I want bigger softer riding tires for next tires.
Discussion in 'Prime Main Forum (2017-2022)' started by The Big Sleaze, Feb 7, 2022.
  1. The Big Sleaze
    289
    64
    'frisco
    2020 Prius
    Two Eco
    (sigh)
  2. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,687
    Somewhere in Wisconsin
    2013 Chevy Volt
    So to answer your question you will be the first one to install wider tires without modded rims and “hopefully” report back
    So test it out and report back your results, everyone else who has upsized did so using the same width tire or used an offset and lift
    Biggest tires you can put on a stock Prius? | PriusChat
    Also It is known 215/70r15 rub unless you do something to lift the car, 205’s who knows?
    Good luck
    #22 Rmay635703, Feb 8, 2022
  3. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    I looked at tirerack.com tire decision guide. Stock size, selected only for ride comfort. They suggested Vrederstein Quatrac, also Michelin CrossClimate+ or Vrederstein Hitrac. A tire made to run with less harshness, at the recommended inflation pressure, will give a better ride without any concerns about a size problem. A size bigger tire run at a bit lower pressure will ride softer, but may have interference problems.
  4. The Big Sleaze
    289
    64
    'frisco
    2020 Prius
    Two Eco
    I'm also wondering about that sorta soft rear wheel well lining stuff. I seems like only stuff that will rub so maybe I could rip it out and replace with some spray rubber to sorta keep things quiet or rust free or whatever then replace the stuff with factory if it becomes an issue and want to return to small tires.
    Its there some time test method used by pros to determine if a newly installed tire is rubbing? What substance could I smear that will clearly show any rubs, handle a 80mph test run, but also wash off OK?
    Just discovered I'm also the proud owner of a 1999 vintage Ford Taurus sporting 205/65r15" and seems to have room so if the Prime tire upgrade has issues I can just put new tires on the Bull since it could use some and bigger tires fine for it, too.
    #24 The Big Sleaze, Feb 10, 2022
