Inverter pump failure with no symptoms?
Discussion in 'Gen 2 Prius Technical Discussion' started by ProspectivePriusPeruser, Apr 30, 2020.
  1. pasadena_commut
    pasadena_commut Senior Member
    3,071
    956
    Southern California
    Cancel that pump order! You only want the OEM. The other brands have not been reliable.
    Regarding "motion" in the tank. The OEM unit I have in there now barely makes the surface move at all. But the car will run for hours on the highway on a hot day and when we get home TechStream shows the inverter temperature is OK. Also, what do you think is moving the fluid through your bleed screw if not the pump?
    Lastly, when you close the bleed screw be sure to thoroughly dry it off. Then if you look at it later and it is crusty you can reasonably suspect a slow leak at that screw. The first time I changed a pump I didn't do that, and it was crusty. But it was not leaking at the screw, it was just the little bit of dried fluid which had not been cleaned off.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    I saw really good turbulence in my reservoir right up the the point it failed on me about 2 weeks ago. The fluid looked like it was boiling.
    Lasted 100,000 miles on the pump that was replaced under a TSB years ago.
    Got the RTOD flying down the highway on a cool day. Pulled over first thing I checked no movement in reservoir. Limped back to work and left it there till i could tow it home the next day.
    I am an expert at pulling the bumper down to remove the headlight and get to the pump. That takes like 5 minutes just like Luscious does.
    Back to very good turbulence. It was a bitch getting the hoses to come off though they were really stuck on. I duckbilled the hoses and lost no coolant at all. I have to get back in there and replace it its been years.
    If you have very poor turbulence it probably has the original coolant and sooner or later like many posters we have seen you will get a clogged inverter cooling channel. Its probably already clogged. Turn the car on ignition only so you can hear the pump it has such a soft whine you can hardly hear it. If its loud its struggling to pump.
    It has a ton of very small cooling channels in the big block of aluminum under the inverter. Its integrated into the inverter you must replace the inverter assy to fix a clogged cooling system. never saw someone selling a separate cooling chamber.
    The invert coolant should run about 110 degrees cooler than the ice.
    I bought my car new and replaced the inverter coolant at 5,000 miles. That's the secret. Get all that break in stuff out of there. Same with the ice coolant. Same with the trans. On new cars period.
    OEM pump was expensive. Much cheaper online but she needed the car asap.
  3. MathWeijzen
    MathWeijzen Junior Member
    74
    Netherlands
    Yes, i know the pump is running...but like it should..?Are you saying ¨...Do replace the pump, but only OEM..? Or are u saying barely no movement at all is normal as long as the OEM pump is in there...?
    I guess there has to be some turbulence according to Toyota service Manual-> After correct bleeding procedure: it says..¨..Standard: Water pump noise becomes softer and coolant circulation in reserve tank improves. Coolant system air bleeding is complete. HINT: If air remains in the coolant system, the water pump noise becomes louder and the coolant circulation in the reserve tank becomes worse¨?
    #23 MathWeijzen, Jan 29, 2021
  4. MathWeijzen
    74
    Netherlands
    I dont quite understand the whole story here...now you are saying ¨..cooling system is likely clogged and replace the inverter assy...¨?
    And what is RTOD? And in the end u replaced with no OEM pump and all back to ´normal´? What exactly is the invert coolant temp..194 F - 110 F = 92 F..? Is that Fahrenheit?
    #24 MathWeijzen, Jan 29, 2021
  5. MathWeijzen
    74
    Netherlands
    And now im a bit confused...maybe theres no problem at all, like i said before no DTC no warning lights no problems whatsover...maybe another thread that got me thinking...like so often on a forum...
    Spareparts i buy also for other cars i owned and now the Prius is always Aftermarket no OEM..never had any troubles sofar.
    I think i try and install the aftermarket pump to see if than i have more turbulence in reservoir..or I get a decent OBD reader and measure the coolant temp...could be still air trapped in there,....
    #25 MathWeijzen, Jan 29, 2021
  6. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Was not talking to you I’m talking to the OP original poster.
  7. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    Yes, it is quite possible you have no problem, except that you reported no discernible movement visible in the inverter reservoir with the car in IG-ON. So either your pump is not working or not working effectively or you have a blockage somewhere in the system.
    Here are two videos. The first one will give you an idea of what we are meaning by "movement'. The second one, skip to 11:10 and view the bleeding of the inverter loop (between 11:10 and 16:00). See how it compares to what you're experiencing. I'll make a couple of comments 1) the hose he is using is far too long. It only needs to be about 50 - 60 cm. 2) he needs to open the bleeder valve more so there is a better flow. He opens it just over a ¼ turn, but it really needs more like a full turn.
