Hybrid System Issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by crasy169, Apr 1, 2026.
  1. crasy169
    crasy169 Junior Member
    Gatesville, TX
    SE
    I could really use some guidance for this. My wife's 2007 Prius has developed some kind of issue with the hybrid system. Initial troubleshooting was leading me to potential intermittent inverter water pump issues. Each time I checked it seemed like it was moving coolant at a good rate, but i replaced it today anyways with a genuine part from Toyota. The issue was not resolved by doing that.(Didn't think it would be.) The diagnostic software that I have is Autoenginuity and I'm sure it has its limitations. From what I can tell using the software the battery seems ok as the 14 modules all show as even and the temperatures are close to ambient temp across the three sensors. I can hear the hybrid pack fan running at high speed. The car runs and drives and reduced power.
    Screenshot of current error codes.
    Previous codes before clearing.
    Please let me know what other info is needed to help troubleshoot this. Hoping its not the hybrid pack or the inverter at this time.
    52,807
    have you opened up the battery to look for corrosion?
  3. crasy169
    Gatesville, TX
    SE
    As in the 12 volt battery in the trunk. All connections there are clean. The hybrid pack I have not touched other than removing the orange cut off when I had to remove the inverter to replace the ABS module months ago. I verified that all connections are right in the inverter after these codes started appearing. Zero corrosion was evident on any of the connections.
  4. ChapmanF
    18,993
    Autoenginuity is showing you the brake system codes (C1259 and C1310) that are present because of the HV ECU P3000 code, and the P3000 code is present because because of the HV Battery codes it's saying it didn't retrieve.
    Not sure if that's because the battery ECU really isn't reporting any codes, or this scan tool isn't able to see them.
    If you're sure of the scan tool (say, it's Techstream or something else definitely known to see battery ECU codes) and there's a P3000-123 with no battery ECU codes showing, then the P3000-123 troubleshooting steps go right to replacing the battery ECU.
    I'd maybe want to check for more codes with a different scan tool before going there.
    Brian1954 likes this.
  5. crasy169
    Gatesville, TX
    SE
    I’m absolutely not positive that I’m getting the necessary information from autoenginuity. Not sure where to go besides the dealer at this point to get a better diagnosis.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,111
    2,011
    NJ-USA
    It's been 10 years+ since I last used AutoEnginuity, but it was a fairly good "budget" pro level scan tool. If you can go into the HV battery ecu to look at data, then you SHOULD be able to retrieve any relevant codes there as well.
    That said, Chapman summed it up. The codes you have point to a fault detected by the HV battery ecu. The diagnostic procedure is to check for HV battery codes, & if there are none then replace the battery ecu.
  7. pasadena_commut
    pasadena_commut Senior Member
    3,034
    942
    Southern California
    Is the OP in a humid location? The corrosion getting to ECU and eating the pins there problem seems to be more common in those locations. At least that is my impression from what I read in this forum.
    In any case, checking for corrosion at the HV pack ECU connector, and inside that ECU would make sense. Buy a set of JIS bits or screwdrivers first though. When I changed the pack on our 2007 I tried to get into that ECU and couldn't open it with the Philips head bits. They are not quite the right shape, and I didn't want to risk stripping the JIS screw heads by applying more force with the wrong shape bit.
    Several threads on this issue, here is one with nice pictures:
    Corrosion/burn on Wire Frame No 2 Plug/Ecu | PriusChat
  8. crasy169
    Gatesville, TX
    SE
    I’m in Central Texas. Not overly humid. I’ll have to pick up a set of JIS bits or screwdrivers. I will take things apart once I get the recommended tools.
    I checked for codes and I am getting P3000 on the HV ECU CAN and no codes on the HV Battery CAN. Sadly it might be a week before I can get back on this between work and likely weather.
  9. crasy169
    Gatesville, TX
    SE
    Just want to double check the location of the battery ecu. It’s located in the HV battery, correct? Is there anything else besides corrosion on the connectors that I should be looking for?
  10. pasadena_commut
    3,034
    942
    Southern California
    Before digging into the pack unplug the 12V battery ground and (completely) remove the orange safety disconnect from the battery.
    If the big metal case is coming off to expose the modules look for signs of leakage and corrosion at those connectors too.
    In the electronics area you could look for general signs of electrical distress, like blackened wires, melted insulation, and so forth, but it is unlikely you will see any. There should be no water present and no indications that it ever was.
  11. crasy169
    Gatesville, TX
    SE
    I finally got a chance to take things apart today nad found some corrosion on the orange connector for the battery ecu. There was no signs of water or melted insulation. Everything looked pretty clean based ont he age of the car. I bought some contact cleaner and tried cleaning things up, but that does not appear to have helped.
    Sound like the next option is to but a new battery ecu. I found this place here selling battery ecu's. Has anyone dealt with Electron Hybrid Solutions before?
    What are the odds of this being the original battery? If so do you think it would be better spent to just replace or upgrade it?
  12. Brian1954
    Brian1954 Senior Member
    2,668
    1,066
    South Central PA, USA
    The battery ECU that they are selling is a remanuctured (used) part that they warranty for one year. It is not new!
  13. crasy169
    Gatesville, TX
    SE
    Correct. For the moment I’m willing to accept that as potential issue to revise later.
  14. crasy169
    Gatesville, TX
    SE
    Well the new part came in and may or may not be bad. I am getting the same codes as before. I am figuring at this point I probably need to try cleaning out the plug better. I have a welding tip cleaner that has many different guage cleaning wires on it.
    At one point it showed new codes for a bad battery at module 9, I cleared codes and started logging all the modules voltages, resistances, temps, and overall voltage. The P3000 code returned during a short drive, but no battery codes.
    What are other peoples thoughts? I can share the logging file if anyone wants to take a look or I can do a new log with specific information if there is something more pointed. Keep in mind these logs are from Autoenginuity not TechStream.
    All help is greatly appreciated.
  15. xw20_driver
    xw20_driver Member
    118
    59
    PNW
    My 2007 battery case has the same K at the 5th position of the case serial number, which from past discussion I believe means 2007. It is likely the original battery pack. How many miles are on your car? Since you've already uncovered the top, can you inspect the condition of the battery modules by looking for signs of leakage or terminal corrosion?
  16. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    ... or out-of-sequence module serial numbers.
  17. xw20_driver
    xw20_driver Member
    118
    59
    PNW
    Quite true. You may discover a surprise under the cover like I did: Nexcell lithium modules.
  18. crasy169
    Gatesville, TX
    SE
    Guess I will be being this onion back a little farther. Based on the corrosion I found on the orange connector on the battery control module I’m going to go ahead and order the #2 frame wire and have it ready to replace since I’m digging that deep.
  19. Brian1954
    2,668
    1,066
    To diagnose the problem with your car, I would first make sure that I was using a scanner that is capable of communicating with all the ECUs in the car. I recommend the Autel AP200. It costs about $60 on Amazon. It is an OBD2 Bluetooth dongle that works with an Autel app on your phone or tablet.
    Read post #1 and then scroll down to post #37 in this thread, https://priuschat.com/index.php?posts/3246758
    Also, look at this thread for the Autel AP200, https://priuschat.com/index.php?posts/3248209
    I would be interested in seeing the logging file. Does the file also show the current flow into or out of the hybrid battery? Were you driving the car when you collected the file, or was the car stationary with the engine running?
    #19 Brian1954, Apr 15, 2026
  20. crasy169
    Gatesville, TX
    SE
    I will have to take a look at the Autel stuff. I'd be happy to send the file to you. It does not look like i can drop a .csv file here. I did the logging while driving.
    Not sure how well that can be copied out to review, but figured that was worth a shot.
