It's time! 100k proactive maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bgustafson, Apr 8, 2018.
  1. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    You have to remove the intake air filter component to get access to your OCC? Ouch! I hate removing car parts that are in the way. :mad:
    I like my drop and go OCC mount! Just lift up the OCC and unscrew the collector housing.(y)
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    I don’t mind the 3 minute activity knowing I don’t have any excess liquid on the downstream side of the PCV check ;).
    It’s good piece of mind(y).
  3. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    Hmmm you two have got me torn. Not sure where I should put it! :cry:
    Bay Stater and Raytheeagle like this.
  4. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Go low(y).
    Bay Stater and Bgustafson like this.
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    That’s what she said :ROFLMAO::ROFLMAO::ROFLMAO:
  6. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    If you must have the intake resonator, maybe try putting studs in place of the bolts for instant removal? Gravity should work in your favor...
    Pixel XL ?
    Raytheeagle and Bay Stater like this.
  7. Bay Stater
    534
    771
    Central Mass
    Well my hose is low. :ROFLMAO:
    Raytheeagle likes this.
  8. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Meh, I’d be concerned about fit and fitment with stationary objects and trying to get the resonator to easily get on and off;).
    Those 10 mm bolts aren’t that fiddly(y).
    mjoo and Bay Stater like this.
  9. Bgustafson
    259
    222
    Chicago
    Today’s the day! Going to begin work and hopefully finish by Tuesday. :whistle:
  10. Mendel Leisk
    42,355
    My OCC is mounted on the lower cross beam, but: I seem to be ok with a 6 monthly drains, synchronized with oil changes. Also, my (Moroso) OCC has a tap and spigot on the underside. I take the engine underpanel completely off for oil changes, so it's trivial to also open the the OCC tap.
    If you don't enjoy periodically removing the engine underpanel (hey, who doesn't): there's another member here with the same OCC (IIRC): he removed the tap and spigot, replaced it with an additional spgot (hose barb with npt threads at other end), connected a short length of fuel line, and the tap and spigot to the end of the hose, basically so he could run the tap to one of the openings in the engine underpanel.
    FWIW, my amount collected is roughly 100cc every 3000 miles.
    Bay Stater likes this.
  11. Bgustafson
    259
    222
    Chicago
    Spark plugs done!
    EGR pipe coming out.... yikes!!
    7EF944B5-489D-42EB-B4A7-15A5A264B0E0.jpeg 1F8BF24B-BC43-4CC0-B036-6F9133E93A6D.jpeg E26F8135-B80B-41CA-935D-DC10081E760D.jpeg 2B1F4B00-C353-4231-B220-6F5BDB513B9B.jpeg
  12. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
  13. Bgustafson
    259
    222
    Chicago
    It’s freeee!
    Man, that bolt under the EGR was a huge pain.
    107k..... I’d say it could’ve gone to 150 at the MOST, but that would’ve been pushing it. I can shoot a flashlight thru it and still see....mostly
    73C083EE-809B-4067-8FD7-D66C329DEA72.jpeg B8199825-4BB7-4261-8130-C816B8B4B62A.jpeg 9966D0D9-5530-4127-9FC8-3F488DE86313.jpeg
    So.. oxiclean or break cleaner? Both?
  14. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    You got a spare:whistle:?
    I’m a fan of brake cleaner ;).
    Good luck (y).
    Bay Stater and farmecologist like this.
  15. Bgustafson
    259
    222
    Chicago
    Wish I had a spare... that’s one minor detail I suppose I forgot to ask about! Should I just purchase a new EGR off eBay?
    I’m having a really tough time getting brake clean to clean out all the passages. What else can I try?
  16. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I usually get 2 cans;).
    1 I spray in all the passges first then if really built up, I put a plug in te end and let it sit for awhile:).
    Cleaning my spare that way now(y).
  17. Bgustafson
    259
    222
    Chicago
    Hot water soak seemed to do a lot of good! But I'm soaking it overnight in brake cleaner for good measure. What method did you use to seal off one end?
  18. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Rubber stopper I picked up from Lowe’s ;).
    The tapered 1” works well(y).
  19. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
  20. Mendel Leisk
    42,355
    Oxi-Clean solution, as strong as you can mix it, and let it soak till it stops bubbling, rinse and repeat as needed.(y)(y)(y)
    Just for the cooler though, which is stainless steel. For the valve, brake clean should be good enough, and oxi-clean might start tarnishing it.
