I just joined the Prius family....Few ?s
Discussion in 'Gen 2 Prius Main Forum' started by egon10psi, Apr 23, 2017.
  1. bisco
    51,908
    should be in your owners manual.
  2. biglew8
    biglew8 Active Member
    170
    114
    Seattle
    Button needs to be out. From other threads that I read on this issue...
    1. Try other CR2032 batteries. Possible bad batteries due to sitting long in the store.
    2. Possible bad 12v auxiliary battery.
    3. Other fob is within distance of the first one
  3. egon10psi
    egon10psi Junior Member
    50
    West Virginia
    Okay I will try all of this. If this doesn't work I will being my search on how to reprogram the original key fob.
  4. biglew8
    170
    114
    Seattle
    @JC91006 Are you familiar with this issue?
  5. JC91006
    16,768
    8,565
    Edit
    Does the keyfob lock and unlock buttons work? Any of the keys?
    To fix this issue, you would need to reseed the car's key memory. A dealer can do it
    In the meantime, you can make a regular key copy of the little key at home depot, make it a regular key like the cars from 15 years ago
    SM-N900P ?
  6. egon10psi
    50
    West Virginia
    No. Both keys only start the car once inserted. Nothing else.
    I wonder why you can program a new keys but you can't reprogram an old key. That seems odd to me. I guess I have to look for a stealership.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,151
    Tampa, FL
    I have an old fob that was reprogrammed by the dealer. So it can be done, but it only works if I plug it into the slot. As for the metal door key, @JC91006 is right. Practically any place that makes keys can make you one.
  8. dolj
    dolj Senior Member
    8,445
    4,289
    Wellington, New Zealand
    You can't program a new key unless you have fully working old key (to use the Chicken Dance). This is why you need to go the dealer (or a skilled auto locksmith) to reseed the immobiliser then add the old key(s) to the car.
  9. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    As far as Aux input how about in the center console, if I recall
  10. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    I don't know if this is crucial, but what color is the Toyota logo on each of your fobs? Black (non-SKS) or silver (SKS)?
  11. JC91006
    16,768
    8,565
    His locks and unlock buttons both don't work. There have been reports of some keys just not functioning. A working spare would normally fix this problem, doing the chicken dance with the non working fob. But right now we have both fobs not working. Either a battery issue or they'll need to be reseed
    SM-N900P ?
  12. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    If the old keys were originally programmed to the car but somehow got cleared out of the car's memory, they should be able to be added back in with techstream without reseeding, since the ID programmed in the key would match the car. I have the scanner if you want to play with it.
    Also, to pair with Bluetooth, you have to place the radio in pairing mode, somewhere in settings, using the touch screen.
    I have investigated getting an AUX adapter but there are not a lot that work with Prius. I believe one that says it works is GROM.
    iPhone ?
    JC91006 likes this.
  13. Moving Right Along
    Moving Right Along Senior Member
    720
    576
    The aux adapter for 2nd gen Prius is inside the center console, so if this is your first Prius, you may have one and not know it. I'd lift the lid of the console and check just in case.
  14. egon10psi
    50
    West Virginia
    Yes, but I want the key to be fully functional.
  15. egon10psi
    50
    West Virginia
    Silver
  16. egon10psi
    50
    West Virginia
    How would I use it? Do you live near me or is it software?
    I pushed the add phone on the screen and turned bluetooth on my phone on but it never received the code that the stereo was sending out. Not sure.
    Galaxy s6
  17. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I live in PA so it would be kind of a hike but not as far away as some of us here on the forum. Techstream is a combination of software and hardware.
    If you pushed the Add Phone button on the car, and it said discoverable or something similar, then you must also go into Bluetooth settings on the phone and scan for devices and add it there. Default name is "HANDS FREE". On my 04 with Bluetooth, it works for phone calls only, not music FYI.
    iPhone ?
  18. egon10psi
    50
    West Virginia
    Okay I will give a try again this evening.
  19. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    biglew8 likes this.
  20. egon10psi
    50
    West Virginia
    Thank you!