    1) Video of Inverter Coolant flow with new pump.
    2) Inverter Coolant Change DIY Video
    I hope that is of some help.
    #27 dolj, Jan 29, 2021
  8. MathWeijzen
    74
    Netherlands
    ok thank u for the vids...I´m experiencing the same like in vid 2 with the bleeder valve more open...
    #28 MathWeijzen, Jan 29, 2021
  9. MathWeijzen
    74
    Netherlands
    Update:
    After trying bleeding system, which i hope i did the right way..quite some fluid lost... enough still ...
    ...I took my car for a 45 minutes drive ...coolant temp 85 degrees C..
    I openend the reservoir and hey..... turbulence....
    my guess its all due to the temperature of coolant and inverter.....and maybe how full the reservoir is..
    i check it again tomorrow morning when its cold...for now i cancelled the new pump order.
    #29 MathWeijzen, Jan 29, 2021
  10. MathWeijzen
    74
    Netherlands
    Checked again this morning Coolant temp 6 degrees C....no turbulence....(n)
  11. ProspectivePriusPeruser
    ProspectivePriusPeruser Junior Member
    50
    Australia
    Wow! Forgot about this thread!
    Just as an update on where this ended up.
    My complacency came back and bit me on a 28c day when I was driving home from work and I got the red triangle. I fought with techstream to attempt to monitor inverter temps but my car has an undiagnosed OBD2 issues so that lead nowhere.
    I bought an inverter pump and did an install myself which was dead simple (did have to make an emergency run to buy SLLC after my hose clamps didn't work too well!).
    The issue was immediately resolved and my Prius has worked perfectly since (except 3 days after I replaced the pump when the battery fan stopped working, that was a fun one to fix)
  12. MathWeijzen
    74
    Netherlands
    ok good for u.....luckely i do not have no Red Triangle....no nothing
  13. MathWeijzen
    74
    Netherlands
    by the way...how much coolant do u need to fill up the transaxle/inverter coolant system when you wanna change it?
    I just read in another post ..2-3 US quarts...?
    #33 MathWeijzen, Jan 30, 2021
  14. pasadena_commut
    3,071
    956
    Southern California
    I put in one of these:
    More Information for DORMAN 601015
    it worked great, except when it didn't. Lots of turbulence normally. However, the inverter coolant temperature problem repeated with it in, and it turned out that it would, every once and a while, fail to start when power was applied to it. When that happened on a hot day with a highway trip, bad news. Long post about it here (currently the last post in the thread)
    How to Replace the Inverter Coolant Pump | Page 11 | PriusChat
    I discussed this pump issue with my mechanic at one point and he said they never put in anything but the OEM because the others fail too often.
  15. MathWeijzen
    74
    Netherlands
    of course they always go for the most expensive OEM part they can get...
    what pump was the OEM..?
    #35 MathWeijzen, Jan 30, 2021
  16. dolj
    dolj Senior Member
    8,655
    4,406
    I know a lot of dutchmen like a good bargain but the inverter coolant pump is one of a few parts I'd recommend not trying to save a few Euros on. What you save on money you loose in time and inconvenience redoing the job before you should have to.
    The Inverter Coolant Pump part is: Pump Assy, Water Toyota part number: G9020-47031.
  17. MathWeijzen
    74
    Netherlands
    thanks, that i already know...and i know what i ´m doing.....but u dont like a good bargain?;)(y)
    #37 MathWeijzen, Jan 31, 2021
  18. dolj
    dolj Senior Member
    8,655
    4,406
    Of course I do, but I don't see it as a bargain when It costs me more money to buy a replacement prematurely (because it failed early) and takes my car off the road (often at the most inconvenient time). I prefer to buy quality parts and do the job only once every 160,000 km.
    But each to their own.
  19. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    Cheap and GOOD is a bargain. Cheap and BAD (fails in a short amount of time) is a waste in my opinion.
    Not every OE part is well designed but in general, you often get what you pay for. Everyone's financial situation is different, but for me I prefer to spend (a little more) once and not have to do it again for years.
    I like the concept of what companies like Dorman set out to accomplish. Unfortunately experience has shown that the quality of what they produce is usually horrible.
    dolj likes this.
  20. MathWeijzen
    74
    Netherlands
    I did some measurements with Torque app, outside temp 6 C, 20 km drive, nex time I wanna drive a bit more...
    Looks ok for now ..try again in the summertime...