    Log File:
    Code:
    Time, Battery Block Voltage -V01 (V) [-327.68 - 327.67], Time, Battery Block Voltage -V02 (V) [-327.68 - 327.67], Time, Battery Block Voltage -V03 (V) [-327.68 - 327.67], Time, Battery Block Voltage -V04 (V) [-327.68 - 327.67], Time, Battery Block Voltage -V05 (V) [-327.68 - 327.67], Time, Battery Block Voltage -V06 (V) [-327.68 - 327.67], Time, Battery Block Voltage -V07 (V) [-327.68 - 327.67], Time, Battery Block Voltage -V08 (V) [-327.68 - 327.67], Time, Battery Block Voltage -V09 (V) [-327.68 - 327.67], Time, Battery Block Voltage -V10 (V) [-327.68 - 327.67], Time, Battery Block Voltage -V11 (V) [-327.68 - 327.67], Time, Battery Block Voltage -V12 (V) [-327.68 - 327.67], Time, Battery Block Voltage -V13 (V) [-327.68 - 327.67], Time, Battery Block Voltage -V14 (V) [-327.68 - 327.67], Time, Battery State of Charge (%) [0.0 - 127.5], Time, Internal Resistance R01 (Ohms) [0.000 - 0.255], Time, Internal Resistance R02 (Ohms) [0.000 - 0.255], Time, Internal Resistance R03 (Ohms) [0.000 - 0.255], Time, Internal Resistance R04 (Ohms) [0.000 - 0.255], Time, Internal Resistance R05 (Ohms) [0.000 - 0.255], Time, Internal Resistance R06 (Ohms) [0.000 - 0.255], Time, Internal Resistance R07 (Ohms) [0.000 - 0.255], Time, Internal Resistance R08 (Ohms) [0.000 - 0.255], Time, Internal Resistance R09 (Ohms) [0.000 - 0.255], Time, Internal Resistance R10 (Ohms) [0.000 - 0.255], Time, Internal Resistance R11 (Ohms) [0.000 - 0.255], Time, Internal Resistance R12 (Ohms) [0.000 - 0.255], Time, Internal Resistance R13 (Ohms) [0.000 - 0.255], Time, Internal Resistance R14 (Ohms) [0.000 - 0.255], Time, Temp. of Battery TB1 (F) [-40.00 - 248.00], Time, Temp. of Battery TB2 (F) [-40.00 - 248.00], Time, Temp. of Battery TB3 (F) [-40.00 - 248.00],
     07:02:39.862, 16.88,  07:02:39.868, 16.93,  07:02:40.192, 16.90,  07:02:40.471, 16.94,  07:02:40.784, 16.87,  07:02:41.368, 16.92,  07:02:41.455, 16.90,  07:02:41.883, 16.95,  07:02:42.175, 15.46,  07:02:42.741, 16.90,  07:02:42.758, 16.90,  07:02:43.148, 16.85,  07:02:43.438, 16.92,  07:02:43.727, 16.88,  07:02:44.311, 69.0,  07:02:44.619, 0.019,  07:02:44.645, 0.019,  07:02:44.948, 0.019,  07:02:45.238, 0.019,  07:02:45.523, 0.019,  07:02:46.079, 0.019,  07:02:46.095, 0.019,  07:02:46.413, 0.019,  07:02:46.716, 0.019,  07:02:47.019, 0.019,  07:02:47.576, 0.019,  07:02:47.608, 0.019,  07:02:47.910, 0.019,  07:02:48.217, 0.019,  07:02:48.707, 72.70,  07:02:48.850, 72.80,  07:02:49.122, 72.54,
     07:02:50.043, 16.86,  07:02:50.051, 16.84,  07:02:50.354, 16.84,  07:02:50.649, 16.86,  07:02:50.975, 16.83,  07:02:51.551, 16.86,  07:02:51.645, 16.85,  07:02:52.006, 16.86,  07:02:52.364, 15.37,  07:02:52.909, 16.83,  07:02:52.916, 16.87,  07:02:53.196, 16.86,  07:02:53.486, 16.86,  07:02:53.754, 16.85,  07:02:54.295, 65.5,  07:02:54.586, 0.019,  07:02:54.606, 0.019,  07:02:54.885, 0.019,  07:02:55.155, 0.019,  07:02:55.460, 0.019,  07:02:56.034, 0.019,  07:02:56.038, 0.019,  07:02:56.366, 0.019,  07:02:56.695, 0.019,  07:02:56.974, 0.019,  07:02:57.530, 0.019,  07:02:57.555, 0.019,  07:02:57.852, 0.019,  07:02:58.157, 0.019,  07:02:58.689, 72.70,  07:02:58.785, 72.80,  07:02:59.066, 72.54,
     07:02:59.937, 16.44,  07:02:59.942, 16.41,  07:03:00.237, 16.39,  07:03:00.520, 16.38,  07:03:00.804, 16.42,  07:03:01.362, 16.77,  07:03:01.371, 16.79,  07:03:01.648, 16.80,  07:03:01.944, 15.31,  07:03:02.222, 16.76,  07:03:02.780, 16.80,  07:03:02.791, 16.75,  07:03:03.072, 16.84,  07:03:03.361, 16.82,  07:03:03.641, 60.0,  07:03:04.181, 0.019,  07:03:04.229, 0.019,  07:03:04.523, 0.019,  07:03:04.808, 0.019,  07:03:05.113, 0.019,  07:03:05.662, 0.019,  07:03:05.678, 0.019,  07:03:05.955, 0.019,  07:03:06.234, 0.019,  07:03:06.537, 0.019,  07:03:07.100, 0.019,  07:03:07.110, 0.019,  07:03:07.428, 0.019,  07:03:07.699, 0.019,  07:03:08.192, 72.70,  07:03:08.256, 72.81,  07:03:08.542, 72.54,
     07:03:09.396, 16.87,  07:03:09.402, 16.86,  07:03:09.678, 16.84,  07:03:09.954, 16.81,  07:03:10.219, 16.86,  07:03:10.780, 16.93,  07:03:10.798, 16.90,  07:03:11.078, 16.91,  07:03:11.349, 15.57,  07:03:11.635, 16.92,  07:03:12.191, 16.99,  07:03:12.203, 16.95,  07:03:12.475, 16.96,  07:03:12.748, 16.93,  07:03:13.034, 58.5,  07:03:13.567, 0.019,  07:03:13.596, 0.019,  07:03:13.881, 0.019,  07:03:14.148, 0.019,  07:03:14.436, 0.019,  07:03:14.982, 0.019,  07:03:14.991, 0.019,  07:03:15.278, 0.019,  07:03:15.549, 0.019,  07:03:15.829, 0.019,  07:03:18.676, 0.000,  07:03:18.683, 0.000,  07:03:18.975, 0.000,  07:03:19.234, 0.000,  07:03:19.744, 72.71,  07:03:19.807, 72.81,  07:03:20.080, 72.56,
     07:03:20.880, 17.35,  07:03:20.891, 17.34,  07:03:20.895, 17.30,  07:03:21.401, 17.31,  07:03:21.699, 17.34,  07:03:22.227, 17.42,  07:03:22.295, 17.45,  07:03:22.570, 17.44,  07:03:22.865, 17.80,  07:03:23.138, 17.34,  07:03:23.678, 17.60,  07:03:23.710, 17.56,  07:03:23.982, 17.54,  07:03:24.259, 17.53,  07:03:24.522, 64.5,  07:03:25.084, 0.019,  07:03:25.094, 0.019,  07:03:25.384, 0.019,  07:03:25.659, 0.019,  07:03:25.937, 0.019,  07:03:26.469, 0.019,  07:03:26.477, 0.019,  07:03:26.744, 0.019,  07:03:27.021, 0.019,  07:03:27.305, 0.019,  07:03:27.855, 0.019,  07:03:27.857, 0.019,  07:03:28.122, 0.019,  07:03:28.395, 0.019,  07:03:28.875, 72.70,  07:03:28.949, 72.81,  07:03:29.333, 72.56,
     07:03:30.233, 18.01,  07:03:30.242, 18.05,  07:03:30.524, 17.97,  07:03:30.789, 17.96,  07:03:31.070, 17.99,  07:03:31.606, 18.30,  07:03:31.623, 18.30,  07:03:31.903, 18.32,  07:03:32.192, 18.79,  07:03:32.461, 18.17,  07:03:33.040, 17.54,  07:03:33.045, 17.51,  07:03:33.335, 17.54,  07:03:33.622, 17.50,  07:03:33.932, 81.5,  07:03:34.495, 0.019,  07:03:34.524, 0.019,  07:03:34.802, 0.019,  07:03:35.069, 0.019,  07:03:35.346, 0.019,  07:03:35.899, 0.019,  07:03:35.945, 0.019,  07:03:36.430, 0.019,  07:03:37.213, 0.019,  07:03:37.445, 0.019,  07:03:37.953, 0.019,  07:03:37.957, 0.019,  07:03:37.963, 0.019,  07:03:37.971, 0.019,  07:03:38.178, 72.71,  07:03:38.482, 72.83,  07:03:38.490, 72.56,
