I need advice - 2007-110,750 miles & DEAD!
Discussion in 'Gen 2 Prius Main Forum' started by Joey40202, Jan 5, 2019.
  1. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Personally I don’t buy anything with the Dorman name on it. Always better to buy the higher quality item and do the job once. If I wanted something built to Vega quality I would buy a Vega.
  2. RandyO
    RandyO Junior Member
    Call me BEFORE you DO ANYTHING ELSE 352-257-9515..Randy in Crystal River.
  3. ChapmanF
    19,014
    There's close to a dozen individual solenoid valves in there that have to open when they open and seal completely when they're closed, so pretty much any of those getting sticky or getting a little piece of grot in the seal would be a problem. There are also several pressure sensors, but I bet those don't go bad much. I could be wrong.
    Because the Gen 2 combines the actuator, accumulator, and pump into one big assembly, there's also an electric pump there. It could wear out. The accumulator has a thin metal bellows inside that could eventually fatigue and crack and leak.
    If I had to bet, I'd probably have my money on a gummed-up valve most of the time, just because there are so many of them in there, and failure of any one of them fails the whole works.
    But probably every unit that comes in has to be diagnosed, and just have whatever failed get fixed. If the motor can be easily disassembled, changing the brushes might be a thing I would do, if I were a rebuilder.
    But no, I've never had even one apart, let alone a statistical sample, so I don't know what they really run into most often. The DTCs you can read can give a lot of information about what exactly's gone wrong, but since the only supported repair is to replace the whole thing anyway, I imagine most people aren't that curious.
    jerrymildred, Raytheeagle and JC91006 like this.
  4. JC91006
    16,936
    8,647
    It would be nice if Matt @texashybridbatteries could refurbish one of these up. I would feel much better buying a refurbished unit vs used units from a wreck. Realistically the replacement parts only have to last 3-5 years before your car will become too old and will end up in the wrecking yards
    padroo and jerrymildred like this.
  5. Joey40202
    Joey40202 Junior Member
    28
    Naples, FL
    Are these issue worth repairing or is it a cut my losses and move on?
    Basically, at this point it's a game of "Russian Roulette" for me — pay up front to have the for the traction battery ordered and once they are installing the battery that is the only way I find out if if the ECU is bad? Dealer quoted me $918.XX for the ECU not including the installation time and cost of the ECU. Does this sound like the normal process?
  6. JC91006
    16,936
    8,647
    The ecu rarely goes bad, so I think you can skip it.
    A used one on eBay would be less than $200
    SFO likes this.
  7. Joey40202
    28
    Naples, FL
    Yes, I agree. That is they way I am leaning. I just don't want to get caught in the middle of the install of the HV battery and get slammed there. Is the ECU a hard DIY install/ Does the ECU involve reprogramming or is it a "plug and play" installation?
  8. JC91006
    16,936
    8,647
    Plug and play, but I seriously don't think you'll have an issue.
    I'll sell you one if you're worried
  9. Skibob
    2,912
    1,505
    Northern California
    Here, this video will get you to where you can see the ECU. I don’t know if you have to completed remove the battery to inspect it. Perhaps some with more experience can comment on that.
  10. strawbrad
    953
    1,007
    Here is a good explanation of the battery ECU corrosion issue.
    The battery fires at ECU sense connector thread | PriusChat
    In Minnesota about 5% of the ECU's have some level of corrosion. You just do not know until you open it up. I have reports from AZ that 0% of the ECU's corrode there. Humidity is a factor.
  11. T1 Terry
    T1 Terry Senior Member
    970
    551
    Are there vehicle dismantlers in the US that will supply a complete traction battery assembly with say 1 mth warranty at a reasonable price? Perhaps this could be an option because the one I bought local here in Australia came complete with the battery computer, harnesses, relays and solenoids ready to simply connect the vehicle wiring harness plugs and the 2 high voltage connectors. Now I have a spare set of all the bits that I can play with and mix and match later if needed.
    On another thread I was informed that the battery computer numbers go up as the factory improvements are made, so the computer with the highest last 3 digits is the better unit because it has the most up to date mods on board
    T1 Terry
