Just picked up a 2012 PiP!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PriusPapi, Dec 30, 2018.
  1. PriusPapi
    PriusPapi Junior Member
    Bay Area
    Just got a winter gray 2012 PiP w 82k on the clock for $9300. It’s been a real chore finding a clean one with leather in the Bay Area.
    I’m a little nervous since all the owner did was oil changes....no 30k or 60k service. I have my fingers crossed for when I take it to the shop next week.
    Is there anything I should tell the mechanic to look out for?
    iPhone ?
    PA Prius, mrlebop, iplug and 4 others like this.
  2. JC91006
    16,936
    8,647
    Just do a transaxle fluid change and you're good to go until 120k miles. Regular oil changes and filters are all it needs
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Congrats, @PriusPapi!! And welcome. Leather in a base model would be hard to find.
    I agree with @JC91006.
    edit to add: If you haven't already done so, you can register at Toyota's owners' website to check on what service records Toyota has and if there are any outstanding recalls. There was one about a year ago for a high voltage fuse in the traction battery.
    Toyota Owners Official Web Site
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    That’s a great deal for a 2012 PIP at that mileage out here:).
    Where’d you find that at:whistle:?
    Advice above is solid and I would only add a brake inspection and caliper pin lubrication to that list. If you take care of the brakes and drive ahead utilizing regen braking to a great extent, your original brakes could look like this (from our 2010 non-PIP with 194 k miles):
    5D0D0E12-9E5F-4971-9D68-3799AA011C69.jpeg 211B5A1C-79FC-4451-AB18-05D6281BA15C.jpeg 0ABC9ADF-D21D-48F5-8969-D70F3FB18677.jpeg C993AD46-BF13-4CCC-A6DF-00CF4ACD9D29.jpeg
    Enjoy your new to you PIP(y).
  5. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Hopefully your brakes won't look anywhere near as bad as the brakes on our Prius v (wagon) when we got it :
    Hi all, new Prius v owner | Page 3 | PriusChat
    Of course, you don't live anywhere near 'salt central' like we do...so you should be good to go! (y) However, as Ray said it certainly is worth a check.
    And BTW...if anyone has rotor rust problems, the zinc plated rotors I have installed are holding up great so far!
    BTW - I'm posting this because I *thought* the vehicle was in great condition when we purchased it...but should have looked a bit deeper before getting it. :unsure:
    Raytheeagle likes this.
  6. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Figured I’d show a pic of ours since it’s in the same area and demonstrates the concept;).
    I’ve converted a couple of guys at work to a 2015 and a Prime and when I showed them the brakes, they couldn’t believe they were original:).
    Reminded them that if the dealer says they need new brakes, they need to find another opinion or source of labor for future tasks(y).
    m.wynn and farmecologist like this.
  7. SlidingBike
    SlidingBike Active Member
    171
    113
    Fremont, CA
    Usually any manufacturer maintained owners vehicle profile lists only the records of services done at the dealerships, if the owner get the services at non-manufacturer shops, it doesnt list there. So, dont be panic if Toyota owners site didnt display a whole list of service records.
    For example, after 30K, I dont go to the Dealer for oil changes etc unless and otherwise the service cost differs max $20 or so. Also my periodical wheel balancing(ever 6 months) is being done at Wheelworks, which doesnt display on my Toy Owners site.
    jerrymildred likes this.
  8. JC91006
    16,936
    8,647
    You may want to clean out the egr pipe, it may have some carbon build up and you should get rid of it before it clogs your system. Do a complete egr circuit cleaning at 120k miles
    m.wynn and Raytheeagle like this.
  9. bisco
    52,848
    congrats and welcome to the pip club! all the best (y)
    30k and 60k get air filter service
    cabin filter every 15k, so make sure to check those
    test the 12v when it's cold and the car has been off overnight. should be above 12.4v
    mrlebop likes this.