     07:03:39.745, 17.09,  07:03:39.749, 17.11,  07:03:40.115, 17.10,  07:03:40.408, 17.10,  07:03:40.705, 17.10,  07:03:41.287, 17.12,  07:03:41.298, 17.10,  07:03:41.583, 17.13,  07:03:41.917, 15.83,  07:03:42.190, 17.08,  07:03:42.751, 16.87,  07:03:42.767, 16.80,  07:03:43.048, 16.93,  07:03:43.352, 16.92,  07:03:43.638, 81.0,  07:03:44.210, 0.019,  07:03:44.257, 0.019,  07:03:44.624, 0.019,  07:03:44.918, 0.019,  07:03:45.197, 0.019,  07:03:45.745, 0.019,  07:03:45.783, 0.019,  07:03:46.075, 0.019,  07:03:46.385, 0.019,  07:03:46.685, 0.019,  07:03:47.226, 0.019,  07:03:47.242, 0.019,  07:03:47.506, 0.019,  07:03:47.792, 0.019,  07:03:48.270, 72.71,  07:03:48.333, 72.83,  07:03:48.621, 72.56,
     07:03:49.460, 16.37,  07:03:49.466, 16.37,  07:03:49.749, 16.38,  07:03:50.012, 16.38,  07:03:50.298, 16.31,  07:03:50.844, 16.38,  07:03:50.871, 16.41,  07:03:51.143, 16.41,  07:03:51.430, 14.88,  07:03:51.735, 16.40,  07:03:52.278, 16.41,  07:03:52.288, 16.38,  07:03:52.564, 16.36,  07:03:52.859, 16.35,  07:03:53.140, 62.5,  07:03:53.780, 0.019,  07:03:53.814, 0.019,  07:03:54.108, 0.019,  07:03:54.403, 0.019,  07:03:54.703, 0.019,  07:03:55.244, 0.019,  07:03:55.258, 0.019,  07:03:55.536, 0.019,  07:03:55.818, 0.019,  07:03:56.095, 0.019,  07:03:56.661, 0.019,  07:03:56.676, 0.019,  07:03:56.964, 0.019,  07:03:57.234, 0.019,  07:03:57.716, 72.72,  07:03:57.793, 72.83,  07:03:58.065, 72.56,
     07:03:58.910, 17.19,  07:03:58.922, 17.16,  07:03:59.219, 17.17,  07:03:59.501, 17.17,  07:03:59.787, 17.19,  07:04:00.366, 17.31,  07:04:00.371, 17.33,  07:04:00.646, 17.32,  07:04:00.948, 17.71,  07:04:01.202, 17.26,  07:04:01.748, 17.35,  07:04:01.769, 17.31,  07:04:02.042, 17.35,  07:04:02.315, 17.30,  07:04:02.586, 66.5,  07:04:03.150, 0.019,  07:04:03.156, 0.019,  07:04:03.429, 0.019,  07:04:03.731, 0.019,  07:04:04.005, 0.019,  07:04:04.548, 0.019,  07:04:04.556, 0.019,  07:04:04.845, 0.019,  07:04:05.116, 0.019,  07:04:05.403, 0.019,  07:04:05.950, 0.019,  07:04:05.958, 0.019,  07:04:06.247, 0.019,  07:04:06.523, 0.019,  07:04:07.015, 72.72,  07:04:07.095, 72.84,  07:04:07.382, 72.57,
     07:04:08.277, 17.06,  07:04:08.289, 17.04,  07:04:08.563, 17.06,  07:04:08.849, 17.06,  07:04:09.220, 17.03,  07:04:09.760, 17.06,  07:04:09.768, 17.06,  07:04:10.059, 17.07,  07:04:10.329, 17.02,  07:04:10.615, 17.03,  07:04:11.178, 17.04,  07:04:11.203, 17.00,  07:04:11.553, 17.05,  07:04:11.886, 17.04,  07:04:12.524, 69.5,  07:04:12.986, 0.019,  07:04:13.168, 0.019,  07:04:13.612, 0.019,  07:04:14.380, 0.019,  07:04:14.546, 0.019,  07:04:14.961, 0.019,  07:04:15.295, 0.019,  07:04:15.840, 0.019,  07:04:15.867, 0.019,  07:04:16.179, 0.019,  07:04:16.466, 0.019,  07:04:16.757, 0.019,  07:04:17.338, 0.019,  07:04:17.341, 0.019,  07:04:17.830, 72.72,  07:04:17.890, 72.84,  07:04:18.175, 72.57,
     07:04:19.009, 17.01,  07:04:19.021, 17.02,  07:04:19.292, 17.02,  07:04:19.563, 17.01,  07:04:19.850, 17.00,  07:04:20.392, 17.04,  07:04:20.424, 17.03,  07:04:20.699, 17.06,  07:04:20.983, 16.81,  07:04:21.256, 17.01,  07:04:21.812, 17.03,  07:04:21.821, 17.00,  07:04:22.095, 17.04,  07:04:22.365, 17.02,  07:04:22.652, 69.0,  07:04:23.197, 0.019,  07:04:23.205, 0.019,  07:04:23.484, 0.019,  07:04:23.750, 0.019,  07:04:24.020, 0.019,  07:04:24.584, 0.019,  07:04:24.589, 0.019,  07:04:24.868, 0.019,  07:04:25.151, 0.019,  07:04:25.466, 0.019,  07:04:25.993, 0.019,  07:04:26.015, 0.019,  07:04:26.279, 0.019,  07:04:26.549, 0.019,  07:04:27.048, 72.72,  07:04:27.114, 72.84,  07:04:27.387, 72.57,
     07:04:28.235, 16.99,  07:04:28.240, 17.02,  07:04:28.513, 17.00,  07:04:28.785, 16.98,  07:04:29.066, 17.00,  07:04:29.612, 17.03,  07:04:29.636, 17.02,  07:04:29.898, 17.05,  07:04:30.172, 16.74,  07:04:30.457, 17.01,  07:04:30.999, 17.02,  07:04:31.011, 17.00,  07:04:31.271, 17.03,  07:04:31.552, 17.02,  07:04:31.824, 68.5,  07:04:32.366, 0.019,  07:04:32.383, 0.019,  07:04:32.661, 0.019,  07:04:32.933, 0.019,  07:04:33.209, 0.019,  07:04:33.759, 0.019,  07:04:33.765, 0.019,  07:04:34.038, 0.019,  07:04:34.309, 0.019,  07:04:34.597, 0.019,  07:04:35.138, 0.019,  07:04:35.157, 0.019,  07:04:35.425, 0.019,  07:04:35.696, 0.019,  07:04:36.180, 72.72,  07:04:36.256, 72.84,  07:04:36.529, 72.57,
     07:04:37.343, 16.99,  07:04:37.353, 17.01,  07:04:37.627, 17.00,  07:04:37.898, 16.98,  07:04:38.179, 17.00,  07:04:38.731, 17.03,  07:04:38.739, 17.03,  07:04:39.080, 17.03,  07:04:39.082, 16.58,  07:04:39.455, 17.00,  07:04:39.720, 17.01,  07:04:40.290, 17.00,  07:04:40.290, 17.03,  07:04:40.592, 17.01,  07:04:40.900, 68.0,  07:04:41.439, 0.019,  07:04:41.467, 0.019,  07:04:41.816, 0.019,  07:04:42.105, 0.019,  07:04:42.386, 0.019,  07:04:42.931, 0.019,  07:04:42.963, 0.019,  07:04:43.237, 0.019,  07:04:43.519, 0.019,  07:04:43.791, 0.019,  07:04:44.372, 0.019,  07:04:44.388, 0.019,  07:04:44.393, 0.019,  07:04:44.750, 0.019,  07:04:44.950, 72.72,  07:04:45.061, 72.84,  07:04:45.071, 72.57,
     07:04:45.685, 17.01,  07:04:45.696, 17.01,  07:04:46.049, 16.96,  07:04:46.349, 17.01,  07:04:46.367, 16.99,  07:04:46.675, 17.03,  07:04:47.245, 16.99,  07:04:47.355, 17.02,  07:04:47.360, 16.48,  07:04:47.839, 16.99,  07:04:47.843, 17.00,  07:04:47.849, 16.99,  07:04:47.855, 16.99,  07:04:47.861, 17.01,  07:04:47.865, 68.0,  07:04:48.558, 0.019,  07:04:48.631, 0.019,  07:04:48.974, 0.019,  07:04:48.988, 0.019,  07:04:48.994, 0.019,  07:04:49.295, 0.019,  07:04:49.861, 0.019,  07:04:49.905, 0.019,  07:04:50.200, 0.019,  07:04:50.480, 0.019,  07:04:50.767, 0.019,  07:04:51.326, 0.019,  07:04:51.356, 0.019,  07:04:51.360, 0.019,  07:04:51.836, 72.71,  07:04:51.947, 72.83,  07:04:52.232, 72.56,
     07:04:52.809, 16.99,  07:04:52.961, 17.00,  07:04:52.973, 17.00,  07:04:53.269, 17.00,  07:04:53.273, 17.00,  07:04:53.278, 17.03,  07:04:53.288, 17.01,  07:04:53.565, 17.02,  07:04:54.123, 16.35,  07:04:54.139, 16.99,  07:04:54.431, 17.01,  07:04:54.711, 17.00,  07:04:55.014, 16.99,  07:04:55.576, 17.00,  07:04:55.596, 67.5,  07:04:56.147, 0.019,  07:04:56.178, 0.019,  07:04:56.461, 0.019,  07:04:56.750, 0.019,  07:04:57.050, 0.019,  07:04:57.620, 0.019,  07:04:57.644, 0.019,  07:04:57.932, 0.019,  07:04:58.229, 0.019,  07:04:58.560, 0.019,  07:04:59.163, 0.019,  07:04:59.229, 0.019,  07:04:59.565, 0.019,  07:04:59.875, 0.019,  07:05:00.401, 72.71,  07:05:00.622, 72.83,  07:05:01.068, 72.56,
