Is anyone have this HITCH?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by scooter4n, Aug 31, 2012.
  1. scooter4n
    scooter4n Junior Member
    27
    27
  2. peterjmc
    917
    188
    Clarksburg, MD
    I don't have any opinions on the Draw Tite brand hitch. A number of users have the Hidden Hitch brand hitch.
    Hidden Hitch
    Check out the Rack thread for pictures of different bike hitch racks, Show Us Your Rack! | PriusChat
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Drawtight makes a good hitch. I have a Curt. Got it from etrailer...in fact its an advertisment on the top of this page.
    Btw, you can buy the trailer light harness that has a little auxillary power supply and it plugs right into the back lights. You need an aux power supply as the car light circuit was designed for low current LED's so if you hook trailer incan's to the car's wiring it may exceed the car's current capabilites and may damage light harness harness. Do not chop the light wires to interface lights for the trailer. Got my wire kit from etrailer too. Plug & play. etrailer on ebay.
  4. Ajvdub
    Ajvdub New Member
    51
    La Crescenta CA
    I put the Curt hitch on as well, 4 bolts, with the car in the air and a ratchet, extension and socket it took me 8 minutes. It hides away well, no cutting needed and it looks clean.
  5. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    I wish someone would come out with a hitch that will not rust. All these will be pure rust in 2 years in any area that gets snow.
  6. scooter4n
    27
    27
    I think IM going to stick to Curt 11469, looks good, easy install, no trimming.
    Thanks all
  7. edthefox5
    10,096
    4,795
    Clearwater, Florida
    AS far as rust get Rustoleum shiny black paint and paint the hell out of the empty tubes. Thats where the water sits and it rusts out. Then after installation light paint of the 4 bolt heads. But make sure you lubricate those 4 bolts before installing them.
    Lastly find some wide black tape. Don't drive around with the hitch in it. Tape off that empty hole the hitch sits in when not using it. Looks really good if done right. Looks like a nice blank hitch plate. My Curt is over 2 years old and not speck of rust on it or in it.
    If you drive around with the hitch in it, it will rust up pretty quick.
  8. edthefox5
    10,096
    4,795
    Clearwater, Florida
    Some have it real easy and alot like me get a Curt that doesn't quite fit. The big mounting plate ears on the end sometimes don't align up with the chassis bolt holes. Mine was 1/4 of an inch off. There welding jig sucks.
    Big long Curt thread about that somewhere. I had to ream it out and bend the ears. Added 2 hours to the job. I could have shipped it back & they would replace it but thats a hassle as the thing is heavy and would have put me
    behind shedule with my tow job.
    Its still a good hitch if you get lucky. But don't be surprised if it don't fit.
    And don't forget the trailer wiring kit. The one with the extra power supply. Its plug & play with no cutting of any harness. Think its $40.
  9. edthefox5
    10,096
    4,795
    Clearwater, Florida
  10. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
  11. edthefox5
    10,096
    4,795
    Clearwater, Florida
    Gen II but I would imagine there crappy QC is across the board. Some people are lucky and there straight. Some are not.
  12. Sfcyclist
    1,621
    375
    SF, CA
    Since they use fixtures to fabricate weldments, I would like to know if anyone with a G3 has issues.
    The rounded tubes on the Curt look nicer than square on Hidden Hitch.
  13. Smee342
    Smee342 Junior Member
    32
    i got the curt hitch installed, it works great. i use mine for my bike rack.
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I used the spray-on bed liner for our last two hitches and they look great w/o any rust (visible anyway).
  15. mainemanx
    mainemanx Member
    355
    40
    State O' Maine
    My Curt went in smooth as... uh, well, it went in smoothly ;)
    However, I highly recommend a 2" receiver! 95% of all accessories are 2". 1 1/4" to 2" adapters are available, but invariably, they are not a tight fit... albeit, they do go in smoothly....
    For example, when the bike rack is not in use, I wanted a push bar/nerf bar to help protect the rear bumper.... nothing available for a 1 1/4" receiver.
  16. Sfcyclist
    1,621
    375
    SF, CA
  17. Sfcyclist
    1,621
    375
    SF, CA
  18. edthefox5
    10,096
    4,795
    Clearwater, Florida
    Like anything on your car it will rust if you do not lubricate it. I sprayed this stuff on the car chassis mounting area where the wings meet the body, the bolt holes, and filled the inner tubes of the hitch and receiver area. Years later still looks like new. Entire car chassis is lubed also. Never a sound under there. No squeeks, no groans, no clunks. And no rust. This product is the best. NO SMELL and designed to be sprayed on things you don't want to rust. Its grease and stays where you spray it. Excellent product:
    PB Blaster CSP Corrosion Stop Protectant 11oz | eBay
    Do not use WD-40!!!
  19. mnsweeps
    mnsweeps Member
    108
    16
    Los Angeles CA
    can you recommend a 2" receiver or which one did you install ? I too want to avoid the 1.25 to 2" adaptor.
  20. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    there was a hitch early on in the G3 lifespan that was 2", but it's since disappeared.:(
