Hybrid specific oil: Do we need it?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Marine Ray, Dec 9, 2019.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    "Our advice: There’s no need to yield to dealerships or service shops suggesting that you should follow a dramatically tighter service schedule because you have a hybrid. Stick to the intervals recommended in your owner’s manual, and a formulation like this is probably a good pre-emptive measure."
    Valvoline released a hybrid-specific motor oil: Do you need it?
    TGrracie and douglasjre like this.
    52,399
    marketing 101, toyota oem, mobil 1, or etc
    TGrracie, jerrymildred and MTN like this.
  3. Marine Ray
    1,139
    947
    Sparks, NV
    Pennzoil website says their hybrid oil only 0W-16. So that's for the 2020 Prius Prime only. 2017-19 Prius Primes use 0W-20.
    TGrracie and MTN like this.
  4. Mendel Leisk
    41,925
    I really doubt there's any difference between 2020 model year engines and previous. Apart from the piston/ring revision, I think the 3rd/4th gen engines are identical. There are obvious differences in the bolt-ons too, the oil filter bracket, the EGR system, intake and exhaust manifolds. But the internals of the engine, the same?
    Accordingly, I wouln't say that one model year engine "needs" 0W20, and another 0W16. It's more just that Toyota's policy has changed.
    The Prius 3rd/4th gen 1.8 liter engine is also used, essentially the same, in non-hybrid Corollas.
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    IIRC, Gen2 Prius PHV (model ZVW52, aka PRIME in the US) in Japanese market always had factory suggested 0W-16 oil. The reason US version (and maybe other regions?) had 0W-20 was due to availability issue, not because of any mechanical differences. Now, 0W-16 oil are starting to show up on a shelf of many auto stores including Walmart in the US, Toyota must have changed the recommendation. I am thinking to use 0W-16 oil for the next oil change on my 2017 PRIME.
    #5 Salamander_King, Dec 9, 2019
    TGrracie and Mendel Leisk like this.
  6. Marine Ray
    1,139
    947
    Sparks, NV
    Does 0W16 provide any better fuel economy?
  7. Prodigyplace
    12,682
    11,833
    Central Virginia
    Probably marginally better fuel economy but, more important to Toyota, likely increased engine wear too so it will need to be replaced sooner. The engine only needs to last long enough to satisfy government regulators.
  8. MTN
    MTN Active Member
    306
    276
    SB, CA
    Right. /sarcasm
    Just like 0w20, and 5w30, and ... before. All the "car guys" said "That stuffs water" and your engine will be smoking and breaking down in no time.
    Change the oil when and with what the manual spec's and the chance of having an oil-related problem are very, very low over the lifespan of the vehicle. Design issues are much more likely to present a problem - e.g. Hondas/Mazda with fuel dilution issues. Subarus and headgasekts, etc.
  9. bisco
    52,399
    they'd be recommending water now, if it raised mpg's and got most engines past warranty
  10. The Big Sleaze
    291
    67
    'frisco
    2020 Prius
    Two Eco
    I'm thinking depends on your local temps. If you live in warmer temps then use the heavier oil since it will still flow at startup and warmup, if in colder region use thinner to get more flow when cold/cool.
  11. Leadfoot J. McCoalroller
    8,149
    7,654
    Pennsylvania
    2018 Prius c
    The products with the least actual differentiation get the most advertising. See flashlight batteries & motor oil for examples.
  12. Marine Ray
    1,139
    947
    Sparks, NV
    Does insurance qualify? Most insurance is the same cost. Most insurance ads are iconic or have some sort of catchy mascot (AFLAC geese, GEICO gecko, PROGRESSIVE)
  13. Leadfoot J. McCoalroller
    8,149
    7,654
    Pennsylvania
    2018 Prius c
    Oh absolutely. High margin, no difference from one to the next... yep they'll pour piles of it into the ad budget.
    Marine Ray likes this.
  14. Prodigyplace
    12,682
    11,833
    Central Virginia
    Until you need to make a claim. In my experience, service from insurance companies varies widely.
  15. Dennis G Waller
    Dennis G Waller Junior Member
    Bellingham WA
    2018 Prius Prime
    Mendel: Can you provide a reference for the changed "piston/ring revision" on the 2020 Prius Prime? Dennis Waller
  16. Mendel Leisk
    41,925
    2010 to partway through 2014 used pistons:
    13101-37120
    And rings:
    13011-37110
    Remainder of 2014 and 2015 used pistons:
    13101-37240
    And rings:
    13011-37260
    2016 onward used pistons:
    13101-37250
    And rings:
    13011-37270
    As far as I know, those last two part numbers are still what's used, for 2020 Prius and Prius Prime. You can verify by checking the various years, searching for "piston" and "piston rings", on an online Toyota parts retailer. McGeorge Toyota Parts is one.
    The object, with the first change was to reduce oil consumption. From what I've read the piston ring outward "spring" was increased, and the oil drain channels improved.
    I would guess the second revision, with the advent of 4th gen, was just a further refinement.
  17. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    The first number tells you what viscosity grade the oil conforms to at low temperatures--so in a warm climate you could get away with a higher "xW-". But regardless of outside temperature, your engine operates at the same temperature well above ambient, around 90-100C, where the second number denotes the viscosity grade (at 100C). So why would you want to move to an xW-30 from an xW-20 if the operating temperature hasn't changed? If xW-20 was fine in freezing weather, it's fine in Death Valley in summer.
  18. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    I generally try to avoid discussions related to motor oil because they tend toward the theological.
    However, one consideration is how oil viscosity varies with temperature. The synthetic oils tend to remain fairly constant over the wide range of temperatures from sub-zero winter starts to cruising across Death Valley in summer. There are some graphs of viscosity vs temperature available on several of the manufacturers' web sites.
    Another issue is the tolerance between moving parts such as rings and cylinders -- which also change with temperature because different metals expand a different rates. I am sure that there are mechanical engineers who can discuss this in much greater detail. It is a subtlety well beyond my limited expertise.
    Personally, I just follow the recommendations in the owner's manual. I have enough other issues to obsess about. ;)
    Raytheeagle and Prodigyplace like this.