     07:05:02.253, 17.01,  07:05:02.263, 16.98,  07:05:02.733, 16.99,  07:05:03.091, 16.99,  07:05:03.667, 17.00,  07:05:03.673, 17.02,  07:05:03.958, 17.00,  07:05:04.236, 17.02,  07:05:04.522, 16.14,  07:05:05.085, 16.99,  07:05:05.099, 17.01,  07:05:05.385, 16.99,  07:05:05.664, 17.02,  07:05:05.939, 16.99,  07:05:06.496, 66.5,  07:05:06.788, 0.019,  07:05:06.805, 0.019,  07:05:07.100, 0.019,  07:05:07.402, 0.019,  07:05:07.688, 0.019,  07:05:08.252, 0.019,  07:05:08.264, 0.019,  07:05:08.547, 0.019,  07:05:08.818, 0.019,  07:05:09.117, 0.019,  07:05:09.677, 0.019,  07:05:09.693, 0.019,  07:05:09.963, 0.019,  07:05:10.260, 0.019,  07:05:10.749, 72.70,  07:05:10.831, 72.81,  07:05:11.125, 72.56,
     07:05:11.995, 16.99,  07:05:12.002, 16.99,  07:05:12.291, 16.99,  07:05:12.583, 16.99,  07:05:12.864, 16.99,  07:05:13.437, 17.01,  07:05:13.448, 17.00,  07:05:13.775, 16.98,  07:05:14.085, 15.98,  07:05:14.379, 16.99,  07:05:14.931, 17.00,  07:05:14.953, 16.98,  07:05:15.245, 16.99,  07:05:15.516, 16.98,  07:05:15.820, 66.5,  07:05:16.366, 0.019,  07:05:16.385, 0.019,  07:05:16.666, 0.019,  07:05:16.947, 0.019,  07:05:17.238, 0.019,  07:05:17.796, 0.019,  07:05:17.815, 0.019,  07:05:18.093, 0.019,  07:05:18.396, 0.019,  07:05:18.686, 0.019,  07:05:19.255, 0.019,  07:05:19.271, 0.019,  07:05:19.572, 0.019,  07:05:19.859, 0.019,  07:05:20.342, 72.70,  07:05:20.432, 72.81,  07:05:20.714, 72.54,
     07:05:21.604, 16.99,  07:05:21.612, 17.00,  07:05:21.901, 16.99,  07:05:22.171, 16.99,  07:05:22.458, 16.99,  07:05:23.014, 17.02,  07:05:23.032, 17.00,  07:05:23.348, 17.01,  07:05:23.661, 15.88,  07:05:23.947, 16.99,  07:05:26.928, -327.68,  07:05:26.934, -327.68,  07:05:27.215, -327.68,  07:05:27.516, -327.68,  07:05:27.786, 66.0,  07:05:28.349, 0.019,  07:05:28.358, 0.019,  07:05:28.661, 0.019,  07:05:29.009, 0.019,  07:05:29.311, 0.019,  07:05:29.918, 0.019,  07:05:29.968, 0.019,  07:05:30.299, 0.019,  07:05:30.622, 0.019,  07:05:30.899, 0.019,  07:05:31.446, 0.019,  07:05:31.462, 0.019,  07:05:31.732, 0.019,  07:05:32.019, 0.019,  07:05:32.512, 72.68,  07:05:32.592, 72.80,  07:05:32.863, 72.54,
     07:05:33.695, 16.99,  07:05:33.701, 16.98,  07:05:34.000, 16.95,  07:05:34.279, 16.99,  07:05:34.559, 16.99,  07:05:35.106, 17.01,  07:05:35.122, 16.99,  07:05:35.409, 16.98,  07:05:35.688, 15.80,  07:05:35.969, 16.98,  07:05:36.529, 16.99,  07:05:36.543, 16.98,  07:05:36.827, 16.97,  07:05:37.106, 16.98,  07:05:37.389, 65.0,  07:05:37.944, 0.019,  07:05:37.961, 0.019,  07:05:38.242, 0.019,  07:05:38.515, 0.019,  07:05:38.815, 0.019,  07:05:39.364, 0.019,  07:05:39.388, 0.019,  07:05:39.692, 0.019,  07:05:39.978, 0.019,  07:05:40.261, 0.019,  07:05:40.804, 0.019,  07:05:40.814, 0.019,  07:05:41.076, 0.019,  07:05:41.330, 0.019,  07:05:41.826, 72.68,  07:05:41.885, 72.79,  07:05:42.142, 72.54,
     07:05:42.933, 16.98,  07:05:42.940, 16.98,  07:05:43.281, 16.95,  07:05:43.596, 16.98,  07:05:44.248, 16.95,  07:05:44.298, 17.00,  07:05:44.627, 16.99,  07:05:44.960, 16.98,  07:05:45.529, 15.77,  07:05:45.593, 16.98,  07:05:45.946, 16.99,  07:05:46.275, 16.98,  07:05:46.833, 17.00,  07:05:46.879, 16.98,  07:05:47.119, 64.5,  07:05:47.628, 0.019,  07:05:47.637, 0.019,  07:05:47.831, 0.019,  07:05:48.026, 0.019,  07:05:48.290, 0.019,  07:05:48.294, 0.019,  07:05:48.579, 0.019,  07:05:49.084, 0.019,  07:05:49.092, 0.019,  07:05:49.340, 0.019,  07:05:49.609, 0.019,  07:05:49.869, 0.019,  07:05:50.369, 0.019,  07:05:50.378, 0.019,  07:05:50.847, 72.68,  07:05:50.931, 72.79,  07:05:51.220, 72.53,
     07:05:52.126, 16.98,  07:05:52.128, 16.99,  07:05:52.416, 16.94,  07:05:52.720, 16.98,  07:05:53.029, 16.98,  07:05:53.609, 17.00,  07:05:53.664, 16.99,  07:05:53.972, 17.01,  07:05:54.277, 15.72,  07:05:54.557, 16.98,  07:05:55.102, 16.99,  07:05:55.124, 16.96,  07:05:55.411, 16.99,  07:05:55.693, 16.98,  07:05:55.982, 63.5,  07:05:56.586, 0.019,  07:05:56.721, 0.019,  07:05:56.726, 0.019,  07:05:57.069, 0.019,  07:05:57.408, 0.019,  07:05:57.965, 0.019,  07:05:57.981, 0.019,  07:05:58.261, 0.019,  07:05:58.555, 0.019,  07:05:58.870, 0.019,  07:05:59.410, 0.019,  07:05:59.430, 0.019,  07:05:59.707, 0.019,  07:05:59.990, 0.019,  07:06:00.491, 72.67,  07:06:00.573, 72.79,  07:06:00.847, 72.53,
     07:06:01.685, 16.98,  07:06:01.694, 16.97,  07:06:01.996, 16.94,  07:06:02.284, 16.98,  07:06:02.567, 16.98,  07:06:03.140, 17.00,  07:06:03.156, 16.98,  07:06:03.451, 16.97,  07:06:03.738, 15.76,  07:06:04.026, 16.98,  07:06:04.571, 17.00,  07:06:04.598, 16.96,  07:06:04.880, 16.99,  07:06:05.170, 16.98,  07:06:05.458, 63.0,  07:06:06.004, 0.019,  07:06:06.024, 0.019,  07:06:06.310, 0.019,  07:06:06.597, 0.019,  07:06:06.882, 0.019,  07:06:07.438, 0.019,  07:06:07.445, 0.019,  07:06:07.727, 0.019,  07:06:08.011, 0.019,  07:06:08.295, 0.019,  07:06:08.852, 0.019,  07:06:08.864, 0.019,  07:06:09.159, 0.019,  07:06:09.442, 0.019,  07:06:09.917, 72.67,  07:06:10.001, 72.79,  07:06:10.294, 72.53,
     07:06:11.122, 16.98,  07:06:11.132, 16.98,  07:06:11.423, 16.97,  07:06:11.704, 16.96,  07:06:11.995, 16.95,  07:06:12.559, 16.99,  07:06:12.620, 16.99,  07:06:12.903, 17.01,  07:06:13.212, 15.73,  07:06:13.550, 16.97,  07:06:14.170, 16.99,  07:06:14.227, 16.96,  07:06:14.610, 16.99,  07:06:14.899, 16.97,  07:06:15.449, 62.5,  07:06:15.748, 0.019,  07:06:15.764, 0.019,  07:06:16.046, 0.019,  07:06:16.333, 0.019,  07:06:16.616, 0.019,  07:06:17.162, 0.019,  07:06:17.168, 0.019,  07:06:17.448, 0.019,  07:06:17.717, 0.019,  07:06:17.986, 0.019,  07:06:18.511, 0.019,  07:06:18.527, 0.019,  07:06:18.819, 0.019,  07:06:19.104, 0.019,  07:06:19.583, 72.67,  07:06:19.669, 72.77,  07:06:19.952, 72.53,
