Is changing the TPM battery impractical?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by gatorback, Jul 14, 2025.
  1. gatorback
    gatorback Junior Member
    60
    I inherited a 2010 prism and I've never had a car with TPM: the TPM dashboard indicator is indicated. I've heard that it is not worth the time and effort to change the battery in the sensor. Is this true for the Prius? If a new sensor is changed, I understand that it must be "programmed" into the car.
    Maybe it is possible to program a new sensor with the old sensor's ID? As always, lessons learned and references (videos / links) are always appreciated: Thank you
  2. ChapmanF
    19,009
    There are aftermarket sensors whose IDs can be programmed, using a tool that does that.
    By contrast, the original sensors (and their replacements) come with fixed IDs that you program into the car using a tool that does that.
    6 of one, ½ dozen of the other.
    Whether it's practical to change the battery comes down to what you think is practical. There are posts here where people have demounted the tire and taken the sensor out and dug through all the potting compound and unsoldered a battery and soldered a new one in and re-potted the whole thing with new compound. I guess we all have different things we would similarly spend that kind of time on, but that wouldn't be one of mine.
    gatorback and Brian1954 like this.
  3. gatorback
    60
    Is the best practice use OEM TPM sensors? Google's AI indicates two OEMs Pacific Industrial Corp or TRW Automotive: is one better than the other or are they the same?
    How would I get the ID of the current sensors (so I program the aftermarket sensors with the ID)?
    #3 gatorback, Jul 15, 2025
  4. ChapmanF
    19,009
    If you have the tires off, you can read the ID numbers off the old sensors—they're printed there.
    If you have a suitable scan tool, you can read the currently registered IDs from the car.
    If you have the right specialized tire-shop tool, you can wave it near the tires and have it read the IDs from the old sensors (except dead ones...).
    Brian1954 likes this.
  5. gatorback
    60
    UPDATE: OEM sensor set from eBay = $40. Discount Auto Tire installed the set for $60.
    borgestes likes this.
  6. Hayslayer
    Hayslayer Active Member
    534
    325
    Was this advertised as OEM? If so, it is most likely an aftermarket, not actually original equipment. There's an aftermarket company named OEM that uses very deceptive advertising to make it appear as if it's original equipment. They're all over ebay and start their ads with "OEM". Similar thing if you see "Genuine". Read through the auction carefully and you'll see a BUNCH of grammar errors. All Chinese counterfeits.
    Toyotapartsdeal sells these sensors for about 80 bucks each, which is about $34 less than msrp. Think a $40 set of 4 is legit?
    For example:
    This is from a seller named "awesensor", who sells sensors of all types for all cars. They're even in what appears to be Toyota boxes, just like all the other counterfeit water pumps, spark plugs, coils, etc.
    "We sell most kinds of auto sensors,with high quality & proper price!We response quickly and ship packages quickly!Welcome to view our store and contact us!"
    #6 Hayslayer, Nov 7, 2025
