Installing in car entertainment..any pointers?
Discussion in 'Gen 4 Prius Main Forum' started by Archenemy, Feb 5, 2017.
  1. Archenemy
    Archenemy Junior Member
    24
    Singapore
    Hi people...i intend to get fix up a basic sound system in my gen 4 prius..ie a monoblock amp with a subwoofer..a 4 channel amp to power some component speakers..
    Any concerns? Is the electrical system any different from normal cars? My worry is the monoblock amp which may suck up too much power from the electrical system from the car...
    Hybrid cars aren't popular in this part of the world so im afraid that the audio shops aren't experienced enough to handle hybrid vehicles.
    Any tips for me?
    Thanks in advance!
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
  3. Archenemy
    24
    Singapore
    Thank you!
    RCO likes this.
  4. Elektroingenieur
    2,515
    3,288
    Three Touring
    The low-voltage electrical system on the Prius differs from other modern cars mainly in that the auxiliary (12 volt) battery is charged by a DC-DC converter powered from the hybrid vehicle battery, not by an alternator connected to the engine.
    I would still suggest being careful about how much electrical load you add. In their training course T623, Electrical Circuit Diagnosis, Toyota writes, “The circuits protected by a single fuse are designed so that normal current does not exceed 70% of the fuse’s rating.” I would suggest keeping the sum of existing and new loads on any circuit below this value, though without access to Toyota’s design information needed for a full electrical load analysis, there are, of course, no guarantees of trouble-free operation.
    In some markets, Toyota sells the Prius with an optional sound system with a separate amplifier, for which there is a dedicated, 10-ampere AMP fuse, separate from the 15-ampere RADIO fuse for the head unit. See pages 3 and 4 of this wiring diagram:
    http://www.toyota-tech.eu/td3ewd/EN/EM3211E.V.1_v1/ewd/contents/system/pdf/AS-SEP.pdf
    Compare the version with a built-in amplifier:
    http://www.toyota-tech.eu/td3ewd/EN/EM3211E.V.1_v1/ewd/contents/system/pdf/AS-BUI.pdf
    (These diagrams are for European models; your car may differ.)
    In the U.S., the separate amplifier is a six-channel JBL unit, installed under the driver’s seat. My car didn’t come with this, but interestingly, it does have the AMP fuse. I don’t know how much, if any, of the wiring for the separate amplifier is provided in cars that didn’t originally have it.
    RCO likes this.
  5. Archenemy
    24
    Singapore
    Wow that is a really detailed explanation..but im not that technically inclined...
    What i understand is that we cant place a heavy electrical load on the vehicle...
    But what is considered heavy? How many watts? How many amps? My apologies..im really an idiot when it comes to such things..
  6. Prodigyplace
    12,704
    11,846
    Central Virginia
    Be careful. Electrical watts consumed by an amplifier is totally different than the rated audio output in watts.
    They should be related but marketing got in the way :(
    RCO likes this.
  7. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    That is easy to figure out how many Kw of power you want on amplifiers......
    This is not impossible....how much are you thinking to dish out.....Anything is possible with .....it doesn't matter what type of is it
    RCO likes this.
  8. Archenemy
    24
    Singapore
    Noted. does the spec sheets of the amplifier manufacturers state the watts consumed?
    I only know that they show output in watts..
  9. Archenemy
    24
    Singapore
    Please assist in layman terms..thanks!
    Budget is around US$1000 for monoblock+subwoofer and US$1000 for 4 channe amp+components.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    This water is way too deep for me, so I'm going to dry of and have a nice cup of hot tea. I wish you all the best in your quest for superior sound system.
  11. Prodigyplace
    12,704
    11,846
    Central Virginia
    For power consumed from a direct current system such as a car you can multiply the voltage (I would use 14) by the current consumed in amps.
    14 volts X 2 amps = 28 watts.
    RCO likes this.
  12. Prodigyplace
    12,704
    11,846
    Central Virginia
    For alternating current used in a home the calculation is much more complex.
    RCO likes this.
  13. Archenemy
    24
    Singapore
    Why 14 instead of 12?
    You are assuming that the amp is 2 amp? Or is it 2 amplifiers at 1 amp each?
    So 28 watts is safe?
  14. Prodigyplace
    12,704
    11,846
    Central Virginia
    Although the battery voltage is nominally 12V, I believe the inverter actually boosts it to 14.4V. Using 14 allows the for a little safety margin from 12V and is closer to the real world voltage.
  15. Samprocat
    491
    297
    Lincoln, NE
    You will need to invest on battery bank new wiring and capacitors......this cars don't like spikes in current draw for amplifier......
    You will need more in this than what you are just thinking for one mentioned....so your budget is not adequately peaced together......
    If you want to do it right ......
    RCO and Prodigyplace like this.
  16. Samprocat
    491
    297
    Lincoln, NE
    I wish i can help more.....
    With your budget this is not good place to start with.....
    RCO likes this.
  17. Archenemy
    24
    Singapore
    I have existing capacitor for my monoblock..can bring over to my new car..
    Is it recommended that i get another capacitor for the 4 channel?
  18. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    I hope the frequency response of your amp isn't to high, you could pick up converter noise. The Prius is a rolling EMI generator.
  19. Archenemy
    24
    Singapore
    Is there anyway to prevent this?
  20. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Yes. The obvious one of sticking with the original fitting.
    Prodigyplace likes this.