     07:06:23.156, 16.97,  07:06:23.159, 16.97,  07:06:23.470, 16.97,  07:06:23.788, 16.96,  07:06:24.143, 16.98,  07:06:24.761, 16.99,  07:06:24.826, 16.98,  07:06:25.173, 17.01,  07:06:25.523, 15.70,  07:06:26.114, 16.98,  07:06:26.207, 16.98,  07:06:26.553, 16.96,  07:06:26.916, 16.96,  07:06:27.606, 16.97,  07:06:27.686, 61.5,  07:06:28.356, 0.019,  07:06:28.468, 0.019,  07:06:28.842, 0.019,  07:06:29.324, 0.019,  07:06:30.077, 0.019,  07:06:30.295, 0.019,  07:06:30.777, 0.019,  07:06:31.523, 0.019,  07:06:31.736, 0.019,  07:06:32.219, 0.019,  07:06:32.973, 0.019,  07:06:33.174, 0.019,  07:06:33.608, 0.019,  07:06:34.283, 0.019,  07:06:34.567, 72.67,  07:06:34.713, 72.77,  07:06:35.098, 72.53,
     07:06:36.192, 16.94,  07:06:36.196, 16.98,  07:06:36.547, 16.96,  07:06:36.996, 16.94,  07:06:37.711, 16.95,  07:06:37.901, 16.98,  07:06:38.299, 16.97,  07:06:38.679, 17.00,  07:06:39.360, 15.72,  07:06:39.506, 16.97,  07:06:39.923, 16.97,  07:06:40.638, 16.95,  07:06:40.810, 16.98,  07:06:41.260, 16.97,  07:06:41.941, 60.5,  07:06:42.354, 0.019,  07:06:42.464, 0.019,  07:06:42.850, 0.019,  07:06:43.229, 0.019,  07:06:43.877, 0.019,  07:06:44.004, 0.019,  07:06:44.386, 0.019,  07:06:44.734, 0.019,  07:06:45.358, 0.019,  07:06:45.438, 0.019,  07:06:45.775, 0.019,  07:06:46.120, 0.019,  07:06:46.733, 0.019,  07:06:46.813, 0.019,  07:06:47.368, 72.66,  07:06:47.467, 72.76,  07:06:47.802, 72.53,
     07:06:48.709, 16.96,  07:06:48.713, 16.96,  07:06:49.034, 16.96,  07:06:49.373, 16.96,  07:06:49.653, 16.93,  07:06:50.212, 16.98,  07:06:50.244, 16.97,  07:06:50.554, 17.00,  07:06:50.559, 15.71,  07:06:50.866, 16.97,  07:06:51.150, 16.98,  07:06:51.154, 16.95,  07:06:51.697, 16.96,  07:06:51.706, 16.97,  07:06:51.964, 60.0,  07:06:52.537, 0.019,  07:06:52.549, 0.019,  07:06:52.823, 0.019,  07:06:53.131, 0.019,  07:06:53.376, 0.019,  07:06:53.870, 0.019,  07:06:53.877, 0.019,  07:06:54.168, 0.019,  07:06:54.458, 0.019,  07:06:54.697, 0.019,  07:06:55.186, 0.019,  07:06:55.195, 0.019,  07:06:55.417, 0.019,  07:06:55.663, 0.019,  07:06:56.111, 72.66,  07:06:56.171, 72.76,  07:06:56.436, 72.52,
     07:06:57.160, 16.97,  07:06:57.183, 16.97,  07:06:57.642, 16.96,  07:06:57.941, 16.95,  07:06:58.458, 16.95,  07:06:58.467, 16.98,  07:06:58.807, 16.96,  07:06:59.179, 16.98,  07:06:59.733, 15.71,  07:06:59.736, 16.96,  07:07:00.023, 16.97,  07:07:00.220, 16.94,  07:07:00.451, 16.94,  07:07:00.665, 16.96,  07:07:01.158, 59.5,  07:07:01.435, 0.019,  07:07:01.469, 0.019,  07:07:01.746, 0.019,  07:07:02.034, 0.019,  07:07:02.320, 0.019,  07:07:02.892, 0.019,  07:07:02.908, 0.019,  07:07:03.194, 0.019,  07:07:03.497, 0.019,  07:07:03.766, 0.019,  07:07:04.323, 0.019,  07:07:04.339, 0.019,  07:07:04.625, 0.019,  07:07:04.911, 0.019,  07:07:05.396, 72.66,  07:07:05.512, 72.76,  07:07:05.945, 72.52,
     07:07:06.706, 16.97,  07:07:06.715, 16.96,  07:07:07.022, 16.95,  07:07:07.309, 16.95,  07:07:07.623, 16.93,  07:07:08.166, 16.98,  07:07:08.188, 16.98,  07:07:08.468, 16.98,  07:07:08.754, 15.71,  07:07:09.055, 16.97,  07:07:09.633, 16.97,  07:07:09.638, 16.90,  07:07:09.911, 16.98,  07:07:10.209, 16.97,  07:07:10.495, 59.0,  07:07:11.057, 0.019,  07:07:11.077, 0.019,  07:07:11.353, 0.019,  07:07:11.660, 0.019,  07:07:11.934, 0.019,  07:07:12.483, 0.019,  07:07:12.502, 0.019,  07:07:12.784, 0.019,  07:07:13.090, 0.019,  07:07:13.357, 0.019,  07:07:13.948, 0.019,  07:07:14.031, 0.019,  07:07:14.307, 0.019,  07:07:14.608, 0.019,  07:07:15.101, 72.66,  07:07:15.180, 72.76,  07:07:15.467, 72.52,
     07:07:16.304, 16.96,  07:07:16.311, 16.95,  07:07:16.617, 16.95,  07:07:16.919, 16.96,  07:07:17.204, 16.92,  07:07:17.762, 16.98,  07:07:17.793, 16.96,  07:07:18.064, 16.97,  07:07:18.351, 15.71,  07:07:18.648, 16.96,  07:07:19.211, 16.96,  07:07:19.229, 16.91,  07:07:19.512, 16.97,  07:07:19.798, 16.97,  07:07:20.083, 58.5,  07:07:20.626, 0.019,  07:07:20.646, 0.019,  07:07:20.912, 0.019,  07:07:21.230, 0.019,  07:07:21.509, 0.019,  07:07:22.072, 0.019,  07:07:22.083, 0.019,  07:07:22.358, 0.019,  07:07:22.644, 0.019,  07:07:22.946, 0.019,  07:07:23.509, 0.019,  07:07:23.514, 0.019,  07:07:23.788, 0.019,  07:07:24.074, 0.019,  07:07:24.571, 72.66,  07:07:24.646, 72.76,  07:07:24.918, 72.52,
     07:07:25.832, 16.93,  07:07:25.842, 16.94,  07:07:26.131, 16.95,  07:07:26.405, 16.93,  07:07:26.695, 16.94,  07:07:27.254, 16.98,  07:07:27.286, 16.97,  07:07:27.573, 16.98,  07:07:27.868, 15.67,  07:07:28.139, 16.95,  07:07:28.697, 16.97,  07:07:28.720, 16.94,  07:07:29.001, 16.97,  07:07:29.286, 16.95,  07:07:29.557, 57.5,  07:07:30.114, 0.019,  07:07:30.132, 0.019,  07:07:30.416, 0.019,  07:07:30.720, 0.019,  07:07:31.005, 0.019,  07:07:31.562, 0.019,  07:07:31.575, 0.019,  07:07:31.867, 0.019,  07:07:32.152, 0.019,  07:07:32.444, 0.019,  07:07:33.014, 0.019,  07:07:33.028, 0.019,  07:07:33.296, 0.019,  07:07:33.587, 0.019,  07:07:34.095, 72.64,  07:07:34.158, 72.75,  07:07:34.445, 72.52,
     07:07:35.283, 16.96,  07:07:35.288, 16.94,  07:07:35.581, 16.92,  07:07:35.868, 16.96,  07:07:36.139, 16.95,  07:07:36.702, 16.96,  07:07:36.712, 16.96,  07:07:36.997, 16.96,  07:07:37.267, 15.71,  07:07:37.568, 16.95,  07:07:38.115, 16.96,  07:07:38.141, 16.94,  07:07:38.413, 16.94,  07:07:38.701, 16.95,  07:07:38.971, 57.0,  07:07:39.512, 0.019,  07:07:39.548, 0.019,  07:07:39.837, 0.019,  07:07:40.132, 0.019,  07:07:40.403, 0.019,  07:07:40.965, 0.019,  07:07:41.033, 0.019,  07:07:41.310, 0.019,  07:07:41.597, 0.019,  07:07:41.886, 0.019,  07:07:42.423, 0.019,  07:07:42.453, 0.019,  07:07:42.727, 0.019,  07:07:42.998, 0.019,  07:07:43.513, 72.64,  07:07:43.598, 72.75,  07:07:43.903, 72.52,
     07:07:44.805, 16.96,  07:07:44.812, 16.94,  07:07:45.096, 16.94,  07:07:45.384, 16.94,  07:07:45.658, 16.95,  07:07:46.215, 16.97,  07:07:46.247, 16.96,  07:07:46.534, 16.96,  07:07:46.804, 15.70,  07:07:47.090, 16.95,  07:07:47.651, 16.94,  07:07:47.685, 16.91,  07:07:47.989, 16.97,  07:07:48.267, 16.96,  07:07:48.570, 56.0,  07:07:49.116, 0.019,  07:07:49.134, 0.019,  07:07:49.430, 0.019,  07:07:49.716, 0.019,  07:07:50.002, 0.019,  07:07:50.561, 0.019,  07:07:50.573, 0.019,  07:07:50.854, 0.019,  07:07:51.131, 0.019,  07:07:51.416, 0.019,  07:07:51.958, 0.019,  07:07:51.981, 0.019,  07:07:52.260, 0.019,  07:07:52.530, 0.019,  07:07:53.029, 72.64,  07:07:53.121, 72.75,  07:07:53.389, 72.50,
