Im seeing water in my spare tire well. Why?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jimbo69ny, May 8, 2012.
  1. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    Its not a lot of water but I am concerned. Where is it coming from. Has anyone else experienced this?
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Clean, dirty? If clean probably the hatch seal is damaged somewhere or pinched. Up near the top. If dirty it could be damage to the wheel wells letting road spray in. Also check the antenna. If it leaks the water will end up in the hatch and the tire well is the lowest point.
    Also possible you carried something in the back that had a little water in it (leaking water bottle?).
  3. wjtracy
    wjtracy Senior Member
    11,315
    3,588
    Northern VA (NoVA)
    Jim- It is a potential concern for the EV batt you want to minimize the water.
    A few owners have indeed mentioned this so if you search you will find. Unfort it can be hard to track down cause. Automated car washes one cause for some.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Yes reports of water in trunk. Some have been caused by a crack in the body seam located at the top of the hatch valley right off the hinges. In the valley itself in the top corners you'll see where the factory spot welded the quarter panel to the roof. You can see the spot welds under the paint. Reports of cracks right there. You have to take the inside covers off to expose and check for rust trails. Cracks probably from slamming the hatch all the time or maybe the car see's alot of really rough terrain and gets a beating.
    Some have reported water coming in through a missing valance piece in the pass side rear wheelwell back feeding water in the battery area.
    And some but few have reported a leaking seal in the taillight. You should see water tracks at the bottom of the seal inside.
    TJK and GrumpyCabbie like this.
  5. Jimbo69ny
    712
    107
    Ithaca, NY
    Its been raining a lot for the past few days. It appears that the water is collecting in the small valley on the driver side behind the tail light. I see what seem to be water stains from water coming down the left side tire well. Without taking the driver side interior panels I cant say for sure where it is coming from. I think the water is making it into the spare tire well from the left side during cornering.
    Ill have to do some serious pannel removal to figure out where its entering the car. :/
  6. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    I purchased a CRX with that problem. It took me forever to hunt down the culprits.
    The big one was cracks in the body seams under/around the hatch area. I fixed those with silicone sealer.
    The other problem was tail light gasket failure. I tried a number of different things, though never purchased new ones. I wound up simply drilling holes on the underside of the plastic to let out any water that may have gotten in. It worked for me on my $875 CRX, but I wouldn't recommend drilling holes for you. Not yet anyway...
  7. cnschult
    cnschult Active Member
    772
    95
    Michigan
    in the meantime remove the rubber drain plugs in the spare tire well and 12V battery compartment (yep that is PIA you have to remove the battery).
    check the rear footwell carpet for dampness, if its damp you may have to lift the rear seat bottom at the front to release the rear carpet, then remove the rear door sill plastic covers to remove the rear carpets, you may not have to remove the carpet entirely as that entails removing the front seats, GPS & JBL units, I bungee corded my rear carpet up to allow some air circulation in to dry the carpets, there are also some rubber drain plugs in the rear seat footwells under the padding (toyota calls these sound insulators)
    some threads say the best way to diagnose is to sit in the car while someone outside sprays it with a garden hose until you find the problem, which is very difficult to do, the crack could be tiny and the water had been slowly accumulating for years.
  8. TJK
    TJK New Member
    Washington Crossing
    Yes - gee thanks Toyota - I'll sit in the hatch while a buddy hoses down the car rather than you sell a car that doesnt leak. Awesome. Next time I'll buy 2!
    Also you can puch the rubber stopper up from under the car if you dont want to take the battery out. Might save some time..
  9. bisco
    49,056
    i haven't seen it on my '04, '08, or '12, must just be lucky i guess. the worst thing is that these problems are happening on cars that are only 7 or 8 years old!
  10. exstudent
    exstudent Senior Member
    2,212
    900
    Torrance, CA
  11. Tbkilb01
    Tbkilb01 Active Member
    215
    187
    Louisiana
    I own 3 2011
    All accumulate water under 12v battery... there’s a rubber plug..bung... I pulled them all and they stay dry now .also check under spare...
    #11 Tbkilb01, May 22, 2023
