Hybrid system failure
Discussion in 'Prius c Technical Discussion' started by fermuscolo, Dec 9, 2017.
  1. fermuscolo
    fermuscolo Member
    53
    38
    Hi. My 2012 Prius C 1 at 63000 miles showed the "Hybrid system. Bla bla" ITake it to the dealer and they say the two batteries where bad. They changed and pay for the 12v battery. At next day the same message. Take it again to dealer they have it for 10 days. Get the car and 2 weeks later again. Take it to dealer again and 10 days later they change the already new 12v battery because was bad. Today again but I see that traction battery was at 1 bar and never see that in the car and remember that last night it was almost full. I leave it charge for a while and with Torque app and a bluetooth scanner cleared the faults and the car run normal now. Something is discharging the traction battery and its a month old. Any ideas?Obviously dealer have none
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    I'm not sure about the traction battery drain.
    I would want hard evidence to quantify it.
    Write record SOC at time of shut down as well as voltage for each hv battery block. This could be done using just a screenshot.
    Then do the same thing at start up.
    Prodigyplace likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,915
    Columbia, SC
    Although I am not very familiar with the C model, a battery is a battery. Just for clarification, the dealer installed a new 12v battery and a new HV Battery?
    The last past of your post mentions you reset the faults and the car drives normal again. Do you happen to remember what those codes were?
    It would certainly be worth looking into the 12v system to see if it's being drained while the car is off. If that is occurring, start with that path.
    If 12v checks out good, what things could be occurring with the HV battery? It really is being drained, it has a weak module issue, a ground isolation issue, or merely an "sensor indication" issue.
    The odds of a 2012 60k mile HV battery failing are slim. Not impossible, but slim. If the dealer installed a new HV battery, I would assume a C battery is installed the same way as any other HV battery. The new module pack uses the electronics package originally attached to the old battery pack. If the new HV battery is exhibiting identical symptoms as the original, I would have significant doubt that the module pack was faulty and would focus more on the electronics portion and where the HV battery status transfers to the car network.
    fermuscolo and Prodigyplace like this.
  5. Prodigyplace
    11,696
    11,318
    Central Virginia
    The way I interpreted the OP, the dealer said both batteries were bad but only replaced the 12 Volt battery (twice!).
  6. fermuscolo
    fermuscolo Member
    53
    38
    Yes the first time new 12v and traction battery. The second time nothing cganged. 3r time again changed the 12v. Right now dont remember right now the code but the web lookout says is a defectice tractiin battery. But is almos new. Maybe something is breaking it.
  7. Prodigyplace
    11,696
    11,318
    Central Virginia
    Some dealers sell "remanufactured" traction batteries. They can have a tendency to fail.
  8. fermuscolo
    fermuscolo Member
    53
    38
    They assure me that toyota doesnt remanufacture. But who knows
  9. Prodigyplace
    11,696
    11,318
    Central Virginia
    I remember some people listing a Toyota part number dealers used for a battery that had been remanufactured by a third party. Basically they "repair" it with used parts & test.
    Perhaps @Raytheeagle remembers what I am referring to . I do not remember which generation Prius had this, though.
    Raytheeagle likes this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    What the part number will have is a -84 at the end of it.
    I believe this was only available in So Cal.
  11. fermuscolo
    fermuscolo Member
    53
    38
    Yes I not trust these guys. Anyway makes sense what @TMR-JWAP SAYS. Something like the electtonics that control the battery. Since this morning the car is parked and today didnt discharge anything so maybe is something intermitent. But Now Im gonna pay close attention to the level when I stop the car and at next startup.
  12. Prodigyplace
    11,696
    11,318
    Central Virginia
    Thanks.
    Since the OP did not even reveal their country, they may well be in California. I do not know.
  13. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
  14. fermuscolo
    fermuscolo Member
    53
    38
    Sorry. I live in Puerto Rico
    Raytheeagle, bisco and Prodigyplace like this.
  15. bisco
    49,490
    how are you folks doing down there? i hear it is still pretty bad.
    Prodigyplace and Raytheeagle like this.
  16. fermuscolo
    fermuscolo Member
    53
    38
    Im well I had water all the time, power plant for the firstm month then electric power come back here. In the house nothing happened but the country is in bad shape. Almos half without power. I don have internet and cable, only in the phone and last couple of days it became usable. It was something mayor. Thanks for asking
    Raytheeagle, Prodigyplace and bisco like this.
  17. bisco
    49,490
    glad you're okay, praying for all. sorry i can't help with the issue, hope it works out. how many miles on your c?
  18. Prodigyplace
    11,696
    11,318
    Central Virginia
    63000 miles. See post 1
  19. bisco
    49,490
    wow, that is very low for new batteries to be needed.
  20. bisco
    49,490
    we seem to be seeing a lot of hybrid system alerts on prius c, i wonder if there is an issue?