     07:07:54.245, 16.93,  07:07:54.250, 16.95,  07:07:54.536, 16.94,  07:07:54.811, 16.91,  07:07:55.082, 16.94,  07:07:55.644, 16.97,  07:07:55.653, 16.97,  07:07:55.943, 16.97,  07:07:56.213, 15.67,  07:07:56.507, 16.95,  07:07:57.060, 16.96,  07:07:57.075, 16.94,  07:07:57.366, 16.97,  07:07:57.653, 16.95,  07:07:57.944, 55.5,  07:07:58.488, 0.019,  07:07:58.533, 0.019,  07:07:58.816, 0.019,  07:07:59.096, 0.019,  07:07:59.380, 0.019,  07:07:59.933, 0.019,  07:07:59.981, 0.019,  07:08:00.270, 0.019,  07:08:00.554, 0.019,  07:08:00.848, 0.019,  07:08:01.405, 0.019,  07:08:01.427, 0.019,  07:08:01.702, 0.019,  07:08:01.992, 0.019,  07:08:02.482, 72.64,  07:08:02.561, 72.75,  07:08:02.849, 72.50,
     07:08:03.707, 16.96,  07:08:03.712, 16.95,  07:08:03.986, 16.90,  07:08:04.275, 16.94,  07:08:04.557, 16.95,  07:08:05.102, 16.97,  07:08:05.126, 16.96,  07:08:05.407, 16.95,  07:08:05.689, 15.68,  07:08:05.992, 16.94,  07:08:06.529, 16.94,  07:08:06.669, 16.94,  07:08:06.673, 16.94,  07:08:07.078, 16.94,  07:08:07.372, 54.5,  07:08:07.948, 0.019,  07:08:07.962, 0.019,  07:08:08.276, 0.019,  07:08:08.547, 0.019,  07:08:08.841, 0.019,  07:08:09.390, 0.019,  07:08:09.421, 0.019,  07:08:09.707, 0.019,  07:08:09.996, 0.019,  07:08:10.304, 0.019,  07:08:10.875, 0.019,  07:08:10.895, 0.019,  07:08:11.171, 0.019,  07:08:11.473, 0.019,  07:08:11.968, 72.64,  07:08:12.063, 72.74,  07:08:12.333, 72.50,
     07:08:13.203, 16.94,  07:08:13.213, 16.94,  07:08:13.498, 16.94,  07:08:13.830, 16.95,  07:08:14.110, 16.94,  07:08:14.672, 16.97,  07:08:14.719, 16.96,  07:08:15.162, 16.96,  07:08:15.166, 15.68,  07:08:15.606, 16.94,  07:08:16.254, 16.95,  07:08:16.292, 16.93,  07:08:16.566, 16.96,  07:08:16.890, 16.95,  07:08:17.202, 54.0,  07:08:17.742, 0.019,  07:08:17.775, 0.019,  07:08:18.045, 0.019,  07:08:18.346, 0.019,  07:08:18.616, 0.019,  07:08:19.188, 0.019,  07:08:19.206, 0.019,  07:08:19.501, 0.019,  07:08:19.787, 0.019,  07:08:20.071, 0.019,  07:08:20.630, 0.019,  07:08:20.642, 0.019,  07:08:20.912, 0.019,  07:08:21.200, 0.019,  07:08:21.708, 72.63,  07:08:21.771, 72.74,  07:08:22.059, 72.50,
     07:08:22.976, 16.94,  07:08:22.983, 16.93,  07:08:23.271, 16.90,  07:08:23.557, 16.94,  07:08:23.829, 16.94,  07:08:24.390, 16.96,  07:08:24.400, 16.96,  07:08:24.671, 16.97,  07:08:24.941, 15.66,  07:08:25.237, 16.93,  07:08:25.802, 16.94,  07:08:25.814, 16.94,  07:08:26.084, 16.96,  07:08:26.387, 16.94,  07:08:26.663, 53.5,  07:08:27.220, 0.019,  07:08:27.230, 0.019,  07:08:27.500, 0.019,  07:08:27.787, 0.019,  07:08:28.091, 0.019,  07:08:28.636, 0.019,  07:08:28.656, 0.019,  07:08:28.937, 0.019,  07:08:29.207, 0.019,  07:08:29.494, 0.019,  07:08:30.043, 0.019,  07:08:30.063, 0.019,  07:08:30.340, 0.019,  07:08:30.627, 0.019,  07:08:31.158, 72.63,  07:08:31.236, 72.74,  07:08:31.516, 72.50,
     07:08:32.358, 16.96,  07:08:32.365, 16.94,  07:08:32.638, 16.94,  07:08:32.926, 16.94,  07:08:33.211, 16.90,  07:08:33.769, 16.96,  07:08:33.783, 16.95,  07:08:34.070, 16.97,  07:08:34.357, 15.68,  07:08:34.642, 16.94,  07:08:35.200, 16.94,  07:08:35.233, 16.90,  07:08:35.502, 16.96,  07:08:35.790, 16.94,  07:08:36.078, 52.5,  07:08:36.616, 0.019,  07:08:36.628, 0.019,  07:08:36.903, 0.019,  07:08:37.189, 0.019,  07:08:37.475, 0.019,  07:08:38.020, 0.019,  07:08:38.044, 0.019,  07:08:38.318, 0.019,  07:08:38.606, 0.019,  07:08:38.891, 0.019,  07:08:39.449, 0.019,  07:08:39.468, 0.019,  07:08:39.743, 0.019,  07:08:40.045, 0.019,  07:08:40.516, 72.63,  07:08:40.595, 72.72,  07:08:40.889, 72.50,
     07:08:41.772, 16.94,  07:08:41.779, 16.93,  07:08:42.082, 16.90,  07:08:42.447, 16.94,  07:08:42.732, 16.94,  07:08:43.289, 16.96,  07:08:43.289, 16.94,  07:08:43.591, 16.96,  07:08:43.893, 15.67,  07:08:44.181, 16.95,  07:08:44.720, 16.94,  07:08:44.736, 16.93,  07:08:45.021, 16.96,  07:08:45.320, 16.95,  07:08:45.625, 52.0,  07:08:46.169, 0.019,  07:08:46.188, 0.019,  07:08:46.491, 0.019,  07:08:46.786, 0.019,  07:08:47.087, 0.019,  07:08:47.626, 0.019,  07:08:47.658, 0.019,  07:08:47.942, 0.019,  07:08:48.245, 0.019,  07:08:48.526, 0.019,  07:08:49.071, 0.019,  07:08:49.087, 0.019,  07:08:49.375, 0.019,  07:08:49.660, 0.019,  07:08:50.152, 72.63,  07:08:50.248, 72.72,  07:08:50.519, 72.50,
     07:08:51.400, 16.92,  07:08:51.414, 16.94,  07:08:51.686, 16.92,  07:08:51.973, 16.91,  07:08:52.267, 16.93,  07:08:52.822, 16.97,  07:08:52.834, 16.94,  07:08:53.102, 16.96,  07:08:53.387, 15.65,  07:08:53.680, 16.93,  07:08:56.538, -327.68,  07:08:56.545, -327.68,  07:08:56.824, -327.68,  07:08:57.111, -327.68,  07:08:57.396, 51.5,  07:08:57.955, 0.019,  07:08:57.967, 0.019,  07:08:58.243, 0.019,  07:08:58.535, 0.019,  07:08:58.815, 0.019,  07:08:59.379, 0.019,  07:08:59.386, 0.019,  07:08:59.683, 0.019,  07:08:59.972, 0.019,  07:09:00.276, 0.019,  07:09:00.839, 0.019,  07:09:00.880, 0.019,  07:09:01.167, 0.019,  07:09:01.473, 0.019,  07:09:02.014, 72.63,  07:09:02.087, 72.72,  07:09:02.372, 72.50,
     07:09:03.245, 16.94,  07:09:03.252, 16.94,  07:09:03.532, 16.92,  07:09:03.813, 16.93,  07:09:04.106, 16.94,  07:09:04.640, 16.95,  07:09:04.672, 16.94,  07:09:04.948, 16.96,  07:09:05.294, 15.67,  07:09:05.591, 16.93,  07:09:08.561, 16.94,  07:09:08.569, -327.68,  07:09:08.846, -327.68,  07:09:09.134, -327.68,  07:09:09.409, 50.5,  07:09:09.966, 0.019,  07:09:09.988, 0.019,  07:09:10.268, 0.019,  07:09:10.550, 0.019,  07:09:10.839, 0.019,  07:09:11.394, 0.019,  07:09:11.409, 0.019,  07:09:11.695, 0.019,  07:09:11.995, 0.019,  07:09:12.297, 0.019,  07:09:12.855, 0.019,  07:09:12.873, 0.019,  07:09:13.161, 0.019,  07:09:13.447, 0.019,  07:09:13.974, 72.63,  07:09:14.066, 72.72,  07:09:14.355, 72.49,