  10. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    Papi, I have your car. Everything I was going to suggest, someone else has already posted. For me, it just runs and doesn't make any fuss.
    mrlebop, jerrymildred and bisco like this.
  11. Mendel Leisk
    42,343
    Eight years and change on, around 79K kms, I've yet to change either cabin or engine air filter. Don't pay someone to do that, for sure. And inspect the filter, make an appraisal, don't just blindly change them. Same story for wiper blades: still on the originals.
    I have changed the transaxle fluid: three times, which is probably two times too many.
    Brakes: Toyota USA suggests an in-depth inspection tri-yearly or 30K miles, whichever comes first. This is not the quick glance over during tire rotation, don't let anyone snow you: there maybe a lot of the braking being done by regen braking, but the brakes do wear, and the caliper pins do dry out. If you follow the schedule you will be in good shape. @NutzAboutBolts has a video on this.
    Brake fluid: Toyota Canada recommends to change tri-yearly or 48K kms, whichever comes first. It is relatively easy, there is a method without the need for Techstream (proprietary Toyota software), there's a vdeo here on how to do it by @NutzAboutBolts , and the procedure is outlined in the Repair Manual.
    Exhaust Gas Recirculation circuit: yeah, clogging is inevitable, best dealt with before it's royally clogged. See @NutzAboutBolts video on how to clean the "pipe" only, which will give some idea what the rest is like.
    Positive Crankcase Ventilation circuit: it tends to barf oil/water/gas mix into the intake manifold. A thorough cleaning of the intake manifold and install of an Oil Catch Can is the best solution. Once more, see @NutzAboutBolts videos.
    #11 Mendel Leisk, Dec 30, 2018
    NutzAboutBolts and JC91006 like this.
  12. PriusPapi
    Bay Area
    Thanks! I got lucky in the South Bay! The prior owner purchased a brand new Chevy Bolt. He needed to get rid of the Prius since it will no longer qualify for the HOV lane starting Jan 1, 2019.
    Im planning to get it checked out at Luscious Garage next week and will add brakes to my checklist.
    I checked the site..... Only three records, all within the first 15k or so. I’m hoping everyone here is right and these things are mostly bulletproof.
    I filled up for the first time today (to first gas pump click) and my estimated cruising mileage was around 415 miles. I know the tank is a little smaller on a Pip, but is that average? Also should I just use pain old 87 for best mpg?
    iPhone ?
    #12 PriusPapi, Dec 30, 2018
  13. PriusPapi
    Bay Area
  14. PriusPapi
    Bay Area
    Also, I'm thinking I need new tires. What would you guys recommend as a good balanced option (performance vs treadwear)? I plan to do driving in cold climates quite a bit. Here are pics of my current tires.
    D63BCD01-642A-4DB2-8E9B-CD0A042FB931.jpeg 010D0B0D-2112-4FE6-A643-552F223D4958.jpeg
    mrlebop and Raytheeagle like this.
  15. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Looks great:).
    I bought Bridgestone turanza serenities at 120 k miles and now at 194 k miles, they have 7/32nds left. Costco I believe has a deal on Bridgestone tires, so might want to look there;).
    Luscious will charge an arm and a leg, but they are reputable. You the DIY type :whistle:?
    Good luck and keep us posted (y).
    m.wynn and mrlebop like this.
  16. bisco
    52,848
    415 is about right, you only have 8 gallons until the low bar starts blinking.
    yes, 87 is all she needs. what a shine, gorgeous!
    m.wynn, mrlebop and jerrymildred like this.
  17. Mendel Leisk
    42,343
    It's fine.
    Sweet rims btw.
    m.wynn, Prodigyplace and Raytheeagle like this.
  18. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Collectors items I hear:p.
    m.wynn, Prodigyplace and Mendel Leisk like this.
  19. JC91006
    16,936
    8,647
    That grey car looks like the one I returned, but mine only had 38k miles on it
    m.wynn and PriusPapi like this.
  20. bisco
    52,848
    i see the resemblance
    m.wynn likes this.
