interference versus noninterference engine??
Discussion in 'Prime Main Forum (2017-2022)' started by bear15, Jun 3, 2017.
  1. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    Does anyone know if the gas engine in the Prime is an interference or noninterference engine? I know a noninterference (free-running) engine will not be damaged if the timing belt breaks. I also know that the 2003 Toyota Highlander has a noninterference engine so when the timing belt broke at 150,000 miles or so no engine damaged occurred.
  2. Insirt
    Insirt Junior Member
    50
    60
    South Carolina
    I guess it's non-interference but I'm not sure if it's applicable since the Prime and all Prii don't have a timing belt or chain (or any real transmission just a torque converter, unrelated to timing).
    If you're worried about powertrain lifespan don't be; it lasts longer than almost all vehicles.
    EDIT: My mistake all Prii including the Prime have a timing chain for the ICE. See other better informed responses...
    #2 Insirt, Jun 3, 2017
  3. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Prius uses a chain instead. So, concerns related to a belt don't apply.
    dalcon95 likes this.
  4. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    This is helpful information. I did not know that all Prii (and the Prime) do not have a timing belt or chain. My son has a 2016 Prius C so I am safe to assume that is true for his car also? Many thanks.
  5. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    John- can you clarify please. I am confused by the post #2 regarding no chain. Thanks
    john1701aPrius Guru
  6. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    All Prius years and model variations have timing chain.
    #1 in Easley,SC
    jerrymildred likes this.
  7. bisco
    52,848
    there is a timing chain under a cover on the engine. i don't recall ever hearing about one breaking, but i suppose they stretch a bit after very high mileage.
    a bigger issue has been a leaking cover on some models, which requires a lot of disassembly to repair.
    #7 bisco, Jun 3, 2017
    dalcon95 and Raytheeagle like this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Here are several pics of the timing chain and the 1.8L engine internals on the Gen3 motor:
    Blown Head gasket rebuild....@297k
    Peruse at your leisure this thread as it has good documentation and discussion around the 1.8L engine;).
    Enjoy the light weekend reading (y).
  9. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    Awesome pics and information- many thanks!! However, I think this brings us back to my question. Does anyone know if the gas engine in the Prime is an interference or noninterference engine? I know a noninterference (free-running) engine will not be damaged if the timing belt or chain breaks.
    wrote before:
  10. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    Hi Bisco- What is a "leaking cover" and at what miles have we been seeing this?
    Wrote before:
  11. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Very few reported claims of the timing chain breaking or failing. There have been many Prii that have eclipsed 300 k miles without issue with the chain. In a Prime, the engine should be running less (depending on your use) so less risk of damage.
    If the chain were to fail, I would assume some damage would occur. But in the 20+ years of driving I have logged in various different makes and models, I have not dealt with that issue.
    bisco and dalcon95 like this.
  12. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Here's a recent thread on the topic with a link to another thread on the same topic:
    Timing cover leak
    More light weekend reading (y).
  13. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    How can we check, just for interest, if it is a noninterference (free-running) engine and will not likely to be damaged if the timing belt or chain breaks, etc.
  14. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    Interesting . . . many thanks.
    Raytheeagle likes this.
  15. dalcon95
    512
    653
    I think most new engines are interfering because of close tolerances and high compression.
    #1 in Easley,SC
    Valiant V, bisco and Raytheeagle like this.
  16. bear15
    bear15 Member
    168
    36
    Suburban Chicago
    I also know that the 2003 Toyota Highlander (and several other Toyota engines) has a noninterference engine so when the timing belt broke at 150,000 miles or so no engine damaged occurred.
  17. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    It is still a valid question but your use of the term "free running" sounds like you don't really know what the concern IS.
    With over head valves OHV, if the valves are still full open when the piston reaches top dead center TDC, the valves can hit the top of the piston unless the clearances are designed to prevent that.
    Anything that throws the valve timing WAY off can cause the collision in an "interference" design.
  18. dalcon95
    512
    653
  19. Mendel Leisk
    42,343
    Just for novices not conversant with the terminology: saying an engine is "interference" means if the camshaft rotations are not properly synchronized with the crankshaft, that both are allowed to turn freely and independently (due to absence/breakage/misalignment of timing belt or chain between the two shafts), then it is possible for the pistons to hit the valves.
  20. LouG123
    LouG123 Member
    49
    47
    Vernon Hills, IL
    Gates is the primary supplier of automotive belts in the US. They used to have a means of searching for a specific car to tell you whether or not it had a timing belt, and if so if it was an interference engine, but I can't tell from my phone. You may want to search here:
    Timing Belt System Products | Gates Corporation