     07:09:15.185, 16.93,  07:09:15.198, 16.93,  07:09:15.471, 16.92,  07:09:15.848, 16.93,  07:09:16.514, 16.94,  07:09:16.576, 16.95,  07:09:16.967, 16.95,  07:09:17.375, 16.96,  07:09:18.024, 15.65,  07:09:18.264, 16.93,  07:09:18.745, 16.93,  07:09:19.427, 16.90,  07:09:19.576, 16.94,  07:09:19.909, 16.93,  07:09:20.299, 49.5,  07:09:20.938, 0.019,  07:09:21.038, 0.019,  07:09:21.418, 0.019,  07:09:21.798, 0.019,  07:09:22.450, 0.019,  07:09:22.476, 0.019,  07:09:22.747, 0.019,  07:09:23.050, 0.019,  07:09:23.380, 0.019,  07:09:24.035, 0.019,  07:09:24.230, 0.019,  07:09:24.673, 0.019,  07:09:25.395, 0.019,  07:09:25.460, 0.019,  07:09:25.968, 72.62,  07:09:26.032, 72.71,  07:09:26.367, 72.49,
     07:09:27.438, 16.91,  07:09:27.446, 16.93,  07:09:27.735, 16.92,  07:09:28.018, 16.91,  07:09:28.300, 16.92,  07:09:28.839, 16.96,  07:09:28.871, 16.94,  07:09:29.157, 16.96,  07:09:29.447, 15.63,  07:09:29.740, 16.93,  07:09:30.291, 16.93,  07:09:30.313, 16.91,  07:09:30.603, 16.94,  07:09:30.889, 16.93,  07:09:31.183, 49.0,  07:09:31.828, 0.019,  07:09:31.930, 0.019,  07:09:32.290, 0.019,  07:09:32.658, 0.019,  07:09:33.297, 0.019,  07:09:33.313, 0.019,  07:09:33.608, 0.019,  07:09:33.908, 0.019,  07:09:34.188, 0.019,  07:09:34.749, 0.019,  07:09:34.757, 0.019,  07:09:35.042, 0.019,  07:09:35.318, 0.019,  07:09:35.604, 0.019,  07:09:36.085, 72.62,  07:09:36.179, 72.71,  07:09:36.465, 72.49,
     07:09:37.348, 16.93,  07:09:37.362, 16.92,  07:09:37.649, 16.90,  07:09:37.945, 16.93,  07:09:38.292, 16.93,  07:09:38.940, 16.94,  07:09:39.046, 16.92,  07:09:39.317, 16.96,  07:09:39.619, 15.66,  07:09:39.926, 16.93,  07:09:40.499, 16.93,  07:09:40.590, 16.90,  07:09:40.963, 16.92,  07:09:41.267, 16.92,  07:09:41.810, 48.0,  07:09:42.097, 0.019,  07:09:42.120, 0.019,  07:09:42.410, 0.019,  07:09:42.732, 0.019,  07:09:43.042, 0.019,  07:09:43.607, 0.019,  07:09:43.625, 0.019,  07:09:43.903, 0.019,  07:09:44.193, 0.019,  07:09:44.471, 0.019,  07:09:45.022, 0.019,  07:09:45.043, 0.019,  07:09:45.309, 0.019,  07:09:45.610, 0.019,  07:09:46.119, 72.62,  07:09:46.203, 72.71,  07:09:46.484, 72.49,
     07:09:47.353, 16.93,  07:09:47.360, 16.92,  07:09:47.667, 16.90,  07:09:47.955, 16.93,  07:09:48.238, 16.92,  07:09:48.782, 16.94,  07:09:48.798, 16.94,  07:09:49.118, 16.92,  07:09:49.481, 15.66,  07:09:50.154, 16.93,  07:09:50.204, 16.93,  07:09:50.482, 16.91,  07:09:50.769, 16.92,  07:09:51.055, 16.93,  07:09:51.612, 47.5,  07:09:51.888, 0.019,  07:09:51.912, 0.019,  07:09:52.199, 0.019,  07:09:52.496, 0.019,  07:09:52.794, 0.019,  07:09:53.345, 0.019,  07:09:53.361, 0.019,  07:09:53.658, 0.019,  07:09:53.945, 0.019,  07:09:54.220, 0.019,  07:09:54.781, 0.019,  07:09:54.807, 0.019,  07:09:55.093, 0.019,  07:09:55.364, 0.019,  07:09:55.845, 72.62,  07:09:55.933, 72.71,  07:09:56.209, 72.49,
     07:09:57.060, 16.91,  07:09:57.068, 16.93,  07:09:57.411, 16.91,  07:09:57.788, 16.89,  07:09:58.388, 16.90,  07:09:58.413, 16.94,  07:09:58.691, 16.93,  07:09:58.988, 16.92,  07:09:59.284, 15.66,  07:09:59.842, 16.92,  07:09:59.848, 16.93,  07:10:00.155, 16.90,  07:10:00.449, 16.94,  07:10:00.727, 16.92,  07:10:01.290, 47.0,  07:10:01.574, 0.019,  07:10:01.588, 0.019,  07:10:01.878, 0.019,  07:10:02.161, 0.019,  07:10:02.445, 0.019,  07:10:02.975, 0.019,  07:10:03.017, 0.019,  07:10:03.289, 0.019,  07:10:03.594, 0.019,  07:10:03.877, 0.019,  07:10:04.439, 0.019,  07:10:04.446, 0.019,  07:10:04.736, 0.019,  07:10:05.024, 0.019,  07:10:05.521, 72.61,  07:10:05.599, 72.70,  07:10:05.877, 72.49,
     07:10:06.736, 16.93,  07:10:06.743, 16.91,  07:10:07.020, 16.91,  07:10:07.305, 16.91,  07:10:07.591, 16.89,  07:10:08.132, 16.95,  07:10:08.163, 16.92,  07:10:08.438, 16.96,  07:10:08.736, 15.66,  07:10:09.007, 16.93,  07:10:09.571, 16.93,  07:10:09.587, 16.90,  07:10:09.882, 16.94,  07:10:10.186, 16.92,  07:10:10.468, 46.5,  07:10:11.042, 0.019,  07:10:11.056, 0.019,  07:10:11.345, 0.019,  07:10:11.646, 0.019,  07:10:11.918, 0.019,  07:10:12.480, 0.019,  07:10:12.497, 0.019,  07:10:12.781, 0.019,  07:10:13.073, 0.019,  07:10:13.365, 0.019,  07:10:13.928, 0.019,  07:10:13.972, 0.019,  07:10:14.262, 0.019,  07:10:14.542, 0.019,  07:10:15.038, 72.61,  07:10:15.131, 72.70,  07:10:15.403, 72.48,
     07:10:16.288, 16.91,  07:10:16.296, 16.92,  07:10:16.572, 16.91,  07:10:16.868, 16.90,  07:10:17.160, 16.92,  07:10:17.708, 16.94,  07:10:17.733, 16.92,  07:10:18.004, 16.95,  07:10:18.307, 15.66,  07:10:18.589, 16.92,  07:10:19.148, 16.93,  07:10:19.166, 16.90,  07:10:19.435, 16.94,  07:10:19.737, 16.92,  07:10:20.008, 45.5,  07:10:20.565, 0.019,  07:10:20.597, 0.019,  07:10:20.878, 0.019,  07:10:21.153, 0.019,  07:10:21.446, 0.019,  07:10:21.996, 0.019,  07:10:22.016, 0.019,  07:10:22.296, 0.019,  07:10:22.594, 0.019,  07:10:22.876, 0.019,  07:10:23.433, 0.019,  07:10:23.471, 0.019,  07:10:23.749, 0.019,  07:10:24.031, 0.019,  07:10:24.546, 72.61,  07:10:24.619, 72.70,  07:10:24.907, 72.48,
     07:10:25.917, 16.93,  07:10:25.930, 16.91,  07:10:26.235, 16.90,  07:10:26.548, 16.91,  07:10:26.836, 16.89,  07:10:27.397, 16.94,  07:10:27.413, 16.92,  07:10:27.696, 16.94,  07:10:27.978, 15.65,  07:10:28.255, 16.93,  07:10:28.817, 16.93,  07:10:28.859, 16.88,  07:10:29.146, 16.93,  07:10:29.434, 16.92,  07:10:29.721, 45.0,  07:10:30.283, 0.019,  07:10:30.377, 0.019,  07:10:30.768, 0.019,  07:10:31.102, 0.019,  07:10:31.665, 0.019,  07:10:31.677, 0.019,  07:10:31.961, 0.019,  07:10:32.246, 0.019,  07:10:32.549, 0.019,  07:10:33.089, 0.019,  07:10:33.180, 0.019,  07:10:33.186, 0.019,  07:10:33.595, 0.019,  07:10:33.605, 0.019,  07:10:34.236, 72.61,  07:10:34.437, 72.68,  07:10:34.749, 72.48,
     07:10:35.579, 16.93,  07:10:35.592, 16.91,  07:10:35.888, 16.91,  07:10:36.169, 16.91,  07:10:36.453, 16.89,  07:10:37.009, 16.94,  07:10:37.030, 16.92,  07:10:37.311, 16.94,  07:10:37.598, 15.65,  07:10:37.909, 16.91,  07:10:38.486, 16.92,  07:10:38.496, 16.86,  07:10:38.768, 16.94,  07:10:39.061, 16.93,  07:10:39.356, 44.0,  07:10:39.901, 0.019,  07:10:39.913, 0.019,  07:10:40.204, 0.019,  07:10:40.485, 0.019,  07:10:40.793, 0.019,  07:10:41.406, 0.019,  07:10:41.468, 0.019,  07:10:41.751, 0.019,  07:10:42.051, 0.019,  07:10:42.338, 0.019,  07:10:42.915, 0.019,  07:10:42.935, 0.019,  07:10:43.220, 0.019,  07:10:43.530, 0.019,  07:10:44.054, 72.61,  07:10:44.152, 72.68,  07:10:44.443, 72.48,
