Inverter replaced, car won't start...
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by mitchmarket, Jun 21, 2017.
  1. mitchmarket
    mitchmarket Junior Member
    Johns Creek, GA
    Technology
    Ok, so I got my inverter and pump replaced tonight, go to start the car and it wont...I get dash lights like a Christmas tree but, nothing beyond that. The pump doesn't circulate any fluid either. Any thoughts yall?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Got a code reader? Techstream software on an old laptop? Try disconnecting the 12v then reconnect to see if it will start?
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    Take it back to the dealer or whoever changed the inverter. Brand new inverter by the dealer or used? I know they have to flash the system for the new inverter but I have to assume you drove it home?
  4. JC91006
    16,477
    8,394
    What year is this car?
  5. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    2012 from the other thread and for some reason DIYing....
  6. JC91006
    16,477
    8,394
    Well you should check if the battery interlock is locked in place. I'm assuming you took that off
  7. mitchmarket
    Johns Creek, GA
    Technology
    Shade tree mechanic to save $$$. Took your advice Ray and checked the connections. Fired right up. Ended up being the fuse lever wasn't properly engaged. First time doing this project so, overlooked it. All in cost for a used inverter, inverter pump and high voltage gloves was about $320 and 4 hours of effort.
    Hitting the hay and will bleed the coolant tomorrow when I have something in my tank. Thanks everyone.
  8. rjparker
    7,918
    4,680
    Texas Hill Country
    Hate to tell you this but Toyota has a recall on the inverter even past warranty.
    Tim Jones likes this.
  9. mitchmarket
    Johns Creek, GA
    Technology
    I already checked with Toyota. It's not covered.
  10. Kmun
    Kmun Junior Member
    Oregon
    I have similar problems. Where is this "Fuse lever" that you discovered.
  11. Air_Boss
    Air_Boss Senior Member
    3,941
    1,078
    New Yawk
    Orange HV interlock that connects the traction battery bank.
  12. Mendel Leisk
    38,651
    Info:
  13. ericbecky
    ericbecky Hybrid Battery Hero
    4,369
    3,217
    Madison, Wisconsin
    Another common problem is improperly reseating the inverter connector if it was unplugged during the procedure.
  14. Scott Caputo
    Scott Caputo Junior Member
    37
    Los Angeles
    How do you know if the connector is connected correctly?
    Air_Boss likes this.
  15. Scott Caputo
    37
    Los Angeles
    what is meant by flashing the system? Is there another term for that, nothing comes up when I search it. Thanks
  16. rjparker
    7,918
    4,680
    Texas Hill Country
    Flashing the system means updating the firmware/software. Usually not needed if you bought a good used inverter and got the right part.
    #16 rjparker, Sep 9, 2022
  17. ChapmanF
    15,464
    There is an MG ECU inside of a Gen 3 inverter. There were recalls (E0E for the liftback, F0R for the v) that changed the MG ECU firmware "calibration" version.
    In the unlikely event of getting an old Gen 3 inverter that hadn't had the recall applied, and contains the wrong firmware version, it would be good to have that updated.
    The calibration IDs can be viewed in Techstream and compared to the corresponding recall docs to see if the proper version is already there.
  18. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    The inverter IS Covered.......................................
    Call another toy dealer.......... you need tech stream to install and add the inveter........
  19. Kyle Salmons
    Kyle Salmons New Member
    Ohio
    Not all of them are covered under the recall. It depends on the VIN.
  20. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
