491
    14,100
    Tampa, FL
    From my manual (emphasis mine):
    So do not ignore this.
  11. Salamander_King
    Salamander_King Senior Member
    10,964
    8,840
    New England
    You mean the difference in mpg is all on HV mode with no EV range left? Are you charging the traction battery?
  12. Lievre23
    Wading River, NY
    Drive to work today (mostly highway) No warning lights were on. See pic below...fir those of you who ay attention to these details, does this seem normal?
  13. jerrymildred
    11,491
    14,100
    Tampa, FL
    It would depend somewhat on how hilly and how many stops. Given your average speed, I'd say it's entirely within the normal range. I sure wish I could average 49 mph on my drive to work. I do well to average 20, and the speed limits are 40-50.
  14. Lievre23
    Wading River, NY
    Pretty flat. Long Island Expressway
  15. Salamander_King
    10,964
    8,840
    New England
    I don't see anything out of ordinary. What part of this screen do you see something is abnormal?
  16. Lievre23
    Wading River, NY
    Brought it to dealer. After a day they figured out the negative battery terminal was loose - which is causing the warning lights and the above average MPG
    lizardskin and Salamander_King like this.
  17. Salamander_King
    10,964
    8,840
    New England
    Glad to hear they solved a mystery. Just curious, was the above average MPG you were seeing just a computer glitch or was it real mpg improvement? If it was REAL, I am going to loosen my negative battery terminal. lol :ROFLMAO::ROFLMAO::ROFLMAO:
  18. kevin.c
    kevin.c Member
    98
    76
    sf bay area
    Yeah I kind of don't believe them. The ground was loose, so the car thought it should use more EV and run the engine less? Maybe they're just trying to avoid diagnosing the increased MPG / get you out the door.
    Salamander_King likes this.