     07:10:45.285, 16.92,  07:10:45.289, 16.91,  07:10:45.609, 16.90,  07:10:45.936, 16.91,  07:10:46.225, 16.92,  07:10:46.821, 16.93,  07:10:46.870, 16.93,  07:10:47.217, 16.95,  07:10:47.605, 15.61,  07:10:48.253, 16.92,  07:10:48.394, 16.93,  07:10:48.809, 16.90,  07:10:49.550, 16.93,  07:10:49.680, 16.92,  07:10:50.013, 43.5,  07:10:50.619, 0.019,  07:10:50.698, 0.019,  07:10:51.031, 0.019,  07:10:51.387, 0.019,  07:10:52.001, 0.019,  07:10:52.048, 0.019,  07:10:52.363, 0.019,  07:10:52.685, 0.019,  07:10:53.332, 0.019,  07:10:53.410, 0.019,  07:10:53.757, 0.019,  07:10:54.081, 0.019,  07:10:54.693, 0.019,  07:10:54.750, 0.019,  07:10:55.279, 72.59,  07:10:55.358, 72.68,  07:10:55.641, 72.48,
     07:10:56.587, 16.92,  07:10:56.597, 16.92,  07:10:56.943, 16.88,  07:10:57.220, 16.91,  07:10:57.543, 16.90,  07:10:58.131, 16.92,  07:10:58.205, 16.91,  07:10:58.509, 16.95,  07:10:58.858, 15.65,  07:10:59.450, 16.91,  07:10:59.484, 16.92,  07:10:59.786, 16.90,  07:11:00.113, 16.93,  07:11:00.440, 16.91,  07:11:01.048, 43.0,  07:11:01.387, 0.019,  07:11:01.429, 0.019,  07:11:01.734, 0.019,  07:11:02.048, 0.019,  07:11:02.352, 0.019,  07:11:02.925, 0.019,  07:11:02.961, 0.019,  07:11:03.261, 0.019,  07:11:03.549, 0.019,  07:11:03.854, 0.019,  07:11:06.759, 0.000,  07:11:06.768, 0.000,  07:11:07.173, 0.000,  07:11:07.595, 0.000,  07:11:08.156, 72.59,  07:11:08.201, 72.68,  07:11:08.455, 72.48,
     07:11:09.250, 16.91,  07:11:09.260, 16.91,  07:11:09.551, 16.90,  07:11:09.772, 16.90,  07:11:10.060, 16.90,  07:11:10.653, 16.93,  07:11:10.653, 16.92,  07:11:10.947, 16.92,  07:11:11.233, 15.65,  07:11:11.532, 16.91,  07:11:12.087, 16.92,  07:11:12.135, 16.86,  07:11:12.421, 16.93,  07:11:12.691, 16.91,  07:11:12.990, 42.0,  07:11:13.556, 0.019,  07:11:13.568, 0.019,  07:11:13.883, 0.019,  07:11:14.169, 0.019,  07:11:14.454, 0.019,  07:11:15.010, 0.019,  07:11:15.026, 0.019,  07:11:15.298, 0.019,  07:11:15.611, 0.019,  07:11:15.890, 0.019,  07:11:16.432, 0.019,  07:11:16.460, 0.019,  07:11:16.738, 0.019,  07:11:17.036, 0.019,  07:11:17.512, 72.59,  07:11:17.586, 72.67,  07:11:17.874, 72.47,
     07:11:18.748, 16.92,  07:11:18.760, 16.90,  07:11:19.052, 16.90,  07:11:19.336, 16.91,  07:11:19.623, 16.88,  07:11:20.181, 16.93,  07:11:20.194, 16.91,  07:11:20.460, 16.94,  07:11:20.748, 15.65,  07:11:21.035, 16.92,  07:11:21.595, 16.92,  07:11:21.605, 16.90,  07:11:21.888, 16.93,  07:11:22.160, 16.92,  07:11:22.460, 41.5,  07:11:23.009, 0.019,  07:11:23.025, 0.019,  07:11:23.289, 0.019,  07:11:23.575, 0.019,  07:11:23.875, 0.019,  07:11:24.434, 0.019,  07:11:24.442, 0.019,  07:11:24.716, 0.019,  07:11:25.003, 0.019,  07:11:25.289, 0.019,  07:11:25.833, 0.019,  07:11:25.859, 0.019,  07:11:26.131, 0.019,  07:11:26.417, 0.019,  07:11:26.909, 72.59,  07:11:26.997, 72.67,  07:11:27.275, 72.47,
     07:11:28.161, 16.92,  07:11:28.167, 16.91,  07:11:28.462, 16.87,  07:11:28.744, 16.90,  07:11:29.026, 16.90,  07:11:29.567, 16.93,  07:11:29.585, 16.92,  07:11:29.872, 16.90,  07:11:30.155, 15.65,  07:11:30.440, 16.92,  07:11:30.996, 16.90,  07:11:31.014, 16.90,  07:11:31.283, 16.89,  07:11:31.554, 16.92,  07:11:31.856, 41.0,  07:11:32.398, 0.019,  07:11:32.416, 0.019,  07:11:32.699, 0.019,  07:11:32.970, 0.019,  07:11:33.271, 0.019,  07:11:33.827, 0.019,  07:11:33.859, 0.019,  07:11:34.195, 0.019,  07:11:34.199, 0.019,  07:11:34.594, 0.019,  07:11:35.140, 0.019,  07:11:35.233, 0.019,  07:11:35.658, 0.019,  07:11:36.052, 0.019,  07:11:36.619, 72.58,  07:11:36.693, 72.67,  07:11:36.996, 72.47,
     07:11:37.875, 16.89,  07:11:37.881, 16.90,  07:11:38.170, 16.90,  07:11:38.458, 16.88,  07:11:38.752, 16.89,  07:11:39.299, 16.93,  07:11:39.331, 16.92,  07:11:39.637, 16.94,  07:11:39.918, 15.61,  07:11:40.282, 16.91,  07:11:40.844, 16.91,  07:11:40.858, 16.86,  07:11:41.144, 16.93,  07:11:41.427, 16.90,  07:11:41.694, 40.5,  07:11:42.273, 0.019,  07:11:42.355, 0.019,  07:11:42.794, 0.019,  07:11:43.241, 0.019,  07:11:43.828, 0.019,  07:11:43.873, 0.019,  07:11:44.159, 0.019,  07:11:44.445, 0.019,  07:11:44.731, 0.019,  07:11:45.271, 0.019,  07:11:45.287, 0.019,  07:11:45.572, 0.019,  07:11:45.868, 0.019,  07:11:46.143, 0.019,  07:11:46.641, 72.58,  07:11:46.722, 72.66,  07:11:47.010, 72.47,
     07:11:47.841, 16.89,  07:11:47.854, 16.88,  07:11:48.142, 16.90,  07:11:48.412, 16.89,  07:11:48.697, 16.89,  07:11:49.243, 16.93,  07:11:49.252, 16.92,  07:11:49.532, 16.94,  07:11:49.809, 15.61,  07:11:50.092, 16.89,  07:11:50.639, 16.91,  07:11:50.661, 16.90,  07:11:50.951, 16.92,  07:11:51.238, 16.90,  07:11:51.539, 40.0,  07:11:52.088, 0.019,  07:11:52.090, 0.019,  07:11:52.385, 0.019,  07:11:52.670, 0.019,  07:11:52.940, 0.019,  07:11:53.502, 0.019,  07:11:53.520, 0.019,  07:11:53.797, 0.019,  07:11:54.098, 0.019,  07:11:54.382, 0.019,  07:11:54.954, 0.019,  07:11:54.978, 0.019,  07:11:55.287, 0.019,  07:11:55.567, 0.019,  07:11:56.057, 72.58,  07:11:56.130, 72.66,  07:11:56.447, 72.47,
     07:11:57.270, 16.91,  07:11:57.278, 16.90,  07:11:57.565, 16.90,  07:11:57.834, 16.90,  07:11:58.131, 16.89,  07:11:58.682, 16.91,  07:11:58.698, 16.91,  07:11:58.979, 16.92,  07:11:59.255, 15.63,  07:11:59.533, 16.90,  07:12:00.088, 16.90,  07:12:00.127, 16.85,  07:12:00.403, 16.92,  07:12:00.690, 16.90,  07:12:00.961, 39.5,  07:12:01.522, 0.019,  07:12:01.539, 0.019,  07:12:01.832, 0.019,  07:12:02.112, 0.019,  07:12:02.390, 0.019,  07:12:02.931, 0.019,  07:12:02.949, 0.019,  07:12:03.247, 0.019,  07:12:03.526, 0.019,  07:12:03.787, 0.019,  07:12:04.359, 0.019,  07:12:04.391, 0.019,  07:12:04.692, 0.019,  07:12:05.011, 0.019,  07:12:05.585, 72.58,  07:12:05.696, 72.66,  07:12:05.704, 72.47,
     07:12:06.318, 16.88,  07:12:06.365, 16.89,  07:12:06.376, 16.89,  07:12:06.381, 16.86,  07:12:06.672, 16.90,  07:12:07.091, 16.91,  07:12:07.160, 16.91,  07:12:07.714, 16.92,
